Michigan people - Page 9411 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > Great Lakes Fanatics
Great Lakes Fanatics Serving the Illinois, Indiana, Michigan, Minnesota, Ohio and Wisconsin regions.
Old 12-04-2012, 01:01 PM   #94101
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 3%
FF Reputation: 9 Timmeh! Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by klodkrawler05 View Post
Timmeh what do you think is appropriate for shifter bushing application?
I'm thinking standard run of the mill delrin because a shifter rod will see in its lifetime maybe half the movements/rotations a suspension bushing sees in 1 drive.
however I'm not opposed to using UHMW Polyethylene if it would be more appropriate for this particular application.
I'd say delrin, it's hard so you'll get hyper accurate shift feel, and it should last plenty long given the amount of movement it'll see. get a second set made for giggles though.
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is offline
Old 12-04-2012, 01:04 PM   #94102
klodkrawler05
Sooooooooooo EURO
klodkrawler05's Avatar
Fan#: 47771
What I Drive: BMW's
Points 12,702, Level 73
Points: 12,702, Level: 73 Points: 12,702, Level: 73 Points: 12,702, Level: 73
Level Up 63% Completed
Forum Activity 10%
FF Reputation: 26 klodkrawler05 Great Standing Member
Buy-Sell-Trade Rating: (30)
That was my thought, I'm actually thinking to try a set in aluminum as well. its not as though I'll experience any noise or vibration being transmitted through the shifter given that its got full poly mounts throughout, and I want a super precise shifter feel so that no shifts are missed trying to go from 2nd to 3rd on the auto-x track.
-Brad
'03 VW Jetta TDI - The Daily Commuter
'02 Chevy Corvette Z06 - The Toy
'99 Triumph Daytona - Death Machine
klodkrawler05 is offline
Old 12-04-2012, 01:07 PM   #94103
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
i hear ya, just not sure aluminum is the right material given the friction you'll be generating... metal on metal wouldn't be happy. delrin is supposed to have pretty good "lubricity" for lack of a better word. machine it right and sand the contacting surfaces a bit and it should be smooth like buttah.
Timmeh! is offline
Old 12-04-2012, 01:10 PM   #94104
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
Timmeh! is offline
Old 12-04-2012, 01:13 PM   #94105
TheBrain88
TheBrain88's Avatar
Fan#: 62354
What I Drive: 2013 Focus ST ST3
Points 276, Level 5
Points: 276, Level: 5 Points: 276, Level: 5 Points: 276, Level: 5
Level Up 52% Completed
Forum Activity 5%
FF Reputation: 1 TheBrain88 Good Standing Member
advice:
What do you do when you have all your work done for the WEEK on tuesday...and try to avoid getting in trouble for not doing work even though there is none...
2013 Focus ST ST3
TheBrain88 is offline
Old 12-04-2012, 01:14 PM   #94106
klodkrawler05
Sooooooooooo EURO
Fan#: 47771
What I Drive: BMW's
Forum Activity 10%
hmmmmmmmmmmmm
well then that could bring up an interesting option.
the bushings with arrows to them could be aluminum I think. that main rod is merely a support beam for the pivot ball of the shifter itself. the more solid that is the less twist/flex I'd get transmitted from the shifter itself into the support rod. so my though is aluminum bushings on both side of that to completely eliminate any flex/give around the pivot point of the shifter.
I'd expect this to potentially cause the plastic race on the shift rod to wear quicker because there would be more force directed to the shift rod ball/liner. #10 is the one that actually moves so I can see bushings 11-16 needing to be delrin to allow for some smoothness with pivoting. I'm also looking at maching a new piece number 10 to have to be more like an actual dog bone thus putting the rod in a double shear situation rather than single shear as currently. i'd either use delrin here or ball bearings although ball bearings are likely overkill. the double shear should eliminate any flex/twist this part sees as well giving me a very crisp buttery shifter since the only form of play left would be in the ball and shift rod pivot which I'd replace with new OEM bits.
-Brad
Old 12-04-2012, 01:20 PM   #94107
klodkrawler05
Sooooooooooo EURO
Fan#: 47771
What I Drive: BMW's
Forum Activity 10%
Originally Posted by TheBrain88 View Post
advice:
browse the internet or work on personal projects that somehow relate to my job.
researching materials for a shifter also increases my knowledge about materials in general so I'm able to pull from a larger knowledge bank when selecting material for a work related project.
solidworks skills improved while modeling up the shifter parts can be used for work projects as well.
-Brad
Old 12-04-2012, 01:23 PM   #94108
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 10,923, Level 69
Points: 10,923, Level: 69 Points: 10,923, Level: 69 Points: 10,923, Level: 69
Level Up 19% Completed
Forum Activity 19%
FF Reputation: 17 kylesvt720 Great Standing Member
Angry Birds skills could be used if I ever need to design a game for a phone...
Cool Lincoln gifs.
Jeremy Clarkson on Detroit: “God may have created the world in six days, but while he was resting on the seventh, Beelzebub popped up and did this place.”
ST CREW #107 / TEAM DURATEC #93 / D23 Crew #3
kylesvt720 is online now
Old 12-04-2012, 01:31 PM   #94109
Aku
Sneeze
Aku's Avatar
Fan#: 57726
What I Drive: 04 A4 Avant, 04 R32T, 94 CBR
Points 10,207, Level 67
Points: 10,207, Level: 67 Points: 10,207, Level: 67 Points: 10,207, Level: 67
Level Up 40% Completed
Forum Activity 7%
FF Reputation: 4 Aku Good Standing Member
'04 Audi A4 Avant 1.8T 6MT
'04 VW R32 - (O:o)=R32=W====(o:O)
'94 Honda CBR600 F2
Aku is offline
Old 12-04-2012, 01:33 PM   #94110
jwill2489
jwill2489's Avatar
Fan#: 78236
What I Drive: 2003 SVT JRSC w/BBK
Points 3,475, Level 36
Points: 3,475, Level: 36 Points: 3,475, Level: 36 Points: 3,475, Level: 36
Level Up 84% Completed
FF Reputation: 4 jwill2489 Good Standing Member
Klod use whatever bushings will prevent the magic shift
jwill2489 is offline
Tags
aku & oberon , ff men cursed , hide yo kids , hide yo wife , in before the lock , kyle is troll king , mi euro-trash thread , toots was here
