Michigan people - Page 7573 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > Great Lakes Fanatics
Great Lakes Fanatics Serving the Illinois, Indiana, Michigan, Minnesota, Ohio and Wisconsin regions.
Old 02-07-2012, 11:13 AM   #75721
wordyahurdd
coooookie monster
wordyahurdd's Avatar
Fan#: 41401
What I Drive: 13'ST, 04'SVT, 03'XB9s
Points 14,610, Level 78
Points: 14,610, Level: 78 Points: 14,610, Level: 78 Points: 14,610, Level: 78
Level Up 40% Completed
Forum Activity 9%
FF Reputation: 7 wordyahurdd Good Standing Member
Buy-Sell-Trade Rating: (16)
lol at bottom 2, i saw the top one this morning :)
2013 ST(3)
2004 SVT : #55 STF (now racecar)
2003 Buell XB9S
wordyahurdd is online now
Old 02-07-2012, 12:07 PM   #75722
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 3%
FF Reputation: 9 Timmeh! Good Standing Member
Buy-Sell-Trade Rating: (6)
assuming free veggie oil (waste from a local restaurant) and if i buy all the chemicals in bulk... (REALLY bulk)
I can make biodiesel for $0.73 a gallon!!!!
add some money for filters (the used oil will need filtering) and i'm still well under $1.50 a gallon.
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is offline
Old 02-07-2012, 12:37 PM   #75723
beat3rfocus
aint no shame
Fan#: 3178
What I Drive: Red 1990 Miata Hardtop
Points 15,249, Level 79
Points: 15,249, Level: 79 Points: 15,249, Level: 79 Points: 15,249, Level: 79
Level Up 80% Completed
FF Reputation: 11 beat3rfocus Great Standing Member
Buy-Sell-Trade Rating: (9)
How long until you start saving money though?
I sold my focus after 9 years.
beat3rfocus is offline
Old 02-07-2012, 12:47 PM   #75724
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
valid question. depends how many big fuel containers i can take home from work and repurpose... we've got TONS of 55 gallon drums because of the fuel sender guys and all sorts of other neat stuff.
the chemical cost is $0.73/gal, the cost to actually make the stuff depends how good of a deal i can get on containers and such...
diesel is $3.70ish + right now so saving $3/gallon will add up quick.
i'd say i'd have to make 75-100 gallons to at least get my money back for the initial big batch investment, and for me that's 2.5-3 months of fuel.
past that point it'd all be money in my pocket. and if other people would be willing to come get some biodiesel from me (i'd keep the cost REAL low) i can make that money back faster by moving more product through the system.
Timmeh! is offline
Old 02-07-2012, 12:58 PM   #75725
beat3rfocus
aint no shame
Fan#: 3178
Dont forget testing supplies to make sure its premium. Its a seasonal burn due to it gelling in cold weather. Unless you purge your fuel system with diesel every time you park. Along with a heated fuel cell for the bio diesel.
Old 02-07-2012, 01:09 PM   #75726
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
well right, testing supplies are either a titration test (relatively cheap) or a pH meter (one time buy)
there's anti-gelling additives that can be used with biodiesel, lowering the gel point by 30 degrees F.
they mix in a 1:750 ratio. 5 gallons is ~$280 and treats 3750 gallons... which as an extra..... $0.074/gallon.
as far as gel temps, the site i'm referencing has this to say:
Depending on the oils used, biodiesel made from fresh, unused oil has a lower pour-point (or CFPP -- Cold-Filter Plugging Point) than biodiesel made from used cooking oil (UCO, WVO). But, again depending on the oil, WVO biodiesel should be okay to a few degrees below freezing. Ours is fine to about -5 deg C (23 deg F). (We think it helps a lot to process it properly and make high-quality fuel -- see Biodiesel test results.
if i treat it with anti-gel, or buy diesel and mix it in, i can get a blend that will start in the winter without much issue. sure maybe i have to run B70 in the winter, but i can run full B100 in the summer.
Timmeh! is offline
Old 02-07-2012, 01:10 PM   #75727
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
more info on winterizing...
Winterized biodiesel
Some people find their WVO biodiesel starts to gel at around 4-5 deg C (40 deg F). This is because any saturated fats/oils in the WVO will crystallise (solidify) at higher temperatures than unsaturated fats and oils, and separate out, clogging the filter. That includes tallow, lard, palm oil, etc.
To make WVO biodiesel for winter, heat the oil first, then cool it to near freezing point; the saturated fats will crystallise out and sink to the bottom. Use the clear oil off the top to make winter biodiesel, keep the stuff at the bottom for summer. But even this "winterized" biodiesel still won't go much below -5 deg C (23 deg F) without gelling.
Timmeh! is offline
Old 02-07-2012, 02:02 PM   #75728
Aku
Sneeze
Aku's Avatar
Fan#: 57726
What I Drive: 04 A4 Avant, 04 R32T, 94 CBR
Points 10,207, Level 67
Points: 10,207, Level: 67 Points: 10,207, Level: 67 Points: 10,207, Level: 67
Forum Activity 7%
FF Reputation: 4 Aku Good Standing Member
Sounds dope
'04 Audi A4 Avant 1.8T 6MT
'04 VW R32 - (O:o)=R32=W====(o:O)
'94 Honda CBR600 F2
Aku is offline
Old 02-07-2012, 04:24 PM   #75729
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
Looks like work is interested in putting one of their sensors on my car to see how it (the sensor) responds to biodiesel made from waste veggie oil... going to see how much extra $$$ i can swing with that/see if they'll provide me with the fuel itself.
Timmeh! is offline
Old 02-07-2012, 11:18 PM   #75730
sjdwales
Wales!!
sjdwales's Avatar
Fan#: 46854
What I Drive: 11 mustang
Points 15,707, Level 80
Points: 15,707, Level: 80 Points: 15,707, Level: 80 Points: 15,707, Level: 80
Level Up 72% Completed
FF Reputation: 13 sjdwales Great Standing Member
Buy-Sell-Trade Rating: (26)
saw sonic blue svt tonight turn from canton center rd onto ford rd and then turned into meijer. had tinted windows and zx3 decal pealed off on the back. was also rear ended/hit on passenger rear side.
No longer drives a focus, WTF?
sjdwales is offline
Tags
aku & oberon , ff men cursed , hide yo kids , hide yo wife , in before the lock , kyle is troll king , mi euro-trash thread , toots was here
