Ford Focus 2005 Zx4 Power steering problems!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-07-2006, 06:45 PM   #1
danielhernandez
Fan#: 34834
FF Reputation: 1 danielhernandez Good Standing Member
Hi,
I have an Ford Focus 2005 ZX4,,that i bought wrecked so it doesnt;a have warranty
the car has only 2700 miles
The powersteering pump makes a lot of noise,,,the steering is not hard
when i turn the steering full it will sound harder
the pw oil will become like pink and gets like foam ,,is this normal;?when the car is on,,i see that the pw reservoir is empty..when i turn off the car the oil will come back in the reservoir
Thanks
Daniel
danielhernandez is offline
Old 09-07-2006, 11:04 PM   #2
downloader
Fan#: 10606
What I Drive: wagon
FF Reputation: 1 downloader Good Standing Member
add some fluid, the pump is low on oil and is pumping air (your foam)
downloader is offline
Old 09-07-2006, 11:11 PM   #3
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,973, Level 91
Points: 20,973, Level: 91 Points: 20,973, Level: 91 Points: 20,973, Level: 91
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 11%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
if you ran the car low on fluid and it has air in it you'll have to bleed it. to do this let the car set for a while after driving so every thing settles and cools, take the cap off the resivoir fill it up to the full line, jack the front of the car up, turn the key to the on possition (not all the way to start-if you start it you have to let it set for a while agian to settle) just enough to unlock it, and turn the steering wheel from lock to lock about 50 times. and while your doing this make sure you keep resivour full because it will get lower as the air is bleed. 50 times should do it but if its still bubbling keep going till it stops.
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 09-08-2006, 02:24 AM   #4
danielhernandez
Fan#: 34834
Thanks you guys,
The problem is fixed,,,
Thanks again for your help
Old 05-17-2012, 10:34 AM   #5
DerrellFord000
Fan#: 95340
What I Drive: 2007 Ford Fusion SEL V6 AWD Red
FF Reputation: 1 DerrellFord000 Good Standing Member
I have an 06 pos. My girldfriend has been running it empty. I thought i would need to replace the whole pump. This sounds promising. I thank the forumers before me.
DerrellFord000 is offline
