Key FOB Programming - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 03-22-2004, 11:11 AM   #1
wfitzpat
Fan#: 5019
What I Drive: 01 SE wagon Ztech 5sp
FF Reputation: 1 wfitzpat Good Standing Member
Key FOB Programming
Hey there Fanatics
I am a new Focus owner and new to this forum so forgive me if I am asking a question which has been dealt with 1000 times already.
The the car I purchased was used and unfortunately did not come with the FOBs. There are plenty of cheap ones avalable locally (Ontario Canada) but I do not know the sequence to program the car to accept them. I have seen numerous posts on reprogramming for performance upgrades ect. but none relating to the more mundane tasks. Can you help?
Cheers
Bill
wfitzpat is offline
Old 03-22-2004, 11:37 AM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Did the car originally come with remote access?
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 03-22-2004, 11:50 AM   #3
wfitzpat
Fan#: 5019
I do not know. Based on the equipment and model ('01 SE Wagon,Ztech, ect.) I assume that it came equipped.
wfitzpat is offline
Old 03-22-2004, 01:08 PM   #4
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Well, someone on another board said that the procedure is in the manual.
1. Close all doors and fasten seat belt.
2. Turn ignition lock from OFF to ON/RUN at least 4 times in 6 seconds.
3. Switch off the ignition. There should be a chime...this indicates it's in "learning mode". You have 10 seconds to do the following:
4. Press & hold one of the buttons of the remote until a chime sounds. This chime says that the code has been received by the remote successfully. Repeat with the other transmitters.
5. If no new remotes are programmed after 10 seconds, or if 4 (max # of remotes) have been programmed, you're done!
6. Test.
As if it will work or not, I don't know. Just because you have power locks doesn't mean you have remote entry.
Egz is offline
Old 03-22-2004, 07:30 PM   #5
wfitzpat
Fan#: 5019
Thanks EGZ. I pick the car up tomorrow and look forward to giving the FOB a try. Thanks to all who responded.
Cheers
wfitzpat is offline
Old 12-19-2008, 09:49 AM   #6
copierwiz
Fan#: 57417
What I Drive: 2004, Red Ford Focus SE
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 copierwiz Good Standing Member
I tried to program a spare fob which I bought used from somebody who sold his Focus 03 but with my 04 focus I programmed that fob no problem but when I tried my original fob that didn't work at all I tried few times even with another spare key. Any idea why
copierwiz is offline
Old 12-19-2008, 10:07 AM   #7
MichaelJD1980
Fan#: 55223
What I Drive: 2013 Tux SE Black Pack 5MT
Points 1,149, Level 18
Points: 1,149, Level: 18 Points: 1,149, Level: 18 Points: 1,149, Level: 18
Level Up 49% Completed
FF Reputation: 9 MichaelJD1980 Good Standing Member
When you enter the program sequence for the key fobs, it sets a new code, so you have to reprogram them ALL at the SAME time. Just programming one will kick the other two out of the system.
MichaelJD1980 is offline
Similar Threads
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
Key Fob compatibility drbadskwerl General Technical Chat 2 11-15-2007 05:30 PM
Key Fob Battery Question miniboon Car Audio, SYNC, MyFord Touch & Electronics 2 10-01-2007 02:01 PM
remote control key fob not working fehrion General Technical Chat 9 05-31-2007 12:45 AM
one key programming? Sh00ter General Technical Chat 6 06-15-2005 03:22 PM
