The break lights on my ZX3 wont go out! - Focus Fanatics
Old 08-30-2006, 05:46 AM   #1
batmessiah
Fan#: 38528
What I Drive: Dark Red 2003 ZX3
FF Reputation: 1 batmessiah Good Standing Member
Question The break lights on my ZX3 wont go out!
I've been having problems with my break system for a while now. The first mistake I made was having my uncle, who is a mechanic on the side, change my break pads and rotors.
We could never get the breaks to pump back up. No matter how many times we bled the breaks, they wouldn't pump back up. We thought it might have been the master break cylandir, and replaced it to not much improvement. When I drove the car, I would have to pump the breaks a good 5 or 6 times so I could stop. Eventually, over 6 months, the breaks finally pumped up and have been working.
Now, ever since the breaks started working properly, and possibly before then, my breaks lights have been on, and stay on. I am afraid someone is going to plow into the back of my 2003 ZX3 at some point.
Is it just a sensor I need to reset? Any help at all would be much appreciated!
batmessiah is offline
Old 08-30-2006, 06:07 AM   #2
OrangeSVT
OrangeSVT's Avatar
Fan#: 3158
What I Drive: 03 SVTF Euro, 92 Mustang LX 5.8L SC
FF Reputation: 1 OrangeSVT Good Standing Member
Your brake light switch may be bad (its on your brake pedel) not uncommon on fords. its easy to change ...unplug it and see if lights go out
MMMMMM, I like eating Rice
#3342 of 3986
OrangeSVT is offline
Old 08-30-2006, 06:20 AM   #3
DJ Lukdogg
DJ Lukdogg's Avatar
Fan#: 38235
What I Drive: 2006 Classic Silver Scion Tc
FF Reputation: 7 DJ Lukdogg Good Standing Member
Check if you bent the bracket that is suppose to touch the brake switch. Alot of times if you just bend it back a little bit the lights should go off i know i have done that plenty of times. but like ORANGE said it also may be your SWITCH which is a 15 dollar part and a piece of cake to change.
DJ Lukdogg is offline
Old 08-30-2006, 06:38 AM   #4
batmessiah
Fan#: 38528
I'll check this in a few minutes on my next break. So, it seems that this switch is the only thing that controls your break light, and is completely seperate from your actual break system?
That is a bit of a relief.
Old 08-30-2006, 06:47 AM   #5
batmessiah
Fan#: 38528
And after checking it seems as if the bracket somehow got bent. Now to go pry on it and bend it back to place!
Thankfully thats the only problem!
Old 08-30-2006, 02:39 PM   #6
Newkleus
Bexar County
Newkleus's Avatar
Fan#: 30810
What I Drive: 2002 CD Silver Focus SVT
FF Reputation: 5 Newkleus Good Standing Member
My parking brake light would come on for no reason because of a broke as master cylinder.
SVT SQUAD #344
2002 CD-Silver Focus SVT
Newkleus is offline
Old 08-30-2006, 04:18 PM   #7
DJ Lukdogg
DJ Lukdogg's Avatar
Fan#: 38235
Glad to see you fixed your problem it commonly happens with me on the Brake switch recall on the taurues i bend it alot of times by accident and just bend it back. No biggy.
Old 08-31-2006, 03:46 AM   #8
turbo joe
turbo joe's Avatar
Fan#: 37711
What I Drive: 1000 horse Focus wagon ;)
FF Reputation: 1 turbo joe Good Standing Member
I bet it's not a "bent" thing...it's the switch.
The switches are like the old door jamb switches that come extra long. You install them and the pedal shoves the barrel in to the right length...like a round zip-tie.
Anyways...your uncle probably tried to bleed the brakes and pulled the pedal up farther than it would have normally travelled. The switch gets shoved in farther...then when someone isn't pulling the pedal up to the over-traveled position, the tab won't reach far enough to shut off the lamps.
You should at least pull the switch and uncompress it...they'll take it a time or two before they strip all the way...or just get a new one. You can tweak the tab or the pedal support to accomodate the tweaked plastic switch, but it would be kinda "Mickey Mouse" to bend metal stuff to fit a misadjusted plastic switch. Obviously, it's your call...
turbo joe is offline
Old 09-01-2006, 10:47 AM   #9
erased023
erased023's Avatar
Fan#: 21731
What I Drive: 2001 ZX3
FF Reputation: 1 erased023 Good Standing Member
Same thing is happening with my 2001 zx3. The brake lights stay on when on drive, but when its parked they work..?.Also the turing signals from the back..i turn them on..either right or left. They both turn on and off..not at the same time..but more like a cop kind of thing..?
erased023 is offline
Old 09-08-2006, 09:26 PM   #10
bobadi
Fan#: 38890
What I Drive: 2002 ZX3
FF Reputation: 1 bobadi Good Standing Member
I just now got my brake lights stuck on, but I doubt that it is the switch.
I was trying to hook up trailer lights to a new trailer and something must have shorted. I never had a problem untill this wiring fiasco. I disconnected the trailer hook up but those brake lights still run with the ignition switch on.
Any suggestions?
Doh!! It was the switch! and the easyist fix I ever made! It must have been stuck on for about a week, cause that is how long my cruize control was out for..
Jeez I am mortified.. But thanks guys!
bobadi is offline
