SVT springs and Eibach dampers- good combo? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 08-10-2006, 12:11 PM   #1
philc
Fan#: 37636
What I Drive: '02 SVTF
FF Reputation: 1 philc Good Standing Member
ok, I did a search and nothing showed up-
in autox, I *have* to run the stock height springs to run in a stock class-
the SVTF currently has the eibach pro setup on it (springs and dampers), and I'll need to remove the eibach spring and install the SVT springs-
does anyone run this combo? are the eibach dampers better than the SVT dampers? will they work well with the SVT springs?
I know the SVT springs are
F: 129 lb/in
R: 157 lb/in
and the eibach springs
F: 137 lb/in
R: 171 lb/in
so the change in spring ratio isn't that extreme (6%f, 9%r)
or would I be better running the SVTF dampers?
thanks FF!
'02 SVTF
3x '86 SVO mustangs
and about 5 other fords.
philc is offline
Old 08-10-2006, 04:22 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
You should be fine with the Eibach dampers and SVT springs.
I'm running the adjustable KYB-AGX's with stock SVT springs.
Works very well.
Only reason I'm running STS instead of GS, is due to the STS and VF Rear Eng mount.
^^^Well, that, and we're all on equal footing so to speak, as R-Compounds are not allowed in STS.
WD40 is offline
Old 08-10-2006, 05:21 PM   #3
philc
Fan#: 37636
thanks for the info!
I'm looking forward to kicking some butt in GS this year-
I currently run a comp-prep SVO, but due to chassis problems, I can't get any good alignment out of it.
'02 SVTF
3x '86 SVO mustangs
philc is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
