Central Locking System - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2006, 09:03 PM   #1
ZeDo
Fan#: 35723
What I Drive: Red Zx3 2000
FF Reputation: 1 ZeDo Good Standing Member
Hey Guys I have a 2000 Zx3 Ford Focus. My locking system just went down a month ago. I have replaced the fuse and the fuse keeps on going in a few minutes or seconds. It does burn out faster when the car is running.
Now with the fuse fried. The Rear hatch seems to unlock when I start the vehicle. I disconnected both doors and played with the locks with a new fuse installed. I had a suspicion the right door was not working correctly so I took it apart and really didn't find much of anything wrong. I tried it with the right door disconnected and no problems, and than plugged it back in. They both worked good. I turned the car on and the fuse fried.
I tried to release the trunk hatch and found the horn would sound when I did that, and than I could not activate the locks, but the fuse wasn't fried. I also noticed the left signal light would go on when I tried to unlock the trunk. Very odd.
I finnaly disconnected the rear hatch and well the fuse blew Immediatley when I used the locks.
I am very puzzled at whats going on with this car and figured I would post here and see what you all had to say.
ZeDo is offline
Old 08-06-2006, 06:13 PM   #2
FocusDog
FocusDog's Avatar
Fan#: 33087
What I Drive: 2000 Green SE Wagon
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 FocusDog Good Standing Member
The dealers supposedly have a diagnostic tester specifically for the Central Locking System/ Central Security Module, due to its complexity.
Supposedly, there's also a built in self test for the 2000 central locking/central security system -- I've never tried it, but here's what the book says to do:
Ignition OFF
Operate one of the door light switches 6 times within 8 seconds to activate self test
The horn will sound and the hazard lights will flash once to acknowledge.
The horn will sound and the hazard lights will flash every time a door, hood, or liftgate is opened.
If the doors are double-locked, and interior scanning is installed, the signal will occur when something is moved within the passenger compartment.
I supposed the self test is terminated if the car is started, but the instructions don't really say anything.
"Yes, that's right, its a Wagon..."
FocusDog is offline
Old 08-07-2006, 08:48 PM   #3
ZeDo
Fan#: 35723
Thank you very much for that. Does the Disgnostic Self test tell you what the problem is when it is finnished?
ZeDo is offline
Old 08-07-2006, 09:15 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Check the How-To's.. what FocusDog mentioned is similar to turning ON/OFF the central locking feature. My car was so rushed through the assembly line that the feature was turned off when I got it. I followed the How-To on this site and turned it on. It might save you some fuses to turn it off for now until you can get to a Ford dealer to figure out what is causing the malfunction.
If I'm not mistaken, there is no powerless back up to the latch lock mechanisms in the Focus, so if the system goes out and the doors are locked--- you could be screwed.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-07-2006, 11:55 PM   #5
FocusDog
FocusDog's Avatar
Fan#: 33087
Points 298, Level 5
As far as I know, self test just acknowledges that the door switches work by flashing the lights and honking the horn so you can narrow down which door/hatch is involved in the problem. I guess in a roundabout way, it tests the switches and the module's ability to interpret the switches.
FocusDog is offline
Old 08-11-2006, 12:05 AM   #6
ZeDo
Fan#: 35723
OKay sounds good. Now I suppose it won't work if the fuse is broken..
Again thanks for your time.
ZeDo is offline
Old 01-25-2012, 11:16 AM   #7
charles5
Fan#: 94254
What I Drive: silver ford focus 99
FF Reputation: 1 charles5 Good Standing Member
central locking system
hi can anyone help me i have bought a ford focus with two keys one fob and one normal key. the fob key unlocks the car when you put the key in the door, but it does not work when the button is pressed and doesnt start the car either, the lights on the dash come on and that is it. i have tried doing the on off tip 6-8 times , changed the battery in the fob and nothing works
i will be grateful for any tips and hints.
charles5 is offline
Old 01-25-2012, 11:30 AM   #8
Getahorse II
Fan#: 73771
What I Drive: 2000 red SE wagon, SPI
Points 348, Level 6
Points: 348, Level: 6 Points: 348, Level: 6 Points: 348, Level: 6
FF Reputation: 1 Getahorse II Good Standing Member
If by "normal key" you mean one like you'd get from the hardware store, it will never start the vehicle. There is a microchip in Focus keys, and a sensor ring around the ignition lock that picks up the key code. The code in your key's chip is stored in the in the vehicle's pcm. If you try to start the vehicle with a key it doesn't recognize, nothing happens.
You can buy extra chip keys and program them yourself. The procedure is outlined in your owners manual.
Getahorse II is offline
Old 01-25-2012, 11:38 AM   #9
charles5
Fan#: 94254
my brother has a focus as well the same. when we swap mote heads on top of the keys he can program it to his focus but i cant to mine.
charles5 is offline
Old 01-25-2012, 12:55 PM   #10
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
You can only program more fobs IF you have two good fobs
This is to prevent thieving parking attendants from making a fob for themselves
Otherwise is off to the dealer or super locksmith that has the electronic tooling
mikeeshaq is offline
