Zetec hesitation at low rpm - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-02-2006, 01:46 AM   #1
chucozx3
Fan#: 30075
What I Drive: 2003 zetec zx3
FF Reputation: 1 chucozx3 Good Standing Member
Angry Zetec hesitation at low rpm
hey guys, i have a question that i could not find in search. I have a fustrating hesitation at low rpms mostly from a stand launch between idle and 2000 rpms. started happening about two weeks ago. Ive changed spark plugs, checked coil, wires, even changed the pcv valve. still there wtf. i ran out of ideas no check light, i have 35K on the focus. any idea would help out alot let me know?
simple mods on this focus,my daily driver!
aem ram intake
focussport udr
msd coil
nology amps
fight to the end! whatever it takes to beat yourself
chucozx3 is offline
Old 08-02-2006, 02:19 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I have the same problem from idle to 2000 rpm it could be the DFPE try searching that out I have'nt replaced mine yet you might want to check the spelling on that though. hopefully will someone will chime in and correct my spelling.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 08-02-2006, 05:34 AM   #3
HalfTime
HalfTime's Avatar
Fan#: 33093
What I Drive: '03 S/C SVTF, '00 SVTL
FF Reputation: 1 HalfTime Good Standing Member
Other then the normal low end Focus trubble, you may have a fuel pump going out??? Does it idle lean? But run fine up top? If it is idleing lean you can smell it. Smells like a bad cat, or a bit lke eggs I guess, not sure how to discribe it. But it don't smell like tipical normal exhaust. If it is rich, you'll smell fuel, and see dark smoke on rapid deceleration + backfireing and popping.
2000 Ford F-150 SVT Lightning @17lbs
2003 Ford Focus SVT ZX3 @18lbs
HalfTime is offline
Old 08-03-2006, 12:56 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
You know I just put new plugs in cause my last set were burning too hot the white insulation was almost to the blistering point. If my car is running lean how do I fix it? Oh and my idle does not miss but it is alittle rough but its been that way since I put in another motor and lower motor mount it horrible with the A/C on. Rpms are fine (I used the digital tach in the odometer) 800 rpms +or- 100 rpm. How would I fix it?
Moderator for
Technical Chat
Old 08-03-2006, 06:17 AM   #5
allanzx3
Fan#: 33007
What I Drive: 2001 Liquid Grey ZX3 S2
FF Reputation: 0 allanzx3 Newbie
Change the fuel filter first. It should be maintance anyway. But my car is doingf the same thing yours is. I replaced the filter and that helped but my fuel pump is deffently on its way out....
2001 Ford Focus ZX3 S2
2002 Mazda Protege5
allanzx3 is offline
Old 08-03-2006, 10:26 PM   #6
chucozx3
Fan#: 30075
Ok i've changed the fuel filter, and dude i hope it doesn't smell like eggs. its bad enough it looks like one (lol). anyway it might be the damn pump. it runs fine at the top. but wtf is DFPE is that a sensor? thanks guys good thought here
chucozx3 is offline
Old 08-04-2006, 06:16 AM   #7
allanzx3
Fan#: 33007
DFPE = Egr
Basically the foci are known for a bad egr sensor, causes the valve to be open when its not suposed to be. Personally i just disabled mine but left the sensor to keep the engine light off.
Egr Disable
2002 Mazda Protege5
allanzx3 is offline
Old 08-04-2006, 07:20 PM   #8
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
so could this be the reason why I am getting bad gas mileage?
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 12-17-2006, 01:23 AM   #9
AcIdBuRn02ZTS
Fan#: 42027
What I Drive: 2002 Twilight Blue ZTS Sedan
FF Reputation: 5 AcIdBuRn02ZTS Good Standing Member
anyone ever figure this out? I'm new to this forum and am having the same problem with my 02 ZTS....
off idle... horrible hesitation... up top... no problems at all....
and horrible fuel mileage... my last tank i averaged 17mpg...
please help
-AcId-
AcIdBuRn02ZTS is offline
Old 12-17-2006, 05:53 PM   #10
rayflex
Fan#: 41399
FF Reputation: 1 rayflex Good Standing Member
i have same problem my focus run like crap from idte til 2000rpm after them he run excelent. And no errors code nothink :( maby it can be O2 sensor i checked evrythink but seems all ok
rayflex is offline
