Update on Headers... - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-03-2006, 04:02 PM   #21
phord_phocus86
phord_phocus86's Avatar
Fan#: 33505
What I Drive: 2002 ZX3 Base
FF Reputation: 3 phord_phocus86 Good Standing Member
Buy-Sell-Trade Rating: (12)
what i am getting from that read is that both are correct
This first solution works like the SVT/Escort GT headers by seperating the firing order so that they can move more freely for more HP.
The optimum cure to this whole problem is to correct the exhaust firing cycle. The two cylinders that fire in succession into each collector have to be separated. This can be done partially by a "Tri-Y" header, where the four primary tubes from each bank merge into two secondary tubes (separating the two pulses firing in succession) and finally collect into a single collector. This type of header helps, but the two pulses are still coming back together at the collector.
This second solution says it creates more vacuum and works like the focussport zetec header for more torque.
The second optimum cure is to cross the two center tubes from each bank, across the engine running them into the collector on the opposite side. This makes the firing cycle in each collector 180 degrees apart, the same as a four cylinder engine. Once this firing order is achieved, the small collector outlet diameter can be used and the "High Velocity Scavenging" at low R.P.M.s cures the reversion problems and eliminates the need for extreme cam duration.
I'm pritty sure I'm getting this right....
I still have a Focus parked, I might fix it up one day.
phord_phocus86 is offline
Old 08-03-2006, 05:56 PM   #22
focusin
FF Cleaning Squad
focusin's Avatar
Fan#: 4322
What I Drive: All Focus' sold
FF Reputation: 63 focusin Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Newb- That header looks SOO familiar
This is great info, I will stick this up on top.
Retired Moderator
GumpCrew #1 (dismantled)
focusin is offline
Old 08-03-2006, 06:50 PM   #23
phord_phocus86
Fan#: 33505
I just wish we could get an experts input on this. It's not even vehicle specific just 4cyl. specific so if anybody has a friend who knows their exhaust ask them about firing order and header configuration, because right now it looks like any configuration works.
Old 08-03-2006, 08:52 PM   #24
pLaYa2284
pLaYa2284's Avatar
Fan#: 5524
What I Drive: 2002 [Black] Focus SE :SPI: 5 Speed
FF Reputation: 1 pLaYa2284 Good Standing Member
Buy-Sell-Trade Rating: (4)
I came home from work so excited to see so many posts, and that this became a sticky ... but alas, not quite there yet ... good information guys, keep it up!
this might help; [hint; it's plain english] and leans toward the 1-3-4-2 firing order doing better by having cylinders 1 and 3 seperated ... I could be wrong, I'm so burned out from work.
http://auto.howstuffworks.com/question172.htm
so; have we come up with a solution yet?
----[edit below]----
I also thought we should probably follow the way ford racing headers work, since they designed the engine, and probably know more about what they're doing ...
----[edit above]----
-=[L.G.]=- pLaYa
2002 [Sangria] Focus SE :Zetec:
pLaYa2284 is offline
Old 08-03-2006, 10:34 PM   #25
phord_phocus86
Fan#: 33505
What the hell man, this is getting more and more complex. I found out the mustang 2.3L 4Cyl shares the same firing order as well, and their after market headers use both the 1-3 and 4-2 pattern, and the 1-4 and 2-3 pattern... so its pritty much evenly split now.
Old 08-03-2006, 10:41 PM   #26
pLaYa2284
pLaYa2284's Avatar
Fan#: 5524
1-4 and 2-3 gets my vote, it just amkes more sense; backpressure is going to build up big-time if both 1 and three are going off after each other, into the same downpipe ... seems as if you would want 1 going off, then 3 into the other set, then 4 into the same as 1, and finally 2 into the last pipe, nothing builds up as pressure ...
I guess my real question would be; what exactly fits our engine, rather than which one uses the correct order? Any clues to something we can find relatively simply? (as in; go to this website, click add to cart, install)
-=[L.G.]=- pLaYa
Old 08-03-2006, 10:47 PM   #27
phord_phocus86
Fan#: 33505
ok, VW MK@ Jetta has the same firing order and use the AVT/ escort focus design in their after market...
Old 08-03-2006, 11:03 PM   #28
phord_phocus86
Fan#: 33505
ok, so this is where we need jeff to chime in. In the Goodies list here it says that the 86-90 GT header is the one to modify, however in my serach I found no GT for 86-90.
Here is what I found that might fit-
Ford Escort (86-90) 1.9L SOHC - 1-1/2", 2 1/2", 169854 $302.29
OR
Ford Escort (91-96) GT 1.8L - 1-5/8", 2 1/4", 169872 $302.29
link- http://www.horsepowerfreaks.com/pric...Jet_Hot_Coated
Old 08-03-2006, 11:21 PM   #29
phord_phocus86
Fan#: 33505
Also I found out that the 86-90 GT uses the 1.9 SEFI version of the CVH motors, so does that mean that any SEFI header bolts up??? I'll keep looking around
Old 08-03-2006, 11:33 PM   #30
pLaYa2284
pLaYa2284's Avatar
Fan#: 5524
haha, got you working overtime on here?
-=[L.G.]=- pLaYa
