Fuses Under Hood - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-24-2006, 04:05 AM   #1
ammorgan
Fan#: 34226
What I Drive: 2003 Dark Blue ZTS
FF Reputation: 1 ammorgan Good Standing Member
Fuses Under Hood
I looked at fuses at Wal-Mart and not really sure which ones I need. I know the ones I need say 10 on them. Need the ones for the high beams, only have one and the high beams don't work. :(
ammorgan is offline
Old 07-24-2006, 09:24 PM   #2
ammorgan
Fan#: 34226
Is there like any difference between motorcycle and car ones? Or can I just grab a pack that has the 10 ones in them and I'll be good?
ammorgan is offline
Old 07-24-2006, 10:00 PM   #3
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
What I Drive: '00 ZX3 Turbo, '06 ST Turbo
Points 5,063, Level 45
Points: 5,063, Level: 45 Points: 5,063, Level: 45 Points: 5,063, Level: 45
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 24 tiresmoker Great Standing Member
there may be a difference, depending on which size fuse. By size I mean there are tiny mini fuses that are smaller than the 10 amp fuse you would be looking for. Do you have an auto zone or an advanced auto near you? you don't want the mini fuses. I wish I had a pic of the mini ones , but I don't. You can tell though, they are really small.
The fuses you want to get are about 3/4" in width across the top where it reads 10
ST Crew #19
2006 ST Turbo: JUNE 07 ROTM 2007 Ride of the Year
2000 ZX3: superturbochargedpartscar
2005 Shinka RX-8: too many mods....
Originally Posted by 03OrangeSVT
It was like concentrated death on chicken
tiresmoker is offline
Old 07-24-2006, 10:01 PM   #4
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Why not just take the fuse from the car into the store and compare them?
penguin is offline
Old 07-24-2006, 10:09 PM   #5
ammorgan
Fan#: 34226
I tried to pull it out with just my hand and couldn't get it out.
ammorgan is offline
Old 07-24-2006, 10:25 PM   #6
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
they're in there pretty tight. If you have a pair of needle nose use them, carefully! ONLY touch the plastic on the fuse and gently wiggle it as you pull up. ry and grab the fuse in the middle, right where it has the number 10. Don't stick the plyers in too far because you run the rick of making contact with the fuse panel itself and shorting out the system. Do this with the keys out of the ignition.
ST Crew #19
Old 07-24-2006, 10:41 PM   #7
NorCaLarry
NorCaLarry's Avatar
Fan#: 22999
What I Drive: 2005 Liquid Grey ZX3 SE
FF Reputation: 1 NorCaLarry Good Standing Member
On my 05 both fuse boxes have a little yellow plastic fuse puller.....dont overlook yours if you have one.
Ford Sport Group Option
Ford Convenience Group Option
ATX - Moonroof
Duratec 20 PZEV
NorCaLarry is offline
Old 07-25-2006, 12:05 AM   #8
ammorgan
Fan#: 34226
Well I tried to stick a new fuse into the box and I don't know if I'm not pushing hard enough or what but the fuse is still loose. Loose enough that I can pull it right back out.
ammorgan is offline
Old 07-25-2006, 08:38 AM   #9
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
after you put the new fuse in does the top sit level with the surrounding fuses? If not it's not in deep enough. If so you "may" have pushed out the connection through the bottom.
ST Crew #19
Old 07-25-2006, 02:16 PM   #10
ammorgan
Fan#: 34226
Yeah it sits at the same level. I was thinking it should click into place.
ammorgan is offline
