timing belt withering away *w/ pics* - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-16-2004, 02:00 PM   #1
bartlomiej
bartlomiej's Avatar
Fan#: 2870
What I Drive: 2001 zx3 mtx
FF Reputation: 1 bartlomiej Good Standing Member
My timing belt rubs against the timing belt cover and wears the belt thin. I have had this problem ever since I got this engine, I have changed the cam gears, cam idler pulley, and cam tensioner pulley, and my timing belt still rubs agains the timing belt cover. anyone ever seen this before?
bartek
www.bartekmedia.com
9mm FR wires, hawker batt, FAL fan wired to a switch , 3pc UDP, 65mm tb, ported 00, venom cam grs, COMP 2's, 421 rh, 2.5 in fp, 2.5 in borla, mcleod race clutch/flywheel, eagle rods, JE 10.5:1 pistons, completely balanced and blueprinted
bartlomiej is offline
Old 03-16-2004, 02:04 PM   #2
mr.squatch
mr.squatch's Avatar
Fan#: 4112
What I Drive: 02 zx3
FF Reputation: 1 mr.squatch Good Standing Member
that is strange. my belt rides right on the edge of the cam gears, flush, looks like it'll come off. it appears yours is even farther out than that. weird. did you loctite your crank bolt? once I saw a guy loctite his crank bolt but it wasn't on all the way, so it stayed where it was because of the bolt, but it just wasn't on far enough. that'd cause your belt to be out too far. hmm.... lemme think on it some more.
is it rubbing on the top cover? if so, just take it off. it's a shame to cover up pretty cam gears anyways.
g
mr.squatch is offline
Old 03-16-2004, 02:11 PM   #3
bartlomiej
bartlomiej's Avatar
Fan#: 2870
I took the top cover off a long time ago.
I have never loctited the crank bolt. I really have no idea what may be causing this...
www.bartekmedia.com
Old 03-16-2004, 02:28 PM   #4
RPIJG
Mr. Wizard
RPIJG's Avatar
Fan#: 18
What I Drive: '02 Focus SE 4DR Zetec
FF Reputation: 1 RPIJG Good Standing Member
looks to me like its rubbing because it is too far off the cam gears, my timing belt is flush on the gears with on overhang. It looks like its rubbing where it's overhanging. When you installed it was it set flush or did you intentionally leave the overhang?
Bye Bye Focus
Hello MkV GTI w/DSG!
RPIJG is offline
Old 03-16-2004, 02:34 PM   #5
guerro
guerro's Avatar
Fan#: 339
What I Drive: 2013 Focus ST Oxford White
FF Reputation: 1 guerro Good Standing Member
I would definitely check your crank pulley.
Annoy a Liberal: Work hard, succeed, be happy.
guerro is offline
Old 03-16-2004, 02:37 PM   #6
bartlomiej
bartlomiej's Avatar
Fan#: 2870
I made sure when i installed it to have the belt perfectly center on the cam gears.
Guerro: Why would it be the crank pulley? The crank pulley was on the old engine and never posed a problem like this.
thanks for the replies!
www.bartekmedia.com
Old 03-16-2004, 03:16 PM   #7
EuroZX3
EuroZX3's Avatar
Fan#: 39
What I Drive: 05 Black Scion TC
FF Reputation: 1 EuroZX3 Good Standing Member
Buy-Sell-Trade Rating: (7)
id try gettin a new belt and rehangin it, maybe that one ended up stretchin a tiny bit somehow and always moves itself offset. keep us posted tho eh
Originally posted by darkpuppet
needs more cowbell
EuroZX3 is offline
Old 03-16-2004, 03:31 PM   #8
bartlomiej
bartlomiej's Avatar
Fan#: 2870
this is the second belt. i thought it may have been that, but i quickly learned otherwise.
www.bartekmedia.com
Old 03-16-2004, 06:00 PM   #9
Shmee
Junior Enthusiast
Fan#: 3792
What I Drive: 2000 Ford Focus
FF Reputation: 1 Shmee Good Standing Member
well if there are any signs of wear on the belt you are supposed to change it immediately anyways.
did you remember to put the guide shim back on the crank gear?
i have seen it on other cars taht if you leave that shim off the belt can walk of the gears and start rubbing on the cover.
Shmee is offline
Old 03-16-2004, 06:10 PM   #10
bartlomiej
bartlomiej's Avatar
Fan#: 2870
if by this you mean the plastic cover behind the crank pulley, yes.
www.bartekmedia.com
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
"How To" VCT Trouble-TSB 03-6-07 Springbuck SVT Performance (2002-2004) 26 08-18-2009 02:21 PM
SPI timing belt advise. Ispi SPI Performance (2000-2004) 9 09-06-2007 06:34 PM
Timing Belt - what parts to replace? erittalf SVT Performance (2002-2004) 13 07-06-2007 11:10 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
