"How To" CFM Silicone Couplers for SVTF Intake Manifold - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-04-2006, 01:35 PM   #1
mike 1
Fan#: 19248
What I Drive: 2006 Subaru WRX STi
FF Reputation: 1 mike 1 Good Standing Member
Buy-Sell-Trade Rating: (8)
CFM Silicon Couplers for SVTF Intake Manifold
Just thought I'd do a short-term testing (15 miles) write up on the CFM Silicon Couplers for the SVTF Intake manifold. If you dont know what I'm talking about; http://focus.c-f-m.com/index.asp?Pag...OD&ProdID=1108 click the link!
Ok, first, you will want to oder the couplers in either red, blue or black. I chose red beause thats just my accent color.
Tools you'll need to do it - 1/4 drive ratchet, 8mm socket, 1/4" socket, flat head screwdriver, pliers or wire cutters (dikes).
Prepare for the removal/ install:
Unclip the injector harness fromt he injecotrs and push it out of the way. Next, unclip the Fuel Pressure regulator/ sensor from the end of the rail and remove the vac. line from the sensor. Now, remove the two 8mm bolts securing the fuel rail, rock the rail back and forth til the injectors come loose, unplug the vac. line from the center/ bottom of the rail and swing the rail out of the way (I set the rail on my strut bar, worked perfect!). You are ready to begin!
Now its time to remove your rubber boots. If you have an 02 you definitely have those stupid 'clip' clamps. I know my friends 04 has the screw type clamps...those you just simply unscrew. To remove the clip clamps, just grab the head where it hooks and take pliers (I used cutters since it has a better head), grab the hook part (its at the 12 o'clock position) and just give it a twist. Then, just pull the whole clamp out. Repeat 7 more times. Now, once the clamps are off, grab the throttle body and push towards the firewall. This is just to separate the two halves. You dont have to make a lot of room, just enough to get the boots out. I grabbed a side and pulled it out from the sides. The way they are shaped makes it tough to pull straight up. Reapeat until all your boots are off.
Now to install the new couplers...what I did was took all my 8 clamps and pre tightened them. Its a lot easier this way since you wont have to hold while you screw the clamps a lot. Put two clamps on the MOTOR side of the intake manifold on each runner. Now, take a coupler and put it on the THROTTLE BODY side of the manifold (trust me!) Get the boot into position and then take one of the clamps and slide it into place and clamp it down snug. Do that on each runner. Now the tricky part (a second set of hands comes in here) grab the throttle body and alternator side of the manifold and lift and slip the assembly into the motor side of the manifold. 1 and 2 will go on easy, but 3 and 4 will fold under. Take a flat head it lift the folded part over the runner (your friend comes in here). Once you do that, pull the TB side into place as hard as possible and have your friend torque the MOTOR side clamps. Do 1 and 4 first. once you do that, do 2 and 3. Thats it. Go over and retorque the clamps with a socket/ ratchet. Reinstall your vac lines, fuel rail and injector harness and go for a drive!
Total time is about 15-20 minutes.
I would rate this on a difficulty scale of 2 out of 5. Its something anyone that can do basic car stuff can handle. The only 'scary' part, if you dont have a second person to help and you can get those couplers to unfold no matter what you try, you are stuck. Just be prepared to have a buddy available.
Now I can hold 10psi with out the boost leaking out of the rubber couplers.
For $20 + Shipping this is something we should ALL do! For turbos its a must, and for the NA guys, hey, it looks cool. When I get my camera back from my wife tonight, I'll take a few installed pictures!
____________
Mike S.
mike 1 is offline
Old 07-04-2006, 02:00 PM   #2
OrangeSVTguy
Get Squashed
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '04 Comp. Orange SVT 3dr.
Points 73,307, Level 100
Points: 73,307, Level: 100 Points: 73,307, Level: 100 Points: 73,307, Level: 100
Level Up 0% Completed
FF Reputation: 44 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (16)
$20 bucks and makes my car looks cool. i'm sold. if only it came in orange then i'd be a sucker for it lol.
great write up
if this generates enough interest, it could go up on the how-to list.
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
OrangeSVTguy is offline
Old 07-04-2006, 02:05 PM   #3
mike 1
Fan#: 19248
Well, the red does have an orange tint to it. Trust me, if you want to color match, youd be fine with red...from what you see of it, theyd never even know it wasnt orange!
____________
Mike S.
mike 1 is offline
Old 07-04-2006, 04:23 PM   #4
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Yeah, put these on last week by myself. Not hard to do at all. Accent the engine bay nicely. I think my old couplers were leaking because they were all covered in dirt and oil, especially the one near the throttle body. When I pulled the couplers off a little oil was under the clamps on the manifold. $20 can't go wrong.
I now drive a Japanese Ford.
macdiesel is offline
Old 07-05-2006, 01:05 PM   #5
Artood2s
Artood2s's Avatar
Fan#: 28626
What I Drive: Silver Bullet (In slow-mo)
FF Reputation: 1 Artood2s Good Standing Member
PICS PICS PICS
"Do or do not... there is no try." - Jedi Master Yoda
Artood2s is offline
Old 07-05-2006, 04:40 PM   #6
mike 1
Fan#: 19248
There's not much to see, but I do have the pics loaded into my camera, just need to host em and post em!
____________
Mike S.
mike 1 is offline
Old 07-05-2006, 10:08 PM   #7
livinlots26
Fan#: 34709
What I Drive: 02 sonic blue svt focus
FF Reputation: 1 livinlots26 Good Standing Member
i did the same thing when i had my head work done i used blue silicon hose from a local truck dealer it only cost me 8 bucks! looks awsome and i think they will last longer than the rubber stock ones
fidanza flywheel livewires screamin demon ignition focus central pullys clutchmasters stage 4 clutch magnaflow cat back CFm throttlebody focus central off road pipe garrett gt28r turbo kit adjustable cam gears a complete motor built by TURBO TOM
livinlots26 is offline
Old 07-07-2006, 06:54 PM   #8
Jmustang68
Jmustang68's Avatar
Fan#: 14878
What I Drive: 2004 SVTF ZX5
FF Reputation: 1 Jmustang68 Good Standing Member
I would like to see pics so I understand where they go... lol... these connecto the injectors to the fuel rail?? They look like intake pipe couplers from the picture on CFM.
2004 Sonic Blue SVT Focus ZX5
AEM CAI Intake, Predator and Tom's Tune, Ford Racing Short Shifter, Corbeau Blue 4PT Harnesses for Track Use
SVT Squad Car #112
Jmustang68 is offline
Old 07-07-2006, 07:53 PM   #9
mike 1
Fan#: 19248
Yeah, they connect the two halves of the intake manifold...
They have nothing to do with injectors or the fuel rail...those parts need to be pushed out of the way for clear access to the couplers...
____________
Mike S.
mike 1 is offline
Old 07-07-2006, 08:37 PM   #10
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Just pop open the hood and look behind the head, you'll see where they go. I'd like to see pics with them in red though, as I've already ordered them.
CaysE is offline
