Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 03-13-2004, 03:54 PM   #1
breakdancein
Fan#: 78
What I Drive: 03 svtf
FF Reputation: 1 breakdancein Good Standing Member
Front strut tower bar install with aem cai SUCCES!!!!!!!
i did it!! i installed the focus central front strut tower brace with my aem cai. i had to get a little creative but ill explain how i did ti so u guys who want one can do it also
1. jack up car so tires just barely lift off the ground this equalizes the struts.
2. remove fuse box cover ( the 1/4 of an inch that the lip takes up will make u not be bale to install the strut bar.
3. lossen up hose clamp holding cai tube into connector to throttle body and slide the tube out fromt he connectore slightly ( the cai tube should be about onyl 1/4 inch into the sleeve that conencts to the throttle body rather than the normal 1/2 inch or so. this wont affect cai at all and again that 1/4 of an inch will be crucial.
4. starting with the drivers side put the brace onto the bolts then do same with passenger side ( the strust brace bar should be just touching your cai).
5. tighten bar down to 18lb/ft like directed in instructions and put fuse box cover back on. it might take a little elbow greese but ti will fit
ok here comes the problem. since the strut tower brace is barely touchign the cai when the car take a turn the bar will rub on the cai also at high revs the bar will rub against the cai. after time that rubbign will wear down the metal on both things and also makes a slight rattle.
here is how u fix that. get a rubber hose about 5-6 inches in length( u want about an inch of extra room on both sides form were the cai comes in contact with the strut bar) as thin as possible and big enough aroud to wrap most of the way around the strut bar. splice the hose open so u can wrap it around the strut bar. slide the hose in between the bar and cai( might need a little spit as lube to get it between) then wrap it around the strut bar. secure on both sides with hose clamps as tight as possible.
whalla u have a frotn strut tower bar with a aem cai. i tested the rubber peice to see if it iwll move under hard cornering and drivign and it wont budge. i have an auto-x tommmorow so that will be the true test but i knwo ti will be fine. the thing u can only tell with time is if that rubber will wear through. ill let u know if i see any change as i drive it. hope this helped.
breakdancein is offline
Fan#: 1
Old 03-13-2004, 06:35 PM   #2
SLIP STREAM SVT
Fan#: 1693
What I Drive: 2002 Pitch Black Focus SVT
FF Reputation: 1 SLIP STREAM SVT Good Standing Member
do you have any pic's?
2002 SVT Focus
#2760 of 4788
Born: 6/13/2002 in Hermosillo Assembly Plant
Current Implants: Grounding Wires, AEM Cold Air Intake, Ford Racing Strut Bar, Smoked Nite Shade Side Markers, Home Made Shorty Antenna, Steeda Tri-Ax Short Shifter, VF Engine Mounts, SCT Xcalibrator 2 (tune by Wayne @ Hypnotic Illusions ), Nx 50 Shot Wet Kit
SLIP STREAM SVT is offline
Old 03-13-2004, 09:13 PM   #3
breakdancein
Fan#: 78
yes i took a bunch but the cable to download them onto my comp from digital camera hasent gotten in when it does ill post them
Old 03-13-2004, 09:18 PM   #4
itsmemorphious
itsmemorphious's Avatar
Fan#: 3318
What I Drive: 2006 Super Crew
FF Reputation: 1 itsmemorphious Good Standing Member
Spit and heater hose probably garden hose and hose claps Sounds a little jury-rigged to me ( not clean lookin at all) Hope i'm wrong, can't wait to see pics.
My 2006 XLT F-150 Super Crew
itsmemorphious is offline
Old 03-14-2004, 05:24 AM   #5
breakdancein
Fan#: 78
lol its not garden hose its a black peice of hosing. u can always paint the parts before instilation before putting them on to help with looks. the most important thing for me was soemthign that works and it does exactly that
Old 03-14-2004, 08:12 AM   #6
itsmemorphious
Fan#: 3318
Hey man what ever works. Can't wait to see pics, that will be my setup to
Old 03-14-2004, 09:41 PM   #7
SVT RACER
Fan#: 2773
What I Drive: 2003 Pitch Black SVT ZX5
FF Reputation: 1 SVT RACER Good Standing Member
I just tried putting my strut bar on and did not have very good luck, I thought it matched up perfectly before but when I went to throw it on there it doesnt want to go. It seems as if the bottome screw hole on the driver side is not aligning properly. I even tried jacking it up from either side. Is it necessary to take the AEM off? It didnt seem like that was going to get in the way unless you had to bring the bar in from a lower angle. So you are suggesting putting the driver side on first with the tb slid out of the way correct?
AEM CAI, Plasma Booster (Ignition Solutions), Sway, TB,DENSO Iradium,Steeda Tri-Ax, Neons
SVT RACER is offline
Old 03-14-2004, 09:43 PM   #8
SVT RACER
Fan#: 2773
Do you have to lift the car from the middle of the front or just one side?
Maybe that s where I went wrong?! I only did one side at a time.
Old 03-15-2004, 09:34 AM   #9
breakdancein
Fan#: 78
u definatly need to do both sides at the same time. by lifting both sides to the same height that makes sure the car is level. if u leave it sitting on the ground or only jack it one side at a time the strits will be uneven and no way u can install it. anymore questions let me know
Old 03-15-2004, 09:38 AM   #10
Zarelli6
Zarelli6's Avatar
Fan#: 411
What I Drive: '89 Volvo 744Ti
FF Reputation: 1 Zarelli6 Good Standing Member
sorry dude, but you can install it on the ground, it is just recommended to jack it up for ease of installation. then again i did it with a fs strut bar so it was a little better quality and fit.
-Chris
Zarelli6 is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 10:54 PM
Strut tower brace stress bar microtonal Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 14 11-17-2008 10:48 PM
AEM intake/ FS strut bar Bert SVT Performance (2002-2004) 6 08-01-2004 03:15 PM
Front Strut Tower Brace/Bar Blues gibsontaylor Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 4 11-10-2003 10:45 AM
