water pump problems - Focus Fanatics
Old 06-25-2006, 10:44 AM   #1
officefocus
Fan#: 24971
What I Drive: 2000 Bright Red ZTS
FF Reputation: 1 officefocus Good Standing Member
Talking water pump problems
My problem was that I was losing coolant quick and so I proceeded to replace the thermostat. That didn't work so I change some of the hoses and tat wasn't it either. Now I am attempting to change the water pump but I have no idea how. I already bought the water pump and ready to do it I just need some help. Can someone direct me to a page where it can guide me?
officefocus is offline
Old 06-25-2006, 10:54 AM   #2
ztecpower
ztecpower's Avatar
Fan#: 20083
What I Drive: 2002 Infra-red Ford Focus ZTS-S2
FF Reputation: 5 ztecpower Good Standing Member
go here = http://www.focusfanatics.com/forum/s...threadid=62696
THat's the timing how-to I submitted, Thwater pump is easy to remove once you do the above procedure in the link, Remove the water pump pulley by removing the 3 bolts holding it on, then remove timing components to gain acess to the Water pump, which is held in by 4 bolts and a rubber gasket/seal. If your replacing your water pump then you should do a timing belt as a precaution. And if your loosing coolant check the tank, sometimes they crack and only release coolant when they get hot (expand and release coolant in small amounts)
Let me know if you need anything else.
Troy.
You know... That guy.
SR# eleventybillion
ztecpower is offline
