5th and reverse gear gone! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-21-2006, 12:00 PM   #1
Les Paul
Fan#: 24908
What I Drive: 2.0 1999 Ghia
FF Reputation: 1 Les Paul Good Standing Member
UK Focus 99 2.0 5 door and driving home today had a lot of trouble getting 5th gear and when I got home found I cannot get reverse at all.
All other gears are ok, no clonking or strange noises....is the box cattled or is it something simpler? Any ideas anyone?
Shut up and play yer guitar...
Les Paul is offline
Old 06-21-2006, 12:01 PM   #2
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
could it be the shifter cables could be messed up
nov173 is offline
Old 06-21-2006, 12:05 PM   #3
madmark10
madmark10's Avatar
Fan#: 32652
What I Drive: 2007 Chevrolet Cobalt
FF Reputation: 1 madmark10 Good Standing Member
syncronizers going out?
madmark10 is offline
Old 06-21-2006, 01:42 PM   #4
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
FTF (First Things First).
Check the linkage and shifting cables.
P.S. I am not familiar with the Focus manual gearbox, but I greatly doubt that Reverse has a synchronizer.
penguin is offline
Old 06-22-2006, 03:45 AM   #5
Les Paul
Fan#: 24908
Thanks for replies, car gone into Fords today will post later what it was. Seems a common problem because they had a Galaxy and a Fiesta with same problems.
Les Paul is offline
Old 06-22-2006, 11:29 AM   #6
Les Paul
Fan#: 24908
Problem fixed today it was 5th/reverse spring lever broken so they have removed it, and it now works ok. Cost 131 They say it should be OK now, however if the problem comes back it will need a new housing which is 320 plus VAT plus labour.
Thanks for replies and help.
Les Paul is offline
Old 06-22-2006, 11:57 AM   #7
jaimz
my car breaks!
jaimz's Avatar
Fan#: 23734
What I Drive: 02 silver ZX3
Points 2,595, Level 30
Points: 2,595, Level: 30 Points: 2,595, Level: 30 Points: 2,595, Level: 30
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
FF Reputation: 9 jaimz Good Standing Member
Buy-Sell-Trade Rating: (8)
if the problem comes back that means they didn't really fix it and you shouldn't have to pay for it
jaimz is offline
Old 06-23-2006, 11:50 PM   #8
UnderEstimated
Fan#: 34085
What I Drive: 2013 Ford Focus SE Sedan
FF Reputation: 1 UnderEstimated Good Standing Member
Sounds like a temporary "fix" to me.
.::2013 Ford Focus SE (Sport Package)
.::2014 BMW 335i M-Sport
UnderEstimated is offline
Old 06-24-2006, 08:59 AM   #9
Les Paul
Fan#: 24908
Well the question has to be that the box works fine without it so what is the original part doing in there if it is not actually used? Unless it is used for a different version of gearbox. The alternative is wait a week for a new housing, pay 320 plus VAT plus labour which amounts to 600 plus.
Worth a try for 131 dont you think?
Les Paul is offline
Old 06-24-2006, 02:37 PM   #10
UnderEstimated
Fan#: 34085
If the 5th gear/reverse spring lever broke, not allowing you to shift into 5th or reverse, then the spring lost its compression. Normally when they break, you're either stuck in 5th or in reverse and your reverse lights will stay on.
Anyway, the point of the spring is to make it harder to accidently shift into 5th or reverse. Now with the spring gone, it is more possible for the shifter to slip into reverse as you shift into 3rd or 4th. But if you know where you're gears are, you'll be fine.
But honestly, they probably should have replaced the spring itself. It's not a common problem nowadays and you'd think a small spring wouldn't be more than a few bucks.
