Go Back   Focus Fanatics > Ford Focus Tech Discussions > SPI Performance (2000-2004)
Old 03-11-2004, 12:49 AM   #1
ibspanky1980
Fan#: 1046
What I Drive: 2000 Ford Focus Se
FF Reputation: 1 ibspanky1980 Good Standing Member
Question fuel filter
Does anyone know the location of the fuel filter, just got my fuel pump replaced through the recall and figure that I should replace the filter as well. Ford wanted to charge to much, so I bought the fuel filter my self and will change it. But don't know where it is?
Please Help!!
ibspanky1980
Eibach lowering springs, 17" ADR Demonya (blk&slvr), 205/40/17 Toyo FZ-4
Alpine 7" Screen in dash, Alpine DVD in glovebox, Alpine 7" screen in each headrest, 2 JL W7 12's (Ported), JL 1000.1 amps, 1 JL 500.4 for the componets, Alpine componet set
ibspanky1980 is offline
Fan#: 1
Old 03-11-2004, 07:51 PM   #2
waterboy
Guest
Fan#: 2258
What I Drive: 2k SPI-T, with Lentech automatic stuff on it
FF Reputation: 1 waterboy Good Standing Member
Buy-Sell-Trade Rating: (4)
Passenger side in front of the rear wheel and 1/2 way between the wheel and center of the car towards the driver wheel. It'll take a small flat blade screwdriver to remove the clips. Throw them away and install the ones that came with the filter. I think it's a 7mm bolt that holds the clamp and filter to the car.
Make sure you've relieved the fuel pressure before you take anything loose. Have some rags handy, as the filter will have some fuel still in it.
waterboy is offline
Old 03-11-2004, 09:52 PM   #3
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: Molly teh SPI - 03 LX
FF Reputation: 3 crazy_urn Good Standing Member
thank you for the info waterboy
and thanks for asking the question ibspanky. i was also wondering.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 03-16-2004, 07:00 AM   #4
FocusOnMySpi
Fan#: 4481
What I Drive: Light Sapp Blue 00 SPI SE and Proud
FF Reputation: 1 FocusOnMySpi Good Standing Member
Is any old Filter good to through in there or Should you go get one from like EscortFocus.com???
FocusOnMySpi is offline
Old 03-16-2004, 06:27 PM   #5
waterboy
Guest
Fan#: 2258
I doubt the one on EFP is anything special.
Jim
waterboy is offline
Old 03-17-2004, 02:35 PM   #6
FocusOnMySpi
Fan#: 4481
Well I just got my Fuel Pump Replaced to the new one for Recall - So im gonna switch them up! How do I relieve the Pressure before installation or uninstallation?
Old 03-17-2004, 07:31 PM   #7
waterboy
Guest
Fan#: 2258
Pull the fuse for the fuel pump. Start the car and run it until it dies. Crank it a few more times. Should be good to go then.
Make sure you have some rags handy to sop up the spilled fuel. The lines and filter will still have some fuel in them.
Jim
waterboy is offline
Old 03-19-2004, 10:23 PM   #8
FocusOnMySpi
Fan#: 4481
Where is the Fuse? Under the Hood?
Old 03-19-2004, 10:25 PM   #9
FocusOnMySpi
Fan#: 4481
Also, Jim Quick Question! My SparkPlug wires from FS are burnt a little bit from my headers through the Protective jacket- Could that cause my Car to stall or start to stall??? Thanks Man!
Old 03-20-2004, 10:04 AM   #10
waterboy
Guest
Fan#: 2258
Sure would make it run funny if they're shorting out on the header. Prop your hood, and splash some water on the wires, if you hear the zap, you've got issues. Randy won't warranty burnt wires, so if you have to buy a set go with the Magnecores.
For the fuse, it's under the hood, #12.
waterboy is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 09:59 AM
Fuel filter retaining clip 05 focus blackheart4355 General Technical Chat 4 03-14-2008 05:42 AM
that damn fuel filter! Clegg SVT Performance (2002-2004) 75 07-15-2006 01:46 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 10:57 AM
yep another mileage thread! teddyrob DURATEC Performance (2003-2011) 23 04-22-2004 08:24 PM
