Cluth Pedal Problem????? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-31-2006, 06:53 PM   #1
Artood2s
Artood2s's Avatar
Fan#: 28626
What I Drive: Silver Bullet (In slow-mo)
FF Reputation: 1 Artood2s Good Standing Member
Question Cluth Pedal Problem?????
Here is the story. On my way to work I stop at a red light, it turns green, I push the clutch pedal in and CRACK!!! I let off the pedal immediately and check for damage. The only thing on my mind was "(insert 4 letter word here), i broke the clutch pedal." At first glance, nothing seems amiss so I since I was only one block away from my job, I drove it gently to the parking lot.
When I got out of work, I looked at the pedals and saw nothing broken. I turn on the car and notice that the clutch pedal seems much shorter than before. I take it for a gentle test drive and gear changes are perfectly normal, the clutch doesn't seem to be slipping and no funny smells are coming from the engine compartment (I though maybe the clutch would only be partly engaged since the pedal didn't go up as far as it used to). Actually, since the pedal travel is shorter, I am able to shift faster now
My question is, what happened???? Will this cause premature wear on the clutch??
The best way that I can describe it is that before the pedal would only move in one direction DOWN. Now I can pick it up ever so slightly. Can anyone else do this?????
"Do or do not... there is no try." - Jedi Master Yoda
Artood2s is offline
Old 05-31-2006, 08:50 PM   #2
George Alford
Fan#: 20443
What I Drive: 2002 silver svtf
FF Reputation: 1 George Alford Good Standing Member
Check the pin that the master cylinder push rod is attached to.On mine this pin was only spot welded an broke lose and caused the push rod to break. It cost me over 300.00 to fix.
George Alford is offline
Old 05-31-2006, 10:43 PM   #3
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,714, Level 78
Points: 14,714, Level: 78 Points: 14,714, Level: 78 Points: 14,714, Level: 78
Level Up 66% Completed
Forum Activity 14%
FF Reputation: 90 goinloco1 Excellent Standing Member
^^^^ see above. a welding shop can fix it cheap. make sure they have fire blankets, then they can weld it with no disassembly.
goinloco1 is offline
Old 06-01-2006, 11:18 AM   #4
Artood2s
Artood2s's Avatar
Fan#: 28626
I have to take a closer with a flashlight tonight, but at least from the driver's seat, it doesn't look too bad. Actually the pedal now lines up with the brake pedal perfectly.
*Warning, crappy camera phone pic*
Like I said, now there is a little play in he clutch pedal where before it was stiff. Can anyone "lift" their clutch pedal, even slightly????
Artood2s is offline
Old 06-01-2006, 11:31 AM   #5
Portuga
Portuga's Avatar
Fan#: 22452
What I Drive: 2002 Blue Focus SVT
FF Reputation: 1 Portuga Good Standing Member
I'll try to lift mine and let you know later.
SVT Squad #84
RP Engine\Trans Syntetic _ Fidanza Flywheel _ Clutchmasters FX100 _ VF Rear Engine Mount _ Hyp SRI _ Hyp 93 Oct Tune _ Grounding Kit _ Taylor 8.2mm Wires _ Autolite Double Platinums _ Clutch Sensor Mod
Portuga is offline
Old 06-02-2006, 09:47 AM   #6
Artood2s
Artood2s's Avatar
Fan#: 28626
Bump for answer. Can anyone lift their clutch pedal??? Kind of like you can lift the throttle pedal, just not as much.
Thanks
Artood2s is offline
Old 06-02-2006, 10:23 AM   #7
steviejoe
Fan#: 20868
What I Drive: 2003 Competition Orange SVT
Points 103, Level 2
Points: 103, Level: 2 Points: 103, Level: 2 Points: 103, Level: 2
Level Up 6% Completed
FF Reputation: 1 steviejoe Good Standing Member
My 2000 has a little slop in it. I can lift it up a small amount, like maybe .25". Have you looked under the dash and made sure it was the pedal return spring? I know that at one point there were some badly tempered ones floating around. I think I went through 2 or 3 before I got one that lasted.
2003 Competition Orange SVT Focus EAP
Borla Exhaust
2000 Rainforest Green ZX3 (R.I.P.) -- Never even had a chance to mod it beyond some Sachs dampners, but at least my wife is still alive.
steviejoe is online now
Old 06-03-2006, 12:33 AM   #8
S281sc
Fan#: 16895
What I Drive: 2002, Sonic blue, SVT Focus #1912
FF Reputation: 1 S281sc Good Standing Member
its the pin that is conected to the master cylinder. look were the clutch pedal is and you will see a broken pin or twisted about to brake. I know because main broke when i was driving and i nearly killed myslef. to fix it i got a screw and nut and put it were the pin was. car works like new.
2002 SVT Focus, sonic blue #1912
mods: slotted brakes, cold air intake.
" Its not about how fast you could go in a straight line, but how fast your car can handle the turns"
S281sc is offline
Old 06-03-2006, 01:28 AM   #9
VAfromMN
Fan#: 20592
What I Drive: '13 Focus ST & '04 Focus SVT
Points 1,024, Level 17
Points: 1,024, Level: 17 Points: 1,024, Level: 17 Points: 1,024, Level: 17
Level Up 24% Completed
FF Reputation: 9 VAfromMN Good Standing Member
Also a possibility, if you have cruise control, is the switch that kicks it out of cruise when you push in the clutch. Wouldn't be nice to have that mill keep revving unexpectedly!
VAfromMN is offline
Old 06-03-2006, 02:21 AM   #10
cbo_and21
Fan#: 23405
What I Drive: '02 CD Silver SVT Focus
FF Reputation: 1 cbo_and21 Good Standing Member
This EXACT same thing happened to me. Same circumstances...everything.
It is the clutch return spring that snapped. Dealer fixed mine for like $50.
The pedal still feels normal because (so I am told) the pressure in the clutch cylinder is sufficient to push the pedal back to (almost) the normal position.
No worries...mine was fixed within a day. I recently got a copy of the service history of my car and this happened to the previous owner, also.
Situations like this are when FF comes in handy!
cbo_and21 is offline
