ZX3 Stock Clutch Life With Mods - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-29-2006, 12:05 PM   #1
spins
Fan#: 30663
What I Drive: 02 Blk Focus ZX3
FF Reputation: 1 spins Good Standing Member
Buy-Sell-Trade Rating: (4)
Will a stock ZX3 clutch handle all NA boltons? I have the basic's now with no problems. My car is a 2002 with 58k miles.
I know reving it high and slipping it from the line will kill or shorten the life of any clutch. I normally pull out easy and if I'm feeling it and the time is right. I hammer it from there and roll through the gears. I never speed shift.
spins is offline
Old 05-29-2006, 07:25 PM   #2
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
well don't quote me but i think i remember hearing that the stock clutch can handle upwards of around 160 hp. but after a while of gettin on the factory clutch it will wear out a lot quicker than an aftermarket clutch. that is a very expensive project if you burn it. if you know u are going to go na and want more power, why not start from the ground up and assure that your car can actually put that power to the ground instead of revvin the tranny and motor out. my clutch is feelin like its wearin on me, i plan on getting a spec stage 2 clutch and fidanze lightweight flywheel, i just need to find a way to install them. i don't really wanna pay a lot for it.
nov173 is offline
Old 05-29-2006, 09:24 PM   #3
spins
Fan#: 30663
I have good tires now and the clutch is fine. I would like a new set of light weight wheels but that will have to wait. I won't do a light weight flywheel. I had one on my turbo miata. It sucks for city driving. Later if I need a clutch I would have the flywheel resurfaced maybe loose like 1lb. I've assisted on two miata clutch installs. Never did a front wheel puller. Motor mounts may be needed later. A LSD would be nice.
Focus Sport Header/Flex,Exhaust H/F Cat. SVT Suspension, Powerworks
spins is offline
Old 05-29-2006, 09:44 PM   #4
fokuzx3
teh tranny killer
fokuzx3's Avatar
Fan#: 15685
What I Drive: r.i.p. liquid grey zx3....now 300zx
FF Reputation: 1 fokuzx3 Good Standing Member
^ with your mods i see no realy need for an lsd unless your a diehard autox dude...and as for the clutch, ive seen more of a problem with the svt clutches than with the zx3 clutches, mine has NEVER slipped and im always bangin the crap outa it (60k miles) the one thing i have had mess up on me is the flywheel, when they replaced it they said quote "more hot spots on it than the sun" so, my dunno
zetec crew #23
zetec R.I.P. best standing 1/4 time= 15.260 @88.08 mph (2.275 60)
Originally Posted by warneej View Post
it takes a minute to get used to, kinda like shaving your balls.. haha
fokuzx3 is offline
Old 05-29-2006, 11:56 PM   #5
spins
Fan#: 30663
Well my last front puller with some balls was a 95 hatch with a JDM GSR. I could launch it pretty well and it had top end power. Before that was my spec V. She had TORQUE! She launched well and would chirp in 3rd gear. My focus seems to roast the tires easily pulling out and taking corners ends up in my user name. I'm learning better control through.
Can you have a stock ZX3 flywheel turned? I've done this on a miata. Took off 1 lb. not much I know. But I hate lightened flywheels.
spins is offline
Old 05-29-2006, 11:58 PM   #6
fokuzx3
teh tranny killer
fokuzx3's Avatar
Fan#: 15685
^ yea its called the ford racing flywheel, but just a reworked stock flywheel but weaker....come to think of it, im not sure if they 'turned' it or replaced it, im sure you can do that though
zetec crew #23
fokuzx3 is offline
Old 06-02-2006, 03:07 PM   #7
sc0tty8
Fan#: 27536
What I Drive: 2k3 Pitch Black ZX3
FF Reputation: 1 sc0tty8 Good Standing Member
I am running stock clutch with 45k on the clock and some work done.
sc0tty8 is offline
Old 06-02-2006, 06:28 PM   #8
venomfocus
venomfocus's Avatar
Fan#: 907
What I Drive: A fast 2001 Pitch Black ZX3
FF Reputation: 1 venomfocus Good Standing Member
you will be fine with the stock clutch....i have every mod you can think of...with 10.5:1 compression...with a lsd and 8lbs flywheel, i put alot of track time with hard launches...even in the street....stock clutch is rated at 200hp
Doing Operation Restoring Hope to my Focus. Trying to get it back on the road around the same power level.
venomfocus is offline
Old 06-02-2006, 07:34 PM   #9
spins
Fan#: 30663
Cool! Thanks
spins is offline
Old 06-02-2006, 11:28 PM   #10
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Yes, the stock clutch will hold up pretty well. A clutch is one of those classic things. Don't fix it if she ain't broke.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
