Old 05-12-2006, 12:47 PM   #1
snowsk8erjg
Fan#: 24392
What I Drive: 2000 Green SE
FF Reputation: 1 snowsk8erjg Good Standing Member
Angry Rough Idle, Loss of power at high RPMs
Here's the deal. I have a 2000 SE and it used to run nice and fast. Recently, it's been running like crap. It has an extremely rough idle and has no power in the power band. It loses all it has at 4000 RPMs. I used to get 35-36 ish mph out of first gear, now I barely get 20mph. I started out with easy stuff. I got a new filter for my CAI, new plug wires, new plugs, changed my fuel filter, and PCV valve. Still ran like shit. I thought the problem might be the fuel pump. I heard about the recall, so I brought it up to a Dealership and they ran diagnostics. They told me I had a dead fuel injector, and that my fuel pressure was fine up until the injectors. So...I got new injectors in it today. I was psyched, figuring I had fixed the problem. I started it up, and it still ran like crap. The only difference is a slight improvement in fuel efficiency. I still have a rough idle, no power over 4000 RPMs, and I'm running out of ideas. CEL is on and shows code PO171 - System too lean. I tested out my EGR and DPFE and they are fine. Anybody have a clue what could be my problem?? I'm running out of ideas.
snowsk8erjg is offline
Fan#: 1
Old 05-12-2006, 12:58 PM   #2
viney266
Moderator
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
FF Reputation: 112 viney266 Excellent Standing Memberviney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Sounds like it is fuel related. I would change the fuel filter and have another dealer check that fuel pump.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 05-12-2006, 02:03 PM   #3
snowsk8erjg
Fan#: 24392
I have a new fuel filter on as of a few hundred miles ago. It made no difference at all once it was on. I'd have to say it seems fuel related, since it loses power when it's revved up (when the engine is starving for fuel) and since the code says the system is too lean. Just when for a ride to test out some new plugs I just put in and it still runs like shit...
Old 05-12-2006, 02:37 PM   #4
Auto0utcast
Fan#: 10652
What I Drive: 2003 gutted zx3
FF Reputation: 1 Auto0utcast Good Standing Member
could be more than one issue... check the oxygen sensors for faulty readings... not that hard to replace.. could also be losing power/ crappy idle due to a clogged catalytic converter. check both of them out and see how that works for u
2K3 std zx3 zetec
MODS: svt header kit, RT 2.5" cat, FS flex, 2.5" trubendz Borla, FR wires, SCT chip, AEM short ram, spec stg 3, vf dogbone, h&r springs, brembo x-drilled and slotted rotors, hawk hp+ pads, oh and shes on a diet...
117hp 134tq - dynapack dyno www.synapsemotorsport.com
15.567 @ 86.51 Lebanon Valley Dragway
Auto0utcast is offline
Old 05-12-2006, 07:41 PM   #5
Scott_SVT
Scott_SVT's Avatar
Fan#: 21836
What I Drive: 2002 Pitch Black w/Blue int SVT
FF Reputation: 4 Scott_SVT Good Standing Member
look for vacuum leak, PCV hose is a likely culprit, but also check the manifold boots, brake booster hose, etc.. it would have to be a large leak to affect the idle
Also, clean the Mass Airflow sensor real quick, a dirty MAF can cause all sorts of problems.
13.746 @ 100.52mph
SVT SQUAD #8
Hurray!! a Squad! how umm... stupid....
Scott_SVT is offline
