Timing Question w/ Aftermarket Cams and Gears - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-09-2006, 10:08 PM   #1
craze173
Fan#: 33583
What I Drive: 2001 Ford Focus ZX3 S2
FF Reputation: 1 craze173 Good Standing Member
Question Timing Question w/ Aftermarket Cams and Gears
On aftermarket cams there is a metal piece that sticks off of the camshaft and on aftermarket cam gears there are two holes where the metal piece can fit into. When you tension up the timing belt after the install you are suppost to leave the cam gear bolts loose so that the timing belt can tension up without moving the cams out of time. If this is done the gears will move a little to make up the space to allow the belt to tension, my question is how do you line up the cams metal piece and one of the two holes in the cam gears up once the tension has been applied.
I tried this once last weekend but left the cams and cam gears installed with each other during the install (timing belt tensioning) and that caused my intake cam to retard itself and because of that my car is now out of time. So, if you have any input or have installed cams and gears before I would appriciate your input, thanks.
craze173 is offline
Old 05-10-2006, 09:01 PM   #2
craze173
Fan#: 33583
If any of you have any experience with this your input would be appreciated, thanks.
craze173 is offline
Old 05-11-2006, 09:41 PM   #3
craze173
Fan#: 33583
........I guess no input. I will be redoing this on Saturday, so if anyone has any helpful info prior to that please let me know.
craze173 is offline
Old 05-12-2006, 01:05 AM   #4
zx3_boy
Fan#: 25977
What I Drive: 2000 Blue ZX3
FF Reputation: 5 zx3_boy Good Standing Member
maybe this will help
http://www.focushacks.com/index.php?modid=17
You know you’re into cars too much when your girlfriend comes over to show you how she died her hair and you say “you should have left it stock”
zx3_boy is offline
Old 05-12-2006, 01:42 AM   #5
BlackNRed01
Boost?
BlackNRed01's Avatar
Fan#: 21668
What I Drive: 2001 ZX3 MTX
FF Reputation: 4 BlackNRed01 Good Standing Member
Buy-Sell-Trade Rating: (8)
if you use the ford racing cam timing tool and dont remove it until after the belt is tightened there shouldnt be an issue.
2001 Infra-Red ZX3
Boosted & Back: Parting Out
BlackNRed01 is offline
Old 05-12-2006, 10:45 PM   #6
craze173
Fan#: 33583
With my question is though is on the new cams and gears they each have a part on them that connects to the other for stronger contact. The cams have a machined cylinder shape of metal that comes off its end and the cam gears have two holes. The metal on the cams fit into one of the two holes that are on the cam gears. When the cam gears are bolted to the cams this forms stronger contact keeping the cams from being able to move out of timing.
My question is when I tension up the timing belt the intake cam moves (retards) itself a few degrees. In the directions for the installation it says to leave the cam gear bolts loose allowing the gears to move with the tension instead of the cams moving (like how mine did). So, I was wondering since the cam has to fit into one of the two holes on the gears, how will I be able to get them lined up after I tension the timing belt? Will it just be trial and error or is there a quick accurate way to do this?
Let me know if this is any clearer or not. Thanks again for your responses.
craze173 is offline
