Terrible 1/4 mile times in my SVT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-06-2006, 05:44 PM   #1
Silver Cosworth
Fan#: 31660
What I Drive: 07 Pitch Black ZX3 Duratec 5spd
FF Reputation: 1 Silver Cosworth Good Standing Member
I took my focus to the track today for the first time, and needless to say I was pretty disappointed in it. I had traction control switched off and it just bogged down terribly at launch.... Is their a trick or something to get around this?, I had no wheel spin either time even though I let off the clutch at just under 3000rpms. Can you guys give me some pointers for next time, i need it, lol.
EDIT: I'm the 118 car with the 17s 1/4 mile.
Silver Cosworth is offline
Old 05-06-2006, 06:07 PM   #2
2.0TooSlow
Fan#: 27765
What I Drive: 02 SVT
FF Reputation: 1 2.0TooSlow Good Standing Member
Worst 60' EVER.
Launch upwards of 5000 and feather the clutch out.
2.0TooSlow is offline
Old 05-06-2006, 06:35 PM   #3
svtfocus_john
Fan#: 33020
What I Drive: SVT focus
FF Reputation: 1 svtfocus_john Good Standing Member
These cars take a lot of getting used to. Depending upon what type of mods you have will determine where you should launch from. I have a short ram, exhaust, flash tune, UDP, a few other little things and i find that i lauch best at 3200 RPM's. If i were you i would go to some empty parking lot and just practice. I did that with my svtf and i learned how to launch my car perfectly.
SVT focus
svtfocus_john is offline
Old 05-06-2006, 06:43 PM   #4
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
the traction control will not be disabled below 20 mph (I think it's 20) even if you turn it off. you either need to get a tune which will completely disable traction control when you hit the switch, or pull your ABS fuse. that'll help your 60 ft and get rid of the bog you had. it was the traction control kicking in. don't launch much over 3000 rpms, feather the clutch, and you should start seeing some better times. just don't feather the clutch for too long...you don't want to roast the clutch
crazymechanic is offline
Old 05-06-2006, 09:21 PM   #5
Silver Cosworth
Fan#: 31660
Hey, I did a forum search and pulled that number 46 fuse, wow, it's like a completely different car. Thanks for the tips guys.
Old 05-06-2006, 09:32 PM   #6
OrangeSVTguy
Get Squashed
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '04 Comp. Orange SVT 3dr.
Points 78,690, Level 100
Points: 78,690, Level: 100 Points: 78,690, Level: 100 Points: 78,690, Level: 100
Level Up 0% Completed
FF Reputation: 44 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (17)
yes you can wire that fuse up to a switch so you can turn it on/off at will without pulling out that fuse all the time.
here's the how-to > > Clicky < <
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
OrangeSVTguy is offline
Old 05-10-2006, 01:04 AM   #7
HalfTime
HalfTime's Avatar
Fan#: 33093
What I Drive: '03 S/C SVTF, '00 SVTL
FF Reputation: 1 HalfTime Good Standing Member
Should make this a sticky somewhere...?
Tips on how to run a low 15 sec 1/4 mile in a STOCK SVTF.
1) If you have the Euro package, you have to pull the fues, #46, to turn traction control off all the way.
2) Do not heat up street tires. Street tires become almost gressy after a tipical burn out. Instead, simply "clean" them off. Stay out of the water, rev the eng to about 4k and pop the clutch. Let off the throttle after 3 or 4 revolutions of the tires.
3) Stage as far back as you can for your best E.T. Once the first light turns on, slowly roll forward and stop AS SOON AS the second stageing light turns on. If your racing heads up, Stage as far foward as you can. Roll though the lights, then back up, stop as soon as the second light tunrs on.
4) Rev to about 3700rpms. Tranny in first.
5) When the 3rd yellow turns on, pop the clutch and roll the throtle down quikly.
6) At 7100rpms power shift. Leave your foot planted to the floor, stab the clutch, all the way down, and let off as fast as you can, at the same time shifting as fast as you can, into the next gear.
7) Congradulations, with practice you can now run a low 15 sec 1/4 in your stock SVTF. Imagine what you can run modded...
Notes...
-Spinning tires is bad. However, in a stock SVTF, a little bit of wheel spin will yeild a better E.T. then trying to flote or slip the clutch for the avg driver. You need to practice this. If you spin to much, lower your launch RPMs, if you bogg AT ALL raise them. Popping the clutch should get you a mid 2.1 60ft time once you get it right. With that said, with even more practice, a slipped clutch launch should get you a low 2.0 60 ft time.
-Street tires vrs Drag Radials or slicks. Do not do a smokey burn out on street tires, that'll cause you to lose traction. You only need them cleaned of debri picked up in the parking lot or stageing lanes. Do not lower PSI to much on street tires, if I run 35psi on the street, I'll run 27psi at the track. On DR's or Slicks, the more you heat'em up, the better. The lower the psi with out slowing you down on the op end, the better. To heat'emn up right, you need to engage the parking break fully, water the front tires or drive through the wet box. Rev it up to 4k and pop the clutch. Hold your RPMS at around 5500 - 6k. Once you see smoke on both sides, count to 5. One, two, three, four, five. Then disengage your parking brake, and let off the throtle 1/2 way. Let'em hook, then depress the clutch and let off the throtle. Do not "test" the tires. Properly heated DRs or slicks have their best grip ONCE after the burn out.
-Why powershift at 7100 rpms when the red line is at 7250? Have you ever powershifted befor? If you hit the rev limiter during the shift, it will alomst defeat the pourpos of powershifting. Once you get it down, shift as high as you want with out hitting the limiter.
-All this take practice. Modify everything to yeild to your driving style and net you your fastest E.T. Things like Tire pressure, launch rpms, clutch usage, shift rpms. All this take practice to get dialed in. What I have typed up is just a good starting point for the novice.
-Good luck, be safe, and have a fuggin blast!
2000 Ford F-150 SVT Lightning @17lbs
2003 Ford Focus SVT ZX3 @18lbs
HalfTime is offline
Old 05-10-2006, 01:12 AM   #8
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
nice write up!
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 05-10-2006, 02:50 AM   #9
HalfTime
HalfTime's Avatar
Fan#: 33093
Thanks! ;)
HalfTime is offline
Old 05-10-2006, 03:15 AM   #10
Shadowrunner
Shadowrunner's Avatar
Fan#: 31568
What I Drive: 1996 Dk. Green Mustang GT Conv. MTX
FF Reputation: 4 Shadowrunner Good Standing Member
i think this would be good advice no matter what model focus you drive... putting this in my favorites
Robby
Originally Posted by Amw86 View Post
returned fiance's engagement ring, since she returned me, made nice pc funds lol
Shadowrunner is offline
