Focus Competition Tires: Info, Links, and Reviews - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2006, 04:23 PM   #11
JBrotbeck
JBrotbeck's Avatar
Fan#: 31749
What I Drive: 2000 Malibu Blue ZX3
FF Reputation: 1 JBrotbeck Good Standing Member
Falken Azenis RT-615
205/50r15
Price Paid: $78 each from Edge Racing
SCCA Solo STS class (8 runs) and limited street usage (under 300 miles)
1.5" drop (Steeda Springs) and Koni Struts, no ABS
This setup is my favorite so far of the four that I have tried. I need to play with air pressures a bit, but this past weekend I ran 38F and 35R and won STS. I don't know if it was the relatively tall sidewall or too low of a pressure, but they made ALOT of noise compared to the other size I have tried. I think from now on I am going to run 40F 37R.
EDIT: The noise went down a god bit since I wasn't over-driving and I bumped the pressures up to 40F 38R. Me likey alot.
South Carolina Region SCCA
2005-2008 STS Champion
Director-at-Large
National F&C
JBrotbeck is offline
Old 07-20-2006, 04:43 PM   #12
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Tire: Falken Azeni RT-615
Usage: SCCA Solo2 AutoCross (STS class) and Daily Drivers.
Review:
General Observations:
They Completely blow the Hankooks (RS2) out of the water!
1) The sidewall is noticeably stiffer (even with the larger size).
Turn in response is greatly improved.
2) Treadwear is much better considering I've run several events with them already.
Currently the Azenis have almost 6,000 miles on them and still show 3/16" till they hit the wear bars.
IIRC, they started at 1/4" depth to the wear bars.
On Track Notes:
(again, comparing to the Hankook RS2)
1) These tires can be pushed much harder before they reach their limits.
2) Transitions from braking to turning, then heavy accleration are much better.
I'm not seeing nearly as much slip from the tires, just mega grip.
I also noticed I can get on the gas much sooner out of a turn, with little or no tire spin.
3) I'm running 4-6psi less in the front, and still don't have any problems with rolling the sidewall.
Most events have been at 40-42psi,
though a couple times I've ran them up to 44psi on a really tight course with lots of direction changes.
Epilogue:
I'm expecting 10,000+ miles out of these tires for daily driving and AutoCross duties.
(That's about 1 set per season, as I run dedicted winter tires when the snow hits)
I've been rotating them after every event, and treadwear is extremely even between all 4 tires.
And before anyone asks due to the 225/45/17 size...
NO, they don't rub at all. (Stock springs and stock wheels)
WD40 is offline
Old 07-24-2006, 01:20 AM   #13
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,617, Level 48
Points: 5,617, Level: 48 Points: 5,617, Level: 48 Points: 5,617, Level: 48
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 36 thenorm Great Standing Member
Kuhmo Ectsa V710 (R comp)
205/50R15
usage: Solo2 auto-x H-stock.
I had high expectations of these tires and they did not disapoint. Dry grip is incredible. These will drop many many seconds off your auto-x time (compared to street tires). They were even a second or 2 faster than my old Yoko Advans A032R. The sidewalls are super stiff (i run ~30psi Front 32rear, will little to no roll over). The tires have worn noticibly after every event. I expect to get less than 20 events out of them. however the tire wear is even. The tires are built with rounded shoulders so that a little bit of wear there wont expose a cord. I have noticed that they grip well when not fully warmed up. (although on cold rainy days, it seems impossible to get any heat into them). A must for the serious autoxer.
thenorm is offline
Old 07-16-2007, 08:34 PM   #14
focusedaddiction
2focusedracing
focusedaddiction's Avatar
Fan#: 23787
What I Drive: 2003 sangria red 5spd. ZX3Turbo
Points 2,448, Level 29
Points: 2,448, Level: 29 Points: 2,448, Level: 29 Points: 2,448, Level: 29
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 4 focusedaddiction Good Standing Member
Buy-Sell-Trade Rating: (14)
Tire: Nitto NT-01
usage: scca solo 2 autoX= street modified
This is my first year( 4 months so far) on "R" compounds so I'm still adjusting to them, but WOW are these things amazing!!!
turn-in is instant ( almost tele-kenetic) & slaloms are bliss, I can hold the throttle more at higher speeds. times are dropping drasticly now
pressures are still high at 43 front 32 rear! but seem optimal for my set-up.. VERY HAPPY with these monsters!!!A+++
_/\_/\_SCCA_/\_/\_SM #74_/\_/\_BRING ON THE CONES!...zetec crew #74
ZX3..underpressure
tuning by TOM
focusedaddiction is offline
Old 09-02-2007, 11:43 PM   #15
tua03332
tua03332's Avatar
Fan#: 37555
What I Drive: 2000 Silver Sedan
FF Reputation: 1 tua03332 Good Standing Member
well it appears the azenis are dominant here. I completly agree with all the above, must better sidewalls, better grip all around, but also they recquire not heat to still have good grip. They will work great in colder weather compared to other tires in the STS classes. As for the rain, simply drop them 2psi and you wont notice a difference. I have about 7 raincrosses already.
one thing to note, the 195/?/15's for whatever reason is a slightly different compound. I am trying out 205's now and besides the increased width, they handle heat much better. However they do get greasy and a spraying is necessary especially with a co-driver.
Bridgestone Potenza RE1-01?
yea not quite sure how to spell that whole thingy, but I will say these tires are a close competitor to falken. They do recquire a little heat before they reach max grip, but you will never need to spray them. I find they handle wet 90% of what falken can do, but still a good tire. As for dry, very little difference in grip. The downside of being to lazy to spray your tires after each run is that these tires dont offer that many sizes.
Overrall, falken wins, but I think im gonna go try the bridgestones next spring.
34 STS
Funded By: My Back Pocket
tua03332 is offline
Old 11-09-2007, 09:29 AM   #16
MattMarks
Fan#: 46203
What I Drive: 2005 ZX 4 ST Spec Focus
FF Reputation: 1 MattMarks Good Standing Member
THis is a bit of a cross-post, but Spec Focus is moving from the Toyo RA1 (205/40/17 to the Toyo R888 (215/45/17) for 2008. The RA1's are being phased out by the end of the year.
For more information -see the Road Racing and Rally forum.
More information on the R888
R888's Stats
Tire Size: 215/45ZR17 91W RD
Product Code: 168160
Rim Width: 7.0-8.0
Tire Wt: 22 lbs
Tread Depth: 6
Inflated Dimension (Dia): 24.6
Inflated Dimension (Width): 8.5
Static Loaded Radius: 11.5
Max Load: 1,356lbs
Max PSI: 50 PSI
Revs Per Mile: 846
Operating Temperature: 140F to 220F, optimum around 200F
Recommended Hot Inflation Pressures: High 30s to Low 40s (psi)
Spec Focus Test Stats:
Circumference at 34psi: 78.50
Diameter at 34psi: 24.64
Tread Depth: Full @ 6/32
2007 Spec Focus NASA National Championships - 4th place
2007 NASA Mid-Atlantic Spec Focus Champion
2006 NASA Mid-Atlantic 944 Supercup Champion
Spec Focus Advisory Board - Have a Spec Focus Question? Ask me!
MattMarks is offline
Old 04-22-2008, 10:46 PM   #17
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
Points 5,927, Level 49
Points: 5,927, Level: 49 Points: 5,927, Level: 49 Points: 5,927, Level: 49
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Hankook Ventus RS2 Z212
Price Paid: 70 per tire
Size: 195 60 14
Simply amazing. First run I had my rear pressures set way to high and did a RWD style donut. After messing with my pressures a bit and when the sun came out they stuck like glue. Very happy.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
