adjusting rear brakes?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2006, 07:00 PM   #1
02specv
02specv's Avatar
Fan#: 16918
What I Drive: 2013 Focus ST
Points 1,050, Level 17
Points: 1,050, Level: 17 Points: 1,050, Level: 17 Points: 1,050, Level: 17
Level Up 50% Completed
FF Reputation: 1 02specv Good Standing Member
I changed the front pads and rotors about 2 weeks ago and since then the car didn't really brake the same. It felt mushy. So today when I was changing the oil, I bled the brakes. That helped the peadle to get a little stiffer, but the brakes still don't feel right. So my service manager said that the rear brakes prolly need to be adjusted. So I racked the car back up and you can take the rear wheels and spin them freely, very eaisly. I know they are not supposed to spin that easy. So I took the dust cover off and came to take the drum off, but I didn't have a socket large enough to fit on that nut. Then I came here and did some searching and found out that the rear brakes are self adjusting. How exactly do you get them to "self adjust"?? I tried pulling the ebrake a bunch of times, driving in reverse, pulling the ebrake while driving, so forth and so on and they still feel the same. Is there an adjustment screw behind the drums?? What size is that bolt to get them off? Any help would be appreicated. Thanks.
02specv is offline
Old 04-28-2006, 07:07 PM   #2
lildisco
RespectMyAuthoritah!
lildisco's Avatar
Fan#: 5761
What I Drive: 06 Mazda6i, 08 Mazda CX7 GT AWD
Points 30,703, Level 100
Points: 30,703, Level: 100 Points: 30,703, Level: 100 Points: 30,703, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 47 lildisco Great Standing Member
Buy-Sell-Trade Rating: (8)
Clicky Clicky To how to adjust the ebrake if that's what your asking.
But as far as adjusting the rear brakes, I've done a few to where you drive about 15 - 20 mph or so and press the regular brakes down. Do this a couple of times and it should set your brakes. I personally don't know if there's an adjustment on the back of the Hub or not.....Hope this helps
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat."
06 Spring Into Focus Best Sedan/Wagon Winner
03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT
lildisco is online now
Old 04-28-2006, 07:10 PM   #3
02specv
02specv's Avatar
Fan#: 16918
Yeah I'm trying to adjust the rear brakes themselves, not the Ebrake. Like if you do a brake job on the front, and don't change the rear shoes, your supposed to adjust them out to comensate for the thickness of the new front pads.
02specv is offline
Old 04-28-2006, 07:14 PM   #4
lildisco
lildisco's Avatar
Fan#: 5761
Forum Activity 3%
Sorry i meant drive 15 - 20 MPH in reverse a couple of times
Old 04-29-2006, 07:35 PM   #5
02specv
02specv's Avatar
Fan#: 16918
^That didnt work, anything else?
02specv is offline
Old 04-29-2006, 07:52 PM   #6
grenada_focus
Fan#: 7055
What I Drive: 2003 Focus ZX3
FF Reputation: 1 grenada_focus Good Standing Member
The following sometimes seems to works for me...
Park the car and turn it off
Raise the e-brake handle as high as possible
Pump the brake pedal until its locks
In terms of the spongy brake feel, changing your pads will not normally stiffen the brake pedal. This seems to be a common misconception. Rather it is the brake line (hoses) expanding under pressure that helps cause a spongy brake feel, especially under warm weather. Upgrade to braided lines to stiffen the brake pedal b/c the hoses do not expand as much. Bleeding the line with the stock hoses will offer temporary stiffness or variant stiffness...
In any case, this seems to be a common problem
grenada_focus is offline
Old 01-31-2015, 01:03 PM   #7
Swakhamer
Fan#: 218426
What I Drive: 2002 Black ZX3
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 Swakhamer Good Standing Member
Help.... I took off the drum to replace the bearing and now the drum won't go back in. How do I adjust to breaks to slip the drum back in
Swakhamer is offline
Old 01-31-2015, 03:15 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,405, Level 75
Points: 13,405, Level: 75 Points: 13,405, Level: 75 Points: 13,405, Level: 75
Level Up 39% Completed
Forum Activity 99%
Easier to do than describe.
You've got a ratcheting adjuster on a bar between the brake shoes, that needs to be released & set to a minimum instead of where it's currently adjusted to for more room to put the drum back on.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-01-2015, 03:11 PM   #9
deandeib
Fan#: 109014
What I Drive: 2011 Sterling Focus
Points 92, Level 1
Points: 92, Level: 1 Points: 92, Level: 1 Points: 92, Level: 1
Level Up 84% Completed
Forum Activity 4%
FF Reputation: 1 deandeib Good Standing Member
Sounds right. I just went thru this minutes ago and had the same problem. I ended up sticking a flat blade screw driver between the two ratcheting surfaces, one on a round nub and the other on the adjusting bar. I think when I pryed them apart, the shoes went to their most closed position so I could get the drum back on. Seems like there is no way to do that same action with the drum on, so how do you adjust the shoes IN to let you pull off a tight drum?
deandeib is offline
Old 02-05-2015, 07:02 PM   #10
amc49
Fan#: 96610
Points 3,374, Level 36
Points: 3,374, Level: 36 Points: 3,374, Level: 36 Points: 3,374, Level: 36
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Really can't, you just work at getting it off. Not bad though unless really deep grooving in drum edge.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is online now
