2005 ZX3 w/Hard Start Problem - Page 2 - Focus Fanatics
Old 04-26-2006, 10:23 PM   #11
abilath
Fan#: 34575
What I Drive: 2005 Screaming Yellow ZX3
FF Reputation: 1 abilath Good Standing Member
Bubba Bob:
Thanks for the tip: I just tried it and it does seem to help! However, as this is not a carbureted car, the fact that I must do pedal acrobatics in order to start it is a bit annoying! Has anyone actually managed to solve this problem with a hardware solution?
-Ryan
abilath is offline
Old 04-27-2006, 01:12 AM   #12
Andy04180
Andy04180's Avatar
Fan#: 21158
What I Drive: 2006 Focus ZX5 Liquid Grey
FF Reputation: 1 Andy04180 Good Standing Member
Thanks for the Info, i'll have to take that up to the dealership this weekend and talk to them about it. One day they'll figure it out.
2006 Liquid Grey ZX5
Current mods:
Interior:
Exterior Mods: 17" Motegi DP12 rims, 5% Tint, Silver Focus Fanatics decals
Entertainment:
Performance:
Team Duratec #70
Andy04180 is offline
Old 04-28-2006, 03:22 AM   #13
EricR
Fan#: 21957
What I Drive: 2005 Liquid Grey ST
FF Reputation: 1 EricR Good Standing Member
Originally posted by Bubba Bob
Lightly press down on the peddle while starting...
Odd -- The only times I've had the hard start problem is when I bump (even very slightly) my gas peddle before starting my ST when cold.
So try Bubba's idea first (nothing to loose) and if it gets worse try keeping your feet away from the gas until you've started your car.
If either makes a difference (good or bad) then please share in a reply post!
ST Crew #23
EricR is offline
Old 05-01-2006, 12:35 AM   #14
abilath
Fan#: 34575
EricR:
I made a mental effort to completely avoid the accelerator as you suggested, but still had intermittent hard start issues.
Thanks for the suggestion,
-Ryan
abilath is offline
Old 05-01-2006, 12:36 AM   #15
abilath
Fan#: 34575
Okay. I spoke with a mechanic friend (non-Ford) this weekend and found that the only thing that he could think of that could cause this problem is an open, or stuck, IAC valve. The theory is that if the engine was still cold when it was last turned off, the IAC valve would still open to keep the idle high. Then, the next time the car is started, the valve is either not told to close or is stuck open and would result in a difficult start to an incomplete choke. This theory sounded reasonable to me (particularly since another user in these groups seemed to have solved his problem when the dealer replaced the IAC valve -among other things). Does this explanation sound feasible to anyone? Either way, I'm going to attempt to find an aftermarket IAC valve (or perhaps an '05 *automatic* version) this week. I'll let you know how it goes.
-Ryan
P.s. Any thoughts would be more than welcome.
abilath is offline
Old 05-01-2006, 06:25 AM   #16
KAG
Fan#: 23149
What I Drive: 2005 ZX5 SE
FF Reputation: 1 KAG Good Standing Member
abilath - Thanks for posting the information about the IAC valve. I really hope it works. Please let us know how it goes. I've been having the same issues with my Car.
KAG is offline
Old 06-05-2011, 09:55 AM   #17
veedubb
Fan#: 86460
What I Drive: 2005 Green ZXW Wagon
FF Reputation: 1 veedubb Good Standing Member
I bought a used ZXW wagon with 5-Spd manual and 2.0 Duratec with 133,000Km on it in March, 2011. I had the same hard starting problem you guys have mentioned and have downloaded the TSB from Ford but didn't want to pay Ford for flashing my ECU, so I was willing to 'live with it' until I get some time to do some 'real' troubleshooting. Since then my alternator went when I was out of town and had to get it replaced for $500, but that's another story. On certain occasions when accelerating, my gas pedal sticks at the upper end of travel (idle position) and gets worse if I just let off the gas and it pedal just 'slams' up. It was to the point that it was dangerous not being able to push the gas pedal down smoothly because I had to overcome the initial sticking.
Anyways, I brought my car down to my buddy's garage who has all the tools I needed to troubleshoot this. I removed the accelerator cable linkage from the Throttle Body (TB) but it was free of any sticking. Next I removed the intake hose to the TB and moved the butterfly plate back and forth to discover that it was sticking. I twisted it to max throttle (with the engine turned off), let it go and it really got stuck in the closed position. There was so much gum around the throttle plate and the housing and I knew that this was the cause of my sticky throttle. So I sprayed the sh!t out of the throttle body with carburetor cleaner and tested it again - no more sticky throttle to this day. Lo-and-behold, this cured my hard start at the same time. I haven't had any more problems with hard starting since I did this at the end of April, 2011. And to think I may have paid Ford to flash my ECU which may not have fixed the problem. Easy to fix and maintain - takes less than 15 minutes, including washing my hands after-wards.
This worked for me and it should be done every now and then to maintain a clean throttle body.
I hope this helps.
veedubb is offline
Old 12-23-2012, 01:23 PM   #18
josephd
josephd's Avatar
Fan#: 84356
What I Drive: 2007 SE Dark Toreador Red Pearl
FF Reputation: 1 josephd Good Standing Member
I am going to revive a very old thread. My 07 with the 5-speed does the same thing. At least with the OP his is clockwork, mine is not.
I was told, the fuel pump is not priming properly. I was also told to turn the key and wait 5 seconds, turn it off, repeat and it should work.
First, IMHO and I am not a mechanic that theory is false it does not work. Secondly, If the fuel pump is not priming properly than it should always happen during cold weather starts.
For example, and I paid close attention today. My Focus was parked on Friday at 3PM. It sat until Sunday at 7:30AM.
When I turned the key, without this priming theory.She fired up without so much as a hiccup. Now where is the fuel after sitting idle for almost 48 hours? Certainly not in the fuel pump, yet she started right up.
So, I drive 1 mile up the road. The car is fully warmed up, I shut it off, for about 10 minutes.
She again starts right up. So, my next destination is 10 miles away. When I get there, the car is literally off for less than 30 seconds.
What happens, the long crank before she starts. Now the fuel pump has long been primed, so again IMHO the long cranks should not occur.
That tells me there is something going on with the computer in some of the earlier Focus's.
If the fuel pump was a certainty, I would spend the 500 plus and replace it. Only because I am OCD when it comes to my cars. From looking at this thread, I can see the problem remains a mystery.
Let no debt remain outstanding, except the continuing debt to love one another, for he who loves his fellowman has fulfilled the law. Romans 13:8
josephd is offline
Old 12-27-2012, 07:10 PM   #19
fsu67
Fan#: 107780
What I Drive: 2002 zx5
FF Reputation: 1 fsu67 Good Standing Member
Check your power hold relay its in the fuse box in engine compartment next to the air filter, Have someone crank the engine over and over and tap the relay or just hit the fuse box and it should crank over! relay cost about $13 at parts store, I've repaired lots of focus with the same problem also goes with every other electrical problem the focus has just slap the fuse box! Ford relays stink!
fsu67 is offline
Old 01-13-2013, 12:20 PM   #20
josephd
josephd's Avatar
Fan#: 84356
Thank-you. :)
josephd is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
