New Engine Technology - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 04-25-2006, 09:14 PM   #1
2004SVTAutoXer
2004SVTAutoXer's Avatar
Fan#: 19123
What I Drive: BMW 335i Coupe, 79 CJ-7
FF Reputation: 26 2004SVTAutoXer Great Standing Member
Source
“Massive Yet Tiny” engine promises big things
Angel Labs has developed a new type of internal combustion engine known as the “Massive Yet Tiny” engine. It “has the potential to replace all the existing internal combustion engines and jet engines,” according to the inventor. It reportedly has a power to weight ratio 40 times higher than a regular internal combustion engine. A 14-inch, 150-pound MYT would reportedly have the same power as a 32 cylinder diesel engine — putting out 858 horsepower.
Below is Angel Labs’ official explanation of the technology:
The prototype has a 14 inch diameter and is 14 inches long. It weighs 150lbs. There are only 26 moving parts, 31 parts total. The first prototype uses diesel or biodiesel for fuel. Through two revolutions of its crankshaft, the ME firing cycle is equivalent to a 32 cylinder reciprocating engine, that is, it fires 32 times. As a result, its displacement is equivalent to an 848 cubic inch reciprocating engine, despite its compactness. This displacement comparison is derived as follows: (3.1416*(3)(3)*3.75)/4*32 = 848 cubic inches, with a 3? bore and 3.75? stroke, four stroke cycle and thirty two firings. The design is also modular. Additional units can be connected to increase power. The ME is actually a large (extremely efficiently organized) displacement internal combustion engine; therefore its high horsepower output. Moreover, with the high number of cylinders firing in close order, a high number of pulses are generated for high torque, but without the friction and parasitic losses discussed below.
At 150lbs, the basic ME design needs only to produce 3,000 hp from 848 cubic inches to produce a 20 to 1 power to weight ratio. (We are assuming less than 4 hp per cubic inch of displacement. Racing engines based on conventional design perform up to 5+ hp per cubic inch of displacement with Super/Turbo Charge. With Normally Aspirated, it will generate minimum 850 horse powers.) To our knowledge, only the latest jet engine has finally attained a 20 to 1 power to weight ratio. By replacing the rear cover of the ME and connecting another ME chamber assembly (adding two inches in length and little additional weight) the ME now becomes a 64 cylinder engine with 1,695 cubic inches raising the power to weight ratio up to 40 to 1.
Since the ME lacks the 80% of the parts normally found in a reciprocating internal combustion engine that is responsible for high friction and parasitic losses, this normally dormant horsepower is now available and would increase the total deliverable output of the ME.
Normally, in a compression ignition (diesel) engine, combustion begins @ TDC (Top Dead Center) @ 0 degree crankshaft position. The expanding gases push the piston down on the power stroke, rotating the crankshaft 180 degrees. The piston then returns to TDC pushing the exhaust at the exhaust stroke, rotating the crankshaft another 180 degrees. This is the burning time in a standard engine, a total of 360 degrees duration.
On a dynamometer, an engine’s combustion temperatures is typically measured 2? from the exhaust ports, on the premise that the combustion temperature is very close to exhaust temperature. This is due to the zero degree duration @ TDC and the 360 degrees running duration of a standard engine. However, if @TDC, the piston is allowed to stay for a longer duration, it will burn a greater percentage of the fuel and air mixture in the combustion chamber until oxygen or fuel theoretically runs out at the end of the power stroke, thereby totally completing the combustion process and drastically lowering the exhaust temperature at the end of the exhaust stroke.
The ME design permits the piston dwell @TDC to be adjustable and the prototype ME is currently set at approximately 12 degrees of the crankshaft rotation, thereby approaching the perfection of a complete burn of all fuel. Its exhaust gases are much cooler. As a result:
More energy is harnessed for the same amount of fuel and air input.
There is less left over fuel to continue to burn at the exhaust stroke.
There is less waste and pollution
The higher compression ratios used in diesel engines result in greater thermal expansion of gases in the cylinder. The end result is a high percentage of fuel energy being converted into useful power. (When running the ME with Bio fuels, the same fuel is used to lubricate the crankcase.) In the ME design, a compression ratio as high as 70:1 can be attained due to the absence of the restrictive reciprocating components. Specifically:
The combustion chambers in the ME have no design limitations due to the absence of valves. (The internal combustion engine is an air pump. Airflow through intake and exhaust ports are normally restricted by valves. The ME has no valve –just open ports with no restriction. Air flow action is one way.)
There are no odd or brand new parts within the cylinder. All the parts are proven designs used in reciprocating engines.
The entire engine acts as a heat sink and a radiator. It is both air and oil cooled.
There is no thrust loading on piston skirts.
Pistons do not touch the cylinder walls, only the rings do.
Pistons travel only the same direction. No reciprocation, only stop and go.
There is high rpm potential for all of these reasons.
There are no cylinder heads, no cam shaft, no valves (the ME is equivalent to the bottom end of a reciprocating engine).
Intake compression and power stroke and exhaust stroke events are happening all at the same time, so there are no load strokes.
SVT Squad #133 - Traded for 2008 Subaru Legacy 2.5i Limited in Quartz Silver Metallic - Traded for 2008 BMW 335i Coupe with stock twin turbo Juiceboxed 500whp and 500wtq of N54 goodness.
2004SVTAutoXer is offline
Old 04-25-2006, 09:20 PM   #2
Shadowrunner
Shadowrunner's Avatar
Fan#: 31568
What I Drive: 1996 Dk. Green Mustang GT Conv. MTX
FF Reputation: 4 Shadowrunner Good Standing Member
wow... that's amazing
Robby
Originally Posted by Amw86 View Post
returned fiance's engagement ring, since she returned me, made nice pc funds lol
Shadowrunner is offline
Old 04-25-2006, 10:29 PM   #3
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 3%
FF Reputation: 9 Timmeh! Good Standing Member
Buy-Sell-Trade Rating: (6)
i beleve it's called a quasiturbine, IIRC
they're amazing, just think the Wenkell engine, but designed way more efficently.
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is offline
Old 04-26-2006, 09:29 AM   #4
Mr-914
Mr-914's Avatar
Fan#: 22215
What I Drive: 2002 Focus 2.0 Zetec
FF Reputation: 1 Mr-914 Good Standing Member
The el (read rotary) has been a revulotion for 50 years...but only on paper.
Why is the word el (read rotary) censored...seriously you ers, get a life.
Mr-914 is offline
Old 04-26-2006, 10:41 AM   #5
igor
igor's Avatar
Fan#: 25921
What I Drive: 2004 Mazda3s Sedan MTX
FF Reputation: 1 igor Good Standing Member
^^^^ [Nelson] HAHA [/nelson]
Mr-914 got PWNED ???...
but seriously.. FF censors W-A-N-K-L-E-R?
Hmm..I wonder what W-A-N-K means.
Igor
igor is offline
Old 04-26-2006, 01:58 PM   #6
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
^^^isnt it a british term, isnt it, - er shit
haha i like how is censored but not shit or biotch or d!ck
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 04-26-2006, 02:43 PM   #7
Mr-914
Mr-914's Avatar
Fan#: 22215
A er is a jerk-off in brit-talk.
Mr-914 is offline
Old 04-26-2006, 05:45 PM   #8
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Forum Activity 3%
alright heres the official definition of er (courtesy of urbandictionary.com):
1. er
631 up, 59 down
While "to " means "to masturbate", the term "er" is seldom if ever used in British slang to denote "one who s". It is quite wrong to infer from somebody's being a er that they in fact (and vice versa), but of course, fair to assume they do in any case. Herein lies the genius of the insult: if you call someone a er, it's probably true, but only literally.
I suppose it all originates from our repressed Victorian sexualities, from back when everybody thought they were the only ones to suffer the secret shame of being an actual er.
Most children these days learn the word "er" long before they learn its literal meaning.
You're such a er.
Oh gosh! How did you know?
He lost both of his hands in a childhood kiting accident.
What a er!
and thats only 1 of 92 definitions!
Timmeh! is offline
Old 04-26-2006, 07:06 PM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
el rotary engines, and the Mazda improvements produce more power per cubic inch- but use the same amount of fuel to do it. Because of the way the oil seal system is in a rotary, there is a very high chance that oil will be introduced in tiny amounts to the combustion chamber- lowering emmissions.
The concept is great, I've owned two rotaries, and I'd get an RX8 in a minute if I could afford a toy car. The torque curve- if you can call it that- is highly impressive, and the sound of one is totally cool. However, it's not that energy efficient if you look at the power you get from one and compare it to the fuel used. At least that's how it was with the ones I owned.
This design is something I think I read about that Carrol Shelby was investing in. I found a website on it years ago, but didn't have the money for an investment at the time. There have been several major improvements to gasoline engines that we haven't seen on the consumer end since I've been reading about motors. The one I FREAKING KNOW would work great on the Duratec engine is the Coates spherical valve. It would be incredibly easy to convert the Duratec- and since Coates originally used Ford motors to showcase his idea: I wondered if there were plans for something like that in the future. Sadly, my emails were returned telling me that the company was only producing head/cam designs for a British truck maker, and some generator motors.
We can only dream that we live to see heralded combustion engine improvements.
ing ers
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
