Brake and Suspension Interchange Guide 00-06 - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-12-2006, 09:34 PM   #21
zx3freak
Fan#: 20544
FF Reputation: 1 zx3freak Good Standing Member
does this mean on my 01 zx3 I could get a stock 05 Lower Control Arm and spindle then buy svt rotors, pads, and calipers and have a front svt setup? Also has anyone put 05' rear discs on a drum car? thanks for any info.
zx3freak is offline
Old 10-13-2006, 06:49 PM   #22
CLWNCAR
CLWNCAR's Avatar
Fan#: 32518
What I Drive: 2003 Red ZX3 Roush Stage 2 Turbo
FF Reputation: 1 CLWNCAR Good Standing Member
Originally posted by Nfocus
So on my 06 ZX3, all I need to do is buy rotors, pads, calipers for the front and they are a direct fit no blood or tears will be spilt over doing this.
If this is so then, Phewwwww. Now on to the real question. What will it take to convert the rear drums to the larger rotors (SVT)? Sorry if this has been covered in a "how to" Im still new to the entire Ford deal and trying to learn from the ground up the hard way.
I think the strut tube diameter is a different size????
CLWNCAR is offline
Old 10-17-2006, 03:04 PM   #23
Nfocus
Nfocus's Avatar
Fan#: 38741
What I Drive: 06' Silver, ZX3 SE Team DURATEC #03
Points 2,141, Level 27
Points: 2,141, Level: 27 Points: 2,141, Level: 27 Points: 2,141, Level: 27
Level Up 94% Completed
FF Reputation: 2 Nfocus Good Standing Member
hummmm its the SVT swap or I go to stop tech and tell them make me a set using an 18" rim.
Im into fast cars and women, just women are harder to get into.
Team DURATEC # 03
Last of the Hatches # 24
US MARINE, above all!
Nfocus is offline
Old 11-13-2006, 08:59 PM   #24
ndforspeed1120
Fan#: 40623
What I Drive: 2006, Red, ZX3
FF Reputation: 1 ndforspeed1120 Good Standing Member
06 front spindles/brakes
on a 2006 zx3 will the front brakes work with 00-05 spindles? im in the process of lowering my car now.
also do you know any where i can get the spindles cheap and or easy?
ndforspeed1120 is offline
Old 11-13-2006, 11:38 PM   #25
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I believe so...if I'm not mistaken, the only difference between the '05 spindles and the '06 is the slot for the bottom of the strut is 5mm wider on the '06. I don't believe they changed the calipers between the two years.
Also, '00-'04 spindles won't fit an '05+ unless you change your ball joints, calipers and rotors. The '05 pretty much uses the SVT spindles because they increased the rotor size, the only difference between '05 and SVT being the ball joint stud diameter.
SkaAddict is offline
Old 03-16-2007, 01:22 PM   #26
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Jeremy, are you going to add the 07 model information to this thread?
The questions are coming up fairly often now.
WD40 is offline
Old 04-04-2007, 01:01 AM   #27
06focuskid
Fan#: 42764
What I Drive: SILVER 06 zx3 ses 5spd FORD GFX PKG
FF Reputation: 41 06focuskid Great Standing Member
so that svt suspension kit on fordracing.com Is not going to work on my 06 zx3 ses? I thought the suspensions manly stayed the same it says fits 00-04 DAMN IT wat do i do now i wanted a small drop and improved handleing even tho this car already loves the corners. And that kit offered what i wanted if i was going to lower any.
06focuskid is offline
Old 04-24-2007, 05:24 PM   #28
drewagood1
Fan#: 43647
FF Reputation: 1 drewagood1 Good Standing Member
Rear drum for disc brake swap
I have a 2000 ZTS. How hard is it to change the rear drum brakes for later year factory discs and what all needs to be replaced?
drewagood1 is offline
Old 04-25-2007, 02:35 AM   #29
focusWI
Fan#: 35665
What I Drive: 2006 CD Silver ZX3
FF Reputation: 1 focusWI Good Standing Member
i may just be a little slow but..
to do an svt brake swap on an 06 do i just need to swap out the brakes and thats all? or would there be suspension swapping involved?
focusWI is offline
Old 06-18-2007, 04:01 PM   #30
sinhumane
sinhumane's Avatar
Fan#: 48102
What I Drive: 2007 CD Silver SES
FF Reputation: 1 sinhumane Good Standing Member
what would be involved in adapting an 07 ses to use 00-05 springs/coilovers? what is the difference between 05, and 06-07?
2007 CD Silver SES, no mods..... yet.
1995 Thunderbird Supercoupe, supercharged 3.8 v6, 235 rwhp, 330 ft-lbs rwtq. 1 of 574 5 speed cars.
sinhumane is offline
