SVT JRSC +BBK Boost - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 04-10-2006, 10:37 AM   #1
Springbuck
Fan#: 23301
What I Drive: 03 CD Silver SVT 5DR
FF Reputation: 1 Springbuck Good Standing Member
SVT JRSC +BBK Boost
I ran a boost guage (autometer) to the engine just to check my boost and it is only reading about 5 PSI max. I have no leaks and the car is running fine. What can be the problem. I thought it was supposed to run about 10 PSI?
03 SVT Focus, STS,
2011 Fusion SEL -Bone Stock and staying that way
Springbuck is offline
Old 08-13-2013, 10:29 AM   #2
SVTFocusOnMe
SVTFocusOnMe's Avatar
Fan#: 89087
What I Drive: 2003 SVT EAP Screamin' Yellow ZX3
FF Reputation: 4 SVTFocusOnMe Good Standing Member
I am aware I am bringing this back from the dead but I am having the EXACT same problem. I have checked almost everything. Running out of ideas.
Did you ever fix this?
03 Ford SVT Focus JRSC BBK
The Bad Cat (97 Merc Cougar XR7)
SVTFocusOnMe is offline
Old 08-13-2013, 11:14 AM   #3
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
Is the belt slipping?
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 08-13-2013, 02:57 PM   #4
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
if the belt isn't slipping, then it is a boost leak....which can be any number of things. either one of the gaskets could be bad, or the bypass valve could be worn/faulty (thereby bleeding off boost), or there is a hole/crack in one of your vacuum lines
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is online now
Old 08-13-2013, 06:44 PM   #5
SVTFocusOnMe
Fan#: 89087
The belt isn't slipping. I did some digging and I'm pretty sure it's the bypass valve. I disconnected it and plugged the vacuum line that leads to it and took a drive and the car drives exactly the same.
I'm just a little confused shouldn't it be stuck closed or open when I removed the vacuum line?
Old 08-13-2013, 09:10 PM   #6
hurtinfocus
Fan#: 835
the vacuum line for the bypass valve is there to OPEN it when the car sees vacuum so that the boost has somewhere to go instead of causing pressure surges. Disconnecting it will only keep it from opening....if the valve is faulty it would be leaking regardless of seeing vacuum or not. to see if it has a leak spray some carb cleaner near it while the car is running and see if the idle changes.
Old 08-13-2013, 09:26 PM   #7
SVTFocusOnMe
Fan#: 89087
Yes and when I disconnected it in theory the valve should stay closed and I should build boost. But when I went for a drive the car drove exactly the same as when it was connected.
I sprayed carb cleaner a couple days ago and didn't find a leak I can try again tm.
Is it possible for the valve to be partially stuck open/closed? This way I can only build some boost but not max.
Old 08-14-2013, 08:47 AM   #8
hurtinfocus
Fan#: 835
it is possible....but be forewarned, the valve is $310 from Moss to replace it...and that may not be the issue/only issue
Old 08-14-2013, 08:50 AM   #9
SVTFocusOnMe
Fan#: 89087
If it is my only issue at this point I will be happy. I have had nothing but bad luck with this kit so far.
Is there any other way to check if its functioning correctly?
Old 08-16-2013, 10:37 AM   #10
SVTFocusOnMe
Fan#: 89087
Okay so here's where I'm at now. Checked the wastegate. Car drives the same when it's closed. Now. When parked and in neutral. If I rev it I can get 9 psi which is acceptable since the blower is ported and I might read less psi but still get the same power. But when I go for a drive with wastegate closed I see 5-6 Max.
Sprayed carb cleaner everywhere didn't find a vacuum leak.
So I'm pretty sure I probably have a leak that only occurs during boost when there is pressure. Which makes it next to impossible to find.
So I'm pretty sure my only option is taking it apart and putting it back together a little more meticulously. Unless the original poster decides to sign on after a year of inactivity and tell me the problem he had.
