HOW-TO (TUTORIAL): Changing Wheel Colours - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Off-Topic Discussions > Photos & Camera Fanatics
Photos & Camera Fanatics Post your photoshop, photography artwork or camera tips and tricks here.
Old 04-06-2006, 11:48 PM   #1
refemall
refemall's Avatar
Fan#: 33052
What I Drive: 2000 Black Focus SE
FF Reputation: 1 refemall Good Standing Member
Alrite, this is going to be a simple rim colour photochop modification. If you have certain colour rims in mind, but can't seem to find them, this tutorial might come in handy.
Here's the photograph I'm going to be working with:
Obviously, I've cropped the image, but that's just for simplicity's sake, and so it'll fit easily on the page.
I'm going to be using PS CS2 for this, so if you have a different program, it might be somewhat different.
First, I want to select the entire wheel, so I'll be using the magnetic lasso tool. To select this, hold the lasso button until a box appears, and select Magnetic Lasso.
Click once on the edge of the wheel for the starting point, and just outline the shape of the wheel. You don't have to be precise, because it will automatically comform to the shape of the wheel. Once you've outlined it, double click, and the wheel will be selected.
Well, this just wont do. We have the entire wheel selected, but we're not changing the colour of the calipers and disks. To remove these, we have to unselect them. So, we're going to inverse the selection. To do this, click the Select menu, then Inverse. Now, we have everything but the wheel selected. Now, what we want to do is add to this selection to do so, we can use the same process of selecting the wheel, or you can use a different type of lasso, so long as it gets the job done. The only difference this time, is we're going to hold SHIFT as we select each area. This will add to the already selected area, without creating a new selection.
When you're done, it should look like this:
But wait, remember, we inverted the selection. So, we have to invert it again, so all we have selected is the wheel. Do this the same way as before (Select >> Inverse).
From here on, it should be pretty easy. To make white rims, I simply adjusted the brightness and contrast (Image >> Adjustments >> Brightness/Contrast)
ANd it was the same idea for the Gunmetal look.
Now for colour, it's a little bit more complicated. You want to go Layer >> New >> Layer via Copy. Now, with the copied layer selected (it should be just the selection of the wheel), right click on it, and choose "Blending Options". Click Colour Overlay, choose the colour, and set the opacity to about 65%, so the details of the wheel stil shine through. Remember, this isn't supposed to looks completely real, it's just to give you an idea of what it might look like if it were real.
And, at least it'll save you some money from buying it and finding out you don't like it.
I hope this was an informative tutorial how-to. Any feedback would be much appreciated.
And, for kicks, here's the final products (except for the coloured versions. You get the idea).
If anyone has any feedback, etc, please let me know.
Cheers!
refemall is offline
Old 04-07-2006, 12:11 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Nice work, I'll 'sticky' this....
Chad (S2)
S2 is offline
Old 04-07-2006, 01:41 PM   #3
refemall
refemall's Avatar
Fan#: 33052
Cheers, thanks!
refemall is offline
Old 04-07-2006, 09:02 PM   #4
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 3%
FF Reputation: 9 Timmeh! Good Standing Member
Buy-Sell-Trade Rating: (6)
one more thing i'd like to add....
when i changed the color of my brake calipers in photoshop i sed the same technique, but i used the satin blending option.... if you play around with the size and stuff, it'll work perfectly, without having to play with the opacity.....
just my $0.02
here's an example of what im talking about....
and after...
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is offline
Old 04-11-2006, 05:19 PM   #5
cruzstyle
cruzstyle's Avatar
Fan#: 12277
What I Drive: 2005 white focus zx3
FF Reputation: 5 cruzstyle Good Standing Member
very nice write up man
"you can always tell the way a man takes care of himself, by the way he takes care of his car"
FOCAL-POINT.ORG
Focus Beach Festival 2007 is coming soon...
cruzstyle is offline
Old 04-14-2006, 01:12 AM   #6
refemall
refemall's Avatar
Fan#: 33052
Thanks.
refemall is offline
Old 09-29-2006, 11:16 AM   #7
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Adjusting color of a selection is a lot simpler with the Hue/Saturation tool. Just click the Colorize checkbox and you can easily adjust the hue, saturation, and brightness of the color you want your selection to be.
CaysE is offline
Old 09-29-2006, 11:33 AM   #8
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
I actually use Corel myself and use a similar technique as mentioned above.....
Chad (S2)
S2 is offline
Old 09-04-2008, 10:34 PM   #9
Als RS8
Als RS8's Avatar
Fan#: 53271
What I Drive: maroon lx
FF Reputation: 1 Als RS8 Good Standing Member
thanks
lol it is bright where you are
dont let any buddy tell you differant
Als RS8 is offline
Old 11-25-2009, 07:55 PM   #10
RaNd0b
Fan#: 64181
What I Drive: 2009 Vista Blue Focus
FF Reputation: 1 RaNd0b Good Standing Member
good stuff!!
RaNd0b is offline
