Cam Gear Alignment Tool - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-28-2006, 10:51 PM   #1
zx3_boy
Fan#: 25977
What I Drive: 2000 Blue ZX3
FF Reputation: 5 zx3_boy Good Standing Member
do you really need the Focus Cam Gear Alignment Tool when installing cam gears on the car, or can you use something else instead?
You know you’re into cars too much when your girlfriend comes over to show you how she died her hair and you say “you should have left it stock”
zx3_boy is offline
Old 03-28-2006, 11:03 PM   #2
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
you don't NEED the alignment tool but it certainly helps. no reason not to use it...its cheap and very useful
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 03-28-2006, 11:11 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
The tool is just a flat piece of metal designed to go in a slot in the back of the cams. If you buy a set of cams, I believe this will come with the cams. If for some reason you're putting in junkyard cams, then you can take your old cams and find some sort of flat hard metal to fit the slot, and use that. There's no reason why it wouldn't work so long as it fit snugly.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-29-2006, 01:14 AM   #4
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
True ^^^, the kit omly cost $20 or so. I know Tony at Newedgeperformance.com keeps them in stock.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 03-29-2006, 01:41 AM   #5
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,745, Level 78
Points: 14,745, Level: 78 Points: 14,745, Level: 78 Points: 14,745, Level: 78
Level Up 74% Completed
Forum Activity 10%
FF Reputation: 90 goinloco1 Excellent Standing Member
just dont try to use the bar to break the cam gear bolts loose.... cams arent cheap.
theres a knob between lobes 1 &2 that will face down at tdc. i found vice grips work perfect to hold the cams while your reaking the bolt loose and the vicegrips will keep it from flipping around on you.
try using the bar and you may snap the slot off the end of the cam....then your screwed.
and by the way, the bar is 5mm thick and about a foot or so long. a machine shop can make it for a couple bucks out of scrap.
goinloco1 is online now
Old 03-29-2006, 10:34 AM   #6
liquid01
Fan#: 252
What I Drive: ZX3 S2 modded--Just a touch
FF Reputation: 3 liquid01 Good Standing Member
This is all good advice. Use the vice-grips and make a cheap aliag. bar at 5mm. This will get the job done.
For Sale (sleeper)
liquid01 is offline
Old 03-29-2006, 06:47 PM   #7
viney266
viney266's Avatar
Fan#: 93
The kit also comes with a pin for TDC on cyl. #1 that you screw into the block. WELL worth the price of admission. NEVER cheap out on tools. I am a mechanic by trade ( tech if you will ) I have a few more than $20 invested in tools.
viney266 is offline
Old 03-29-2006, 07:00 PM   #8
slikirish
slikirish's Avatar
Fan#: 26844
What I Drive: 2004 Mustang GT 5 Spd
Points 2,589, Level 30
Points: 2,589, Level: 30 Points: 2,589, Level: 30 Points: 2,589, Level: 30
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 2 slikirish Good Standing Member
perhaps off topic, but would putting a set of cam gears on the stock cams do anything? More power etc...
Zetec Crew #4
Back on Stock wheels after bending 3 18's in 2 months. Stupid Winter Roads.
slikirish is offline
Old 03-29-2006, 09:01 PM   #9
jfocus69
jfocus69's Avatar
Fan#: 31958
What I Drive: 2001 ZX3-----Royal blue w/ gold met
FF Reputation: 1 jfocus69 Good Standing Member
They are only beutification, unless they are adjustable.
Zetec Crew #80
Naturally aspirated torque junkie
Rest In Peace FOCUS CENTRAL
jfocus69 is offline
Old 03-29-2006, 10:27 PM   #10
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
If the cams were tuned on a dyno. Or you can do the textbook basics: advance total cam timing= peakier power curve with higher hp / retard total cam timing= broad power curve with more low end torque. Since we have dual cams, we can move the intake and exhaust independent of each other, and increase cylinder pressures by moving the centerline of the cams away from each other- for example: adv int 2, exh 0 change.
Things don't always work exactly exactly on every motor, so this is only a guideline. Dyno tuning of the cams would be the best way to determine what is the best adjustment for your cams. Or you can always order them in some flashy color, get a groovy sticker, remove the upper timing cover, and show your buds how much of a race fanatic you are
Be eclectic.
