How-to: Vf Rear Motor Mount Install [picts] - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 03-18-2006, 03:49 PM   #1
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Post How-to: Vf Rear Motor Mount Install [picts]
I installed my VF-Engineering motor mount this morning, and took LOTS of picts....this is a COMPLETE HOW-TO, so I suggest it for the How To archives.....
I know many people have this, but this is for all of you that still need it.....I have put off buying this for a LOOOOOOONG time, and now it's over and done with......
P.S. SIDE NOTE: if you see it, I had a donut on (left rear).....last night I got a flat tire, plugged it.....see if it holds....
TOOLS NEEDED FOR INSTALL:
1. open bay/space
2. Jack (1)
3. Jackstands (2)
4. 13mm wrench (I used closed end)
OPTIONAL: Air supply, air hammer/wrench and 13mm socket
5. Hammer (for slight adjustments of mount)
6. screwdriver, or drift pin (small adjustment of mount)
INSTALL TIME: about an hour with hand tools, less with air wrench
NOTE: you are RIGHT NEXT to your cat, and exhaust...MAKE SURE YOUR EXHAUST IS COOL/BARELY WARM TO THE TOUCH!!!!!!!!
P.S...I got REALLY dusty from the ground, you are on your back for the whole install.
Box in car:
Mount on dash:
Instructions:
STEP 1:
Jack Car up and put on jackstands
STEP 2:
locate mount
STEP 3:
Jack up tranny/engine assy SLIGHTLY, to hold engine and tranny up, and take pressure off the mount...LEAVE JACK HERE FOR THE WHOLE INSTALL!!!!!!!!
STEP 4:
Loosen front bolt with a 13mm wrench (or use an air wrench)
The bolts are a few inches long, and they have to be screwed ALL THE WAY OUT....so don't try to smack em with a hammer, cause the stock mount is threaded. (the new mount is NOT....)
STEP 5:
I loosened the front bolt until I saw the threads, and then I started on the rear bolt:
STEP 6: REMOVE REAR BOLT.
Expect the motor to move rearward about an inch......it is supported by the jack, but it will still move some anyway.....
bolt removed, showing how mount has been pushed back a little.....notice holes not aligned....
STEP 7: REMEMBER BOLT LENGTHS!!!
Rear bolt is on the left, front bolt is on the Right......the rear is longer....
STEP 8: this is the hardest part, physically too....in order to remove the stock mount and install the new mount, I needed to push the motor forward about 2'', or a little less....but it was already on a jack, soI figured out that if I wrapped my legs around cat right behind the header (COLD.....duh....) I could use my legs and PUSH the header forward (and thus move the engine up and to the front) and wiggle the old mount out....I didn't get a pict of the mount coming out, since my hands and legs were tied up ......here is a pict of where my legs were:
http://www.focusfanatics.com/howtos/...ogetmounto.jpg[/IMG]
Push forward on the header, and wiggle the mount out...I had it come out towards the passenger side, same as for the new mount install.....you will see that pict when I install the new mount, as installation is the same as removal....
STEP 9:
GIVE OLD MOTOR MOUNT THE FINGER, AND CURSE IT's DESIGN!!!!
STEP 10:
smile next to new mount
STEP 11: CHECK FOR PROPER PLACEMENT OF NEW MOUNT
the cupped side will go DOWN....simple
STEP 12:
INSTALL NEW MOUNT
same thing as removing old mount, push forward on the header with legs, and install new mount
this is the pict that shows how the old mount came out, but instead it's the new one going in....I couldn't take a pict of the old mount coming out, so this is the closest I can get.....
MOUNT HALFWAY IN:
NOTE: there is a flange on the lower support member.......watch out or you'll cut your finger....
got my pinky.....
MOUNT ALL THE WAY IN: (fitted in place)
STEP 13:
INSERT REAR (LONGER) BOLT
I used a hammer and a screwdriver to slightly adjust the position of the mount, to align the bolt holes......
rear bolt screwed in:
STEP 14:
INSTALL FRONT (SHORTER) BOLT
I used the same method with my leds pushing forward on the header to line up the bolt holes for the front bolt....push the header forward, line up the bolt hole, and stick the bolt in....
Front bolt installed....
STEP 15:
TORQUE BOTH BOLTS TO 35FT/lbs.
STEP 16:
LOWER JACK AND TAKE A GANDER AT YOUR NEW MOUNT INSTALLED!!!
STEP 17:
LIFT UP CAR AND REMOVE JACK STANDS
THAT IS ALL! should be around an hour......probably less, cause I took all these picts,and had to get all the tools at the shop.....
Hopefully you understood all of this.......
THANK YOU ALL!!!
HaveBlue83 is offline
Old 03-18-2006, 03:54 PM   #2
dwdgsi03
dwdgsi03's Avatar
Fan#: 2298
What I Drive: 2000 Midship Runabout
FF Reputation: 1 dwdgsi03 Good Standing Member
Nice write up and great pics. Now we have two!
(\_/) Copy this bunny to your sig because he`s better than the "other bunny"
(O.o)
dwdgsi03 is offline
Old 03-18-2006, 03:54 PM   #3
JohnMichael
Michael J. Caboose
JohnMichael's Avatar
Fan#: 21469
What I Drive: Black Hemi Ram & Honda Shadow VT600
FF Reputation: 7 JohnMichael Good Standing Member
Didn't Doug (WD40) already do this How-To? Nice pics anyways!
Cap America and Deadpool walk into a bar, Cap orders a glass of milk, because he's Cap. DP orders a glass of Human Crap, because he's Deadpool.
O'er Pirates from the Black of Pitch
JohnMichael is offline
Old 03-18-2006, 03:58 PM   #4
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
I figured why not do a write up and take picts while I did it.........wasn't sure if we had one yet of not......
Old 03-19-2006, 05:58 AM   #5
fat pat
fat pat's Avatar
Fan#: 18326
What I Drive: 2002 Pitch Black SVT Zx3
FF Reputation: 1 fat pat Good Standing Member
heres a great peice of advice...dont strip the hell out of the bolt that mounts to the frame, because you wont be able to use your shiny new mount
Oversteer scares the passenger
understeer scares the driver...
fat pat is offline
Old 03-19-2006, 09:00 PM   #6
zedeater
zedeater's Avatar
Fan#: 17864
What I Drive: 03 Pitch Black SVTF/1994 Mustang GT
FF Reputation: 1 zedeater Good Standing Member
Here is the link to WD40's original how to....
http://www.focusfanatics.com/forum/s...threadid=26094
Yours is also seems to be a high quality "how to" Haveblue83, I wouldn't hesitate to use yours either.....if my dealer hadn't already installed mine free
Keep up the good work!
2003 SVT fOCUS 3dr Black on Red (1 of 981 )
#3038 of 3985
SVT SQUAD #70
zedeater is offline
Old 03-20-2006, 01:39 PM   #7
Jojos ZTS Focus
Fan#: 32953
What I Drive: 2003 Pitch Black ZTS Focus
FF Reputation: 1 Jojos ZTS Focus Good Standing Member
I'm not sure, but what is the inferiorness of the OEM motor mount? Why is the VF motor mount better?
/Not sure, just want to learn
03 ZTS Focus, window tinting, Zetec 16v engine, 16" Alloy Wheels, ceramic brake pads, K&N drop in air filter, Polk DB speakers, 12" Alpine sub and HU, and more to come
Jojos ZTS Focus is offline
Old 03-20-2006, 01:46 PM   #8
blight0x
blight0x's Avatar
Fan#: 18053
What I Drive: 2005 Ford Focus ZX3 SES
FF Reputation: 1 blight0x Good Standing Member
learn2search
F2 RS Body Kit | FS SCT XCAL2 Custom Tune | FS Cold Air Intake | FS Stealth Exhaust | VF Engineering Rear & Driver side Engine Mounts | H&R Coilovers | Corbeau CR1 Race Seats | Hella Taillights | 18" Kazera Wheels (Black)
Thanks for bringing my Signature up to Code S2! <3
blight0x is offline
Old 03-20-2006, 02:48 PM   #9
HuTcH77
Fan#: 32875
What I Drive: 03 Silver ZX3 Red 90 S-10
FF Reputation: 1 HuTcH77 Good Standing Member
umm those didnt look like craftsman tools is that allowed?
and well documented... wish change control arm bushins on an s-10 was that easy
i had cuts like you have on your pinky on all my fingers and nuckles
HuTcH77 is offline
Old 03-20-2006, 05:46 PM   #10
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
the craft shop on base supplied the tools.....
tonite I'm gonna take the mount out, and take the car in to Ford tomorrow, cause the motor is still clunking in the bay.....I think it's another motor mount (one of the side ones)......back to stock for a warranty claim, and after it gets fixed, I will put it back in again, and throw the H/F cat on and get a short shifter.......
