Allowable Mods by Class (Autocross) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 08-03-2007, 01:09 PM   #11
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
What I Drive: '00 ZX3 Turbo, '06 ST Turbo
Points 5,063, Level 45
Points: 5,063, Level: 45 Points: 5,063, Level: 45 Points: 5,063, Level: 45
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 24 tiresmoker Great Standing Member
^^^The way I would see it, no, you can't put any SVT parts on your car. Reason being, it wasn't a factory option. Even if it was a factory option the car has to be built in those years. So if you could get an SVT suspension on a non SVT from the factory in say 2002 - 2004, your non SVT would have had to been built between those years to qualify to add the parts after the fact. See where I'm going with this.
You CAN get a set of DOT R-compounds on your stock wheels diameter and width, you can run a K&N or other higher flowing drop in air filter as long as you use the stock air box, and I think you can change your bushings in the front say bar, or change the front sway but not the rear. The rear must remain untouched.
I've seen people get kicked out of HS for less though. One guy had a Mazda 3 and he put a stock Mazda 3 spoiler on his car (sedan) but the spoiler wasn't a factory option for his year or something. Had to remove to stay in HS
ST Crew #19
2006 ST Turbo: JUNE 07 ROTM 2007 Ride of the Year
2000 ZX3: superturbochargedpartscar
2005 Shinka RX-8: too many mods....
Originally Posted by 03OrangeSVT
It was like concentrated death on chicken
tiresmoker is offline
Old 08-03-2007, 02:47 PM   #12
Nye
Nye's Avatar
Fan#: 29653
What I Drive: 94 SHO ATX, and 2000 Blue ZX3 MTX
Points 678, Level 13
Points: 678, Level: 13 Points: 678, Level: 13 Points: 678, Level: 13
Level Up 56% Completed
FF Reputation: 1 Nye Good Standing Member
thats at nationals though right? not at a small region event?
Nye is offline
Old 08-03-2007, 03:15 PM   #13
miniboon
Dehawkified
miniboon's Avatar
Fan#: 35233
What I Drive: 2005 Impreza 2.5 RS
FF Reputation: 42 miniboon Great Standing Member
the "option package conversion" has to be for the same model year and it must be COMPLETE. So SVT parts can only be put on the same year, either 02,03, or 04, and you have to put EVERY SVT part on to stay stock. Basically, it's not worth it. Either go up to STS or just stay stock and enjoy the drive. The class you are in is not so important as learning about yourself and your car and HAVING FUN. Also, whether it's nationals or a small event, any SCCA event follows the same rules
Originally Posted by viney266 View Post
I think miniboon is right on the money.
miniboon is offline
Old 08-03-2007, 04:18 PM   #14
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
^^^ding ding ding
Basically you would have to upgrade the entire car to an SVT. Might as well buy one then, ya know.
Just have fun in your stock class and learn to drive better. Or if you want to upgrade the car and run a different class.
The one nice thing about stock classes is you can run DOT R-compound tires. You can't run those in any of the street touring classes.
ST Crew #19
Old 08-03-2007, 04:58 PM   #15
tua03332
tua03332's Avatar
Fan#: 37555
What I Drive: 2000 Silver Sedan
FF Reputation: 1 tua03332 Good Standing Member
if you wish to remain in stock class there are but a few things you can do to the car. Obviously I would recommend upgrading the driver first, but if you want a more mechanical answer here ya go. Any shocks using oem mounting position, stock wheel width/size, but not weight (hint: enkei light weight wheels). Dot-r tires (prefer V-710's), agressive alignment without camber kits. K&N air filter, front sway bar and bushings. Thats pretty much it.
34 STS
Funded By: My Back Pocket
tua03332 is offline
Old 08-07-2007, 10:03 AM   #16
Nye
Nye's Avatar
Fan#: 29653
also was wondering what the service manual gave as specs for wheel alignment, etc. cause I know that some gm cars can put a camber kit on there car and still run stock class because there service manual says you can do that. Thanks for all of your help
Nye is offline
Old 08-07-2007, 11:15 AM   #17
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
The rules are so broad in many respects that you could drive a truck through them.
Things become very sticky and political at the National level, but a lot of the regions tend to be more relaxed.
For example, if an older car is damaged and needs body work (Corvettes, Opels and BMW 2002's come to mind) often OEM replacement parts are difficult to find. As a result, they often resort to fiberglass replacements. Depending on the manufacturer, the fiberglass is marginally lighter than the OEM.
Usually, a discussion amongst the drivers in that class takes place prior to the event or runs. If all the drivers agree to allow the car to remain in the same class, then the officials usually don't take issue with it.
With respect to upgrading with parts from an SVT - and I am not encouraging cheating, there are very few people out there that would recognize a difference. Of course, brakes would be pretty obvious, but if you took the suspension or the stock air box from an SVT and installed them on your car you will notice a difference, but I doubt anyone else would. Especially with a Ford part number stamped on them.
In H Stock, you would see some gain, but not enough to really set you apart.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 09-04-2007, 11:13 AM   #18
AePoloGuy08
Fan#: 49649
What I Drive: 2006 Black ZX5
FF Reputation: 1 AePoloGuy08 Good Standing Member
wow i am really confused or just stupid... you decide... What class would i be in with an cold-air intake, 2.5" cat back exhaust, cosworth header and flex/pipe, 17 inch rims with r rated tires, performance clutch and tranny and a 50 shot of nitrous.
AePoloGuy08 is offline
Old 09-04-2007, 01:11 PM   #19
tiresmoker
What bump stop?
tiresmoker's Avatar
Fan#: 20426
First off you can't run Nitrous at autocrosses, so you'll have to leave the bottle at home, or take it out at the event. That being said, are the tires R compound tires, or do you mean the Speed Rating is R? There is a huge difference.
But for the most part, I'm pretty sure you would be looking at FSP (F Street Prepared)
ST Crew #19
Old 09-05-2007, 06:50 PM   #20
BlkMamba03
BlkMamba03's Avatar
Fan#: 37662
What I Drive: 03 SVT F
FF Reputation: 3 BlkMamba03 Good Standing Member
Man i removed my rear seats and it thows me out of DSP!!! ouch I dont do it to win anyway!
BlkMamba03 is offline
