how to get svt performance out of a zetec? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-14-2006, 01:28 PM   #11
FocusRyderzx3
Fan#: 28657
What I Drive: 03 Liquid Grey ZX3
FF Reputation: 1 FocusRyderzx3 Good Standing Member
Originally posted by ouikikazz
svt has approx 145-155whp (it varies from car to car). The wtq numbers i totally forget tho.
like i said i could be wrong. i need to go back and look at FF they were doing dyno runs w/ an SVT, changing filters and adding a tune and they had the dyno numbers. must of red it wrong but oh well
I bleed liquid grey!!!!
FocusRyderzx3 is offline
Old 03-14-2006, 05:08 PM   #12
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
yeah, I think we discussed that article a while ago and came up with a conclusion that they were getting bum readings from the dyno
crazymechanic is offline
Old 03-14-2006, 07:03 PM   #13
chad_p71
Fan#: 22773
What I Drive: 2003 Pitch Black SVT
FF Reputation: 1 chad_p71 Good Standing Member
well i bought my zx3 focus because it was only 5500 @ 62000miles(dealer); I wanted a cheap car, with good gas mileage that had lots of aftermarket crap i could put on it. I wont be tradeing it for an SVT because they are more money than I wanted to get a car loan for and they are very difficult to find where I live. They are nice cars and I like the fact the the motor puts on 170 hp(at crank) on all motor, while at the same time being reliable and driveable. I would like to do the same to my car. Now that I am paying my car down, rather than trading it off and just going into debt some more, I am just going to have fun with the car I have and add parts to it, to see how fast I make it go down the quarter mile. Hopefully 15.5 this summer is my goal.
17 inch O.Z. Racing Ultraleggera Rims
chad_p71 is offline
Old 03-14-2006, 07:29 PM   #14
chad_p71
Fan#: 22773
hey crazymechanic thanks allot for your specs,
Im not familiar with variable cam timing, I have head about it before and have some basic ideas of what it is but I am not entirely sure. What exactly is it and how does it work?
What is the compression ratio of a SVT motor? The 00' Zetec has 9.6 to 1; which isnt too bad! But I think I still would like to deck the cylinder head for a little extra compression ratio. Do they sell the 'extra thin' head gaskets for zetecs? That gasket might give me a little extra boost in compression ratio too.
I am intrested in a cam change, but my car is a daily driver so I can't have anything too crazy.
On average what are stage 2 cams like, I dont want anything too lumpy or skitzophrenic. Any reliablity problems with aftermarket cams for this motor?
My only problem is with the computer tune, I will probably be adding a nitrous kit eventully and advancing my timing with no2 is a bad idea.
chad_p71 is offline
Old 03-14-2006, 08:14 PM   #15
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
VCT changes the cam's profile at a given point in the powerband, typically either causing both valves to open/close simultaneously (when before one would open before and close after the other) or changes the cam's duration/lift. This is accomplished by a solenoid on the camshaft that pushes the shaft over, moving a different lobe profile onto the valves. The benefit is the valves open further/longer at high RPMs, allowing the engine to breathe better at the top of the band while not sacrificing economy or drive quality at the bottom or middle of the band. Its basically the same as having a mild grind cam from idle to 3000-4000 RPMs, and then switching to a more aggressive profile from 4000 RPMs to redline.
AFAIK its not possible to swap a SVT head onto a standard Zetec block, but for what its worth there's other mods you could do that would yield more gains. You have to figure that all of the differences between the two engines only resulted in 40 more HP/TQ over a standard Zetec, so any given change (such as VCT) is only going to result in miniscule gains. Most of the SVT Zetec's extra power lies in the free-flowing intake/exhaust setup and higher compression ratio...VCT is something of icing on the cake.
SkaAddict is offline
Old 03-14-2006, 10:09 PM   #16
lanting90
Boosted
lanting90's Avatar
Fan#: 1901
What I Drive: 2003 Jetta 1.8T
Points 6,525, Level 52
Points: 6,525, Level: 52 Points: 6,525, Level: 52 Points: 6,525, Level: 52
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 2 lanting90 Good Standing Member
Buy-Sell-Trade Rating: (4)
Originally posted by Toolman00
[B]I'm not sure what lanting90 has for mods (I'm almost positive he doesn't have cams), but I matched up with him. My SVT has a few go-fast goodies. It's probably an unfair comparison because I had winter tires on at the time, but from a stop he clearly had the advantage. Once up to speed, I had the advantage. Nobody was "killing" anybody, but he pulled away quicker off the line and I was pulling when I was in 3rd - perhaps the rear tires that were installed backwards (directional tread) on lantings car helped him on the launch and hurt him at speed (you fix that btw?). It was all done in fun anyways. I know my car isn't the fastest. If I wanted a fun car, I'd find an inexpensive ZX3, gut the interior (remove back seat at least) and do a V8 conversion... probably should have went that route... be about the same price as my SVT with the goodies (what I'm looking at doing at least).
lol...that was a fun day..to bad we didn't really get to race, just playaround on teh highway on the friggen coldest day of teh year!!..lol..
o, and my mods were a CAI, 65mm TB, UDP, un-tuned cam gears, 2.5 flex, and MBRP cat-back.(i think that's all teh mods...o, and fouled plugs...lol...)
anyways, u def. had the advantage in the top end..and yes, i did switch those two tires around..
i'm gonna have to run u agian tho, got my race header on last week...adjusted the cam gears some...and dam this focus is loud...lol..
anyways...itz all in good fun...but i think w/ all the bolt-ons, u could prolly lay waste to a stock SVT..
Current:2003 VW Jetta 1.8T Wolfsburg
Past:
2003 EAP SVTF
2000 ZTS
2001 ZX3
lanting90 is offline
Old 03-15-2006, 06:58 PM   #17
Toolman00
Toolman00's Avatar
Fan#: 2744
What I Drive: 2000 Ford Expedition XLT 4x4
FF Reputation: 3 Toolman00 Good Standing Member
Cool! Yeah it was friggin cold! My car didn't like turning over that day, but it did eventually! We'll have to go for a ride in your car sometime. I want to see how much stiffer your setup is over the SVT.
I need to get tires mounted on my new rims so I can play! Hoping we get enough snow tomorrow so I can do it during the day. I hope the snow melts soon so I can have a fun because I SOOOOOOO want to start playing around again!
Give the toughest job to the laziest man and he'll find the easiest way to get it done.
Toolman00 is offline
Old 03-15-2006, 08:08 PM   #18
lanting90
Boosted
lanting90's Avatar
Fan#: 1901
no kidding!!it was like 50 last week, and last night is back to 19!!
i know how u feel..i'm finally getting some tires for my rims..i'm getting soem Kumho Ecsta Supra 711s 215/40 from tirerack for way cheap...all i gotta do is paint my 17s bronze, and get those thangs mounted...then plish/wax the car, and i'll be ready for WoW next weekend..
Past:
2003 EAP SVTF
2000 ZTS
2001 ZX3
Old 11-08-2006, 11:51 PM   #19
GZetec
GZetec's Avatar
Fan#: 36463
What I Drive: 01 White SE 4dr
FF Reputation: 1 GZetec Good Standing Member
i have those tires but for my stock wheels, and the tires are freakin awesome. nice choice!
GZetec is offline
