atx to mtx conversion - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-13-2006, 09:57 PM   #1
R1ck 22
R1ck 22's Avatar
Fan#: 26054
What I Drive: 2002 fort knox zts
FF Reputation: 1 R1ck 22 Good Standing Member
ok i have an atx sedan but i want to convert it to an mtx has this been done or can it be done what all would i have to change besids the tranny/ linkage/ ?ecu?
ZETEC Crew # 78
mods: spectre cai kamakize hedder mbrp exhaust enki 17's kenwood ddx 7015 kac 7202 and 10'' mtx 5500s c/f oem style hood poison body kit 1.25 drop springs
R1ck 22 is offline
Old 03-13-2006, 11:05 PM   #2
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
how many miles do you have on your car. Some people dont really think its worth it, and it might be better just to go out and find a mtx focus.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 03-13-2006, 11:15 PM   #3
Focus~Racer
Focus~Racer's Avatar
Fan#: 994
What I Drive: Black 2001 4-Dr ZTS... Oh the heck with it... As long as it's a Focus!! :)
FF Reputation: 1 Focus~Racer Good Standing Member
You need a NEW!! Flywheel to replace the flex-plate you have now.. A clutch, a pressure plate. a bearing set.. You need pedals, the hole in the firewall has to be knocked out. You need a Slave Cylinder to piggyback the brake master cylinder since the clutch is hydraulic. You may need a vacuum booster from the MTX. You need a different ECU and PCM.. Since the focus uses a PCM for the trans on both cars, You may need to take the bulb out of the stupid shift light..
To tell ya the truth I have an ATX 01 focus ZTS... It's not worth the trouble. there are 5 tranny shops in my neighborhood. The prices ranger from $3000 if I got the parts to $7000 if I just brought the car in and had them do it all!!!
Your better off trading your car in on a standard.. TRUST ME!!
If you make something Idiot Proof....
Someone, somewhere, will just make a better idiot....
98% of All Fords are Still On the Road Today!!!
The other 2% actually made it home!!
Focus~Racer is offline
Old 03-14-2006, 09:50 AM   #4
R1ck 22
R1ck 22's Avatar
Fan#: 26054
i thought about that but the problem is that i cant trade off the car becaust its got a salvage title bu if i could find a svt or a 4 door 5 speed for the right price then it might be worth looking into but i really dont need another car and i like the way mine is its kind of a sentimental thing i think
ZETEC Crew # 78
R1ck 22 is offline
Old 03-14-2006, 03:15 PM   #5
R1ck 22
R1ck 22's Avatar
Fan#: 26054
or mabye an engine swap how hard would that be??
ZETEC Crew # 78
R1ck 22 is offline
Old 03-14-2006, 06:02 PM   #6
Focus~Racer
Fan#: 994
take everything I just said plus add an engine.... you still need the ECU / PCM from the engine.. It's easier if your swaping the same thing.. But then again if its got sentimental value you may not see it as hard...
Old 03-14-2006, 07:43 PM   #7
R1ck 22
R1ck 22's Avatar
Fan#: 26054
yeah ill look for an engine the hardest part of that will be putting the peddels in
ZETEC Crew # 78
R1ck 22 is offline
Old 03-14-2006, 07:55 PM   #8
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
A lot of people who try this run into trouble after they get everything installed, because you have to go to a dealer and get your keys reprogrammed to match the PATS system on the new ECU and many dealers flatly refuse to do the programming for a wide range of reasons. Like everyone's saying...much easier to trade your car in and buy one with a MTX. Barring that, I'd look for a junked Focus with a MTX that has keys, the ECU and the manual transmission...pull the transmission and related parts, ECU and ignition cylinder with keys and transplant them into your Focus...that would skip having to find a dealership that would reprogram the PATS.
As far as putting the pedals in, it wouldn't be that hard. You'd just need the brake/clutch pedals and the bracket they're attached to (plus all of the wiring and switches attached to the bracket,) you'd need to drill three holes for the clutch master cylinder to pass through...its mostly inside the cabin, there's two hydraulic lines running in and out plus a bolt hole in the middle...actually, the pedals would be the easiest part of the job in comparison with the rest.
This would be a lot of work if you've never dropped a transmission before or don't have much experience as a mechanic, its not something that could be accomplished over the weekend (at least not by someone without experience/training) and you'd stand a pretty good chance of screwing your car up to the point where you couldn't fix it. Remember, its always cheaper to pay someone to do the job right the first time than it is to pay them to fix all of your mistakes after you've tried and failed.
SkaAddict is offline
Old 03-14-2006, 07:58 PM   #9
R1ck 22
R1ck 22's Avatar
Fan#: 26054
hmmm anyone got a wrecked 5 speed for sail j/k what years would work with my 02 also would it be worthit to do like a duritec or svt swap??
ZETEC Crew # 78
R1ck 22 is offline
Old 03-14-2006, 09:31 PM   #10
Focus~Racer
Fan#: 994
O.M.G "Frogman283" I forgot about that!!
When I went to the ford Dealership in my town to ask them if they could do the work on my car.. (I know, I know.. BIG BIG $$$$$$$ if they actualy would do it..) But I figured hey who better to do it right??? Anyway they told me that there system wouldn't allow the new keys to be programmed or something along those lines.. SO you WILL run in to problems with that.. And trust me... The P.A.T.S is NOT something you can bypass... If it was it would be a waist of time.. That thing runs through so many systems...
Your only hope would be to get [2] Keys at least from the DONATE car so you would be able to make new keys if need be.. As I understand it even if you pull the PCM / ECU the code for the keys will remain.. So if you had the keys for the motor you would be fine.. But you would then obviously have to change the ignition and door locks.. But if your that hard off on keeping the car I guess it would be a small price to pay.. That would be the least of your work..
