Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 03-09-2006, 10:04 AM   #1
bushmasterguy
bushmasterguy's Avatar
Fan#: 16812
What I Drive: 2004 Ford Focus SVT - CD Silver
FF Reputation: 1 bushmasterguy Good Standing Member
Kent Cam Gear Adjusting for SVT - How Difficult?
For those of you who actually have a SVT Exhaust Cam Gear how hard is it to adjust it once it is installed?
I had a mechanic install a Kent Cam Gear and set it to 0 degrees. Now I am taking it to the dyno for some runs and then Tom with Focus Power is going to send me a revised tune to match my new Air/Fuel ratios (Thanks Tom!).
So is it hard to adjust the Exhaust Cam Gear once it is installed? The Dyno is charging me for the runs and then my mechanic will also charge me to do the adjusting. Can I cut costs and do the adjusting myself? For the record I am not a mechanical genious but I am not totally helpless. For example I installed my Steeda Short Shifter myself.
The "Go":
Focus Central 65mm TB, Steeda SRI, FC 2 PC Pulley Kit, "Tom's Tune", Steeda Short Throw Shifter. MSD Coil and Wires, Steeda Strut Tower Brace, Clutch Masters Stage III, Kent Alloy Exhaust Cam Gear, Borla Exhaust, Quaife Diff, Fidanza Flywheel, Denso Spark Plugs.
The "Show":
TYC Altezza Tail Lights, Steeda Emblems, Euro Grill, RT Brake Caliper Lacquer Blue
bushmasterguy is offline
Fan#: 1
Old 03-09-2006, 11:17 AM   #2
Reedicus
Fan#: 30035
What I Drive: 2003 2.3
FF Reputation: 1 Reedicus Good Standing Member
Buy-Sell-Trade Rating: (4)
I haven't done this so I can't help, but my impression was that it is simple enough to do while the car is still strapped down on the dyno, taking only a few minutes. Please post up pic of the before and after dynos. I have been thinking of doing this, but recently spoke to Tom who pretty much said "don't waste your time"... something still makes me want to try. good luck
Reedicus is offline
Old 03-09-2006, 12:53 PM   #3
bushmasterguy
Fan#: 16812
I read in Focus Performance Book that they got 7 hp and equivalent torque through out the power band on a stock svt with a cam gear. Plus lighter weight less rotating mass than the stock cam gear. That is what convinced me to do it.
The "Go":
The "Show":
Old 03-11-2006, 09:59 PM   #4
svt2nv04
SVT Fanatic
svt2nv04's Avatar
Fan#: 16592
What I Drive: 2004 Sonic Blue SVT; 1572 of 1978
FF Reputation: 31 svt2nv04 Great Standing Member
Buy-Sell-Trade Rating: (10)
yup that sounds right. i've heard it's a great mod. how much is that mechanic charging you to adjust the cam gear? if it's not too much i'd just go with him doing it for you.
2004 SONIC BLUE SVT; 1572 of 1978
Audiophile 9006, moonroof, HIDS
svt2nv04 is offline
Old 03-12-2006, 07:35 AM   #5
bushmasterguy
Fan#: 16812
After a little research (called Focus Sport and talked to a technician that convinced me I could do it) and experimentation I decided to do it my self. All you need is a T55 Torx Bit with Rachet to turn the cam gear and a allen wrench to lossen the cam for adjustment.
I tried it easy as pie and will save me his $65 per hour rate. The Dyno is going to cost me $150 for the first hour (about 3 runs) and $125 per hour after that. I reserved the Dyno for 3 hours but more than likely go 1.25 hours is what we are estimating. So that is $181.50 for the Dyno. Adjusting the cam gear in is trial an error.
I am going to start at -2 degrees retard and go from there.
The "Go":
The "Show":
Old 03-12-2006, 12:03 PM   #6
2004SVTAutoXer
2004SVTAutoXer's Avatar
Fan#: 19123
What I Drive: BMW 335i Coupe, 79 CJ-7
FF Reputation: 26 2004SVTAutoXer Great Standing Member
how much does the gear cost?
SVT Squad #133 - Traded for 2008 Subaru Legacy 2.5i Limited in Quartz Silver Metallic - Traded for 2008 BMW 335i Coupe with stock twin turbo Juiceboxed 500whp and 500wtq of N54 goodness.
2004SVTAutoXer is offline
Old 03-12-2006, 12:05 PM   #7
bushmasterguy
Fan#: 16812
$145
The "Go":
The "Show":
Old 03-12-2006, 12:37 PM   #8
Goat Roper
The Godfather
Goat Roper's Avatar
Fan#: 8634
What I Drive: 2003 Black ZTS
FF Reputation: 6 Goat Roper Good Standing Member
It is very easy to do. Simply loosen the adjustment bolts slightly. Put a ratchet on the cam bolt then ever so gently tap or apply just enough pressure to move it one degree in either direction.
Run a baseline dyno
Retard or advance one degree. Re-run dyno.
If you gained HP, take it another degree in the direction you started. Re-run dyno.
If you lost HP, take it back the opposite direction (if you went to -1 and lost HP, take it to +1). Re-run dyno.
Same principal, if you gain HP, take it another degree. If you lose HP, you know that TDC is where its at.
Keep in mind to not make a whole bunch of runs at once (it only takes a minute to adjust the gear). You will heat saturate your motor, which will make it lose HP. So you end up think you are losing HP when in actuality you may be adding it.
ALWAYS REMEMBER TO TIGHTEN THE ADJUSTMENT BOLTS UP BEFORE EACH DYNO RUN!
If you have a mechanic actually do this for you, you will be kicking yourself in the head afterwards. It is more difficult to replace a light bulb than to do this.
Scott Sweeney Photography
Goat Roper is offline
Old 03-12-2006, 03:11 PM   #9
focusfrost
Fan#: 20693
What I Drive: svt 2003 pitch black euro
FF Reputation: 1 focusfrost Good Standing Member
bushmasterguy keep us posted on your results of this mod.
focusfrost is offline
Old 03-12-2006, 03:23 PM   #10
bushmasterguy
Fan#: 16812
Will do. I am going to be at the Dyno all tommorrow morning. Can't wait! It is like waiting for Christmas morning.
The "Go":
The "Show":
