Lean Less: The Inside Scoop on Anit-Roll Bars from GRM - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > General Racing Chat
General Racing Chat Use this Forum to discuss everything from launching off the line and four wheel drifts, to telling your favorite race tale. (Posting Rules)
Old 03-08-2006, 09:51 PM   #1
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
What I Drive: 2003 SVTF, 2003 G35, 2001 Audi S4
FF Reputation: 5 DirtyDeeds Good Standing Member
Lean Less: The Inside Scoop on Anti-Roll Bars from GRM
I thought I knew everything I needed to know about anti-roll bars. This article taught me a thing or two I didn't know. If you think adding a 1mm thicker bar won't make much of a difference, read on...
http://grmotorsports.com/news/012005...rs.php#more-78
DirtyDeeds is offline
Old 03-08-2006, 10:44 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Dang man, you're just full of em tonight!
Great reading again.
WD40 is offline
Old 03-08-2006, 10:47 PM   #3
Logan175
Logan175's Avatar
Fan#: 22323
What I Drive: The focus got torched now we have a 3 series BMW
FF Reputation: 1 Logan175 Good Standing Member
wow...
so much good info brain meltdown
Logan175 is offline
Old 03-08-2006, 11:21 PM   #4
Oni
Oh yeah!
Oni's Avatar
Fan#: 24899
What I Drive: An unloved Focus
FF Reputation: 4 Oni Good Standing Member
Buy-Sell-Trade Rating: (6)
Excellent article. I wonder if SVT knows approximately what the precentage is for the stock TLLTD. I'd be interested to see what the H&R 24mm rear sway bar does for that factor since that's most likely the sway bar I will upgrade to. And I wonder if the moment arm is different in length than the OE.
SVT Squad #80
1365 of 3985
Born: 04/25/2003
formerly known as the member ilcowil
Oni is offline
Old 03-09-2006, 10:02 AM   #5
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
Just as an interesting side note, Sway-bars are used by manufacturers in very different ways. BMW for instance, believes in stiffer springs/dampers with relatively weak sway-bars whereas Lotus uses a lot of sway bar with a relatively soft damper/spring setup. Both are great handlers, but shoot for the same goal with different methods.
So many people forget how much of an interconneted system it all is, but of course not many companies would sell (or customers would buy) nothing but a front to back full suspension upgrade... After all, even an upgrade in tires could totally change the TTLD.
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
Old 03-18-2006, 08:50 AM   #6
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
Points 1,311, Level 20
Points: 1,311, Level: 20 Points: 1,311, Level: 20 Points: 1,311, Level: 20
Level Up 11% Completed
FF Reputation: 5 finalley Good Standing Member
Adjustable endlinks??
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
Old 03-18-2006, 03:08 PM   #7
Oni
Oh yeah!
Oni's Avatar
Fan#: 24899
Is that a question or what? I know there are adjustable end links on some sway bars, but as far as I know, H&R's are fixed. I was stating I wonder if the moment arm on the H&R sway bar is the same as OE which would mean you'd only increase the stiffness of the bar through the diameter enlargement - not the moment arm increase in length and the diameter.
SVT Squad #80
1365 of 3985
Born: 04/25/2003
Oni is offline
Old 03-18-2006, 03:13 PM   #8
dwdgsi03
dwdgsi03's Avatar
Fan#: 2298
What I Drive: 2000 Midship Runabout
FF Reputation: 1 dwdgsi03 Good Standing Member
Oh wow, so going to a 24mm H&R bar is going to make a WORLD of difference. Now I can see how just adding to the rear can disrupt the cars balance so much.
(\_/) Copy this bunny to your sig because he`s better than the "other bunny"
(O.o)
dwdgsi03 is offline
Old 03-18-2006, 11:33 PM   #9
finalley
Fan#: 386
if the HR bolts back up to the stock location with the stock bolts wouldn't the arm length be the same??
finalley is offline
Old 03-19-2006, 03:55 AM   #10
Oni
Oh yeah!
Oni's Avatar
Fan#: 24899
Not necessarily. The location of the bolts and mounting points for any aftermarket sway bar should match up to the OE unless fabrication is required. If the H&R sway bar were to have a longer moment arm, all it would simply do is readjust where the bar is located under the car by possibly a few centimeters. Basically, if you can imagine the OE bar is fixed but has some space around it, then the moment arm of the aftermarket sway bar can be lengthened or shortened as it has room to be moved forward and back in the empty space.
SVT Squad #80
1365 of 3985
Born: 04/25/2003
Oni is offline
