msd digital window switch will it work with the coil on plug setup on durtech - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-21-2006, 07:39 PM   #1
chetn20
chetn20's Avatar
Fan#: 31134
What I Drive: saleen 2004 red n2o focus
FF Reputation: 1 chetn20 Good Standing Member
Post msd digital window switch will it work with the coil on plug setup on durtech
dos any body know if msd digital window switch works on the durteck switch is new and it is not on their web site yet but some shop have them
USE A BIGGER HAMMER NEXT TIME
MODS: 75 HP WET NOS SYS COS WORTH D-POWER STAG ONE AND TWO MAG FLOW 2.5 CAT BACK SPEC STAG 3 CLUTCH FIDANZA ALUMINUM FLYWHEEL T2 TORSION DIFFERENTIAL CFM TORK MONT N2 RACE CRAFT SUSPENSION
chetn20 is offline
Old 02-21-2006, 10:58 PM   #2
dtec04
dtec04's Avatar
Fan#: 13978
What I Drive: 2004 grey duratec zx3
FF Reputation: 1 dtec04 Good Standing Member
Yes, it will work. You just need a tach driver.
Supertech 11.6:1 pistons, Eagle rods, Crane Stage 3 cams, Ranger Crank, 39lb svt injectors, 4.0L ranger/Explore Maf sensor, Cosworth Manifold, Cosworth flywheel, Cosworth clutch, and 4.06 gearing
dtec04 is offline
Old 02-22-2006, 05:58 PM   #3
chetn20
chetn20's Avatar
Fan#: 31134
called msd tech line today to check with them cause the shop i got it from say no other components needed msd says hookup wire to negative side of one coil for tach signal
chetn20 is offline
Old 08-08-2006, 08:05 AM   #4
netdrgoon
netdrgoon's Avatar
Fan#: 26752
What I Drive: 2005 Focus Zx3 se D20 M5 - blazing
FF Reputation: 2 netdrgoon Good Standing Member
Not to bring back the dead, but um, which wire on the COP is the negative?
2005 Focus Zx3 se D20 M5 - "Helios" - blazing copper
intake, header, exhaust, xcal2 tune, !CMC, cams, suspension, nitrous, torsen, spec lw flywheel and stg1 clutch
home brew turbo in the works
netdrgoon is offline
Old 08-08-2006, 05:38 PM   #5
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
should be the one on the right of the coil
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 08-12-2006, 12:38 AM   #6
netdrgoon
netdrgoon's Avatar
Fan#: 26752
Okay, I tried the one on the right (whereas, you are looking at the coil, and the connectors are at the bottom). I spliced into the wiring harness that clicks onto the coil with a little splicing thingy...no signal...(green wire with black stripe). I did the same on the one with the green wire on the left, my window switch tach activated. I am VERY glad this thing has an rpm display or otherwise someone hooking it up wouldn't know it was operational. Kinda nifty.
So it was one or the other, and on my car the one that worked was on the left..lol. I wish they had just marked it!
Old 09-06-2006, 10:32 PM   #7
fallingtheory
Fan#: 38380
What I Drive: 2005 Ford Focus Black ZX3
FF Reputation: 1 fallingtheory Good Standing Member
i tried this...the thing is it does get a signal. but it read nothing as far as rpms. it didnt go past 1000. what am i doing wrong??
fallingtheory is offline
Old 09-06-2006, 10:53 PM   #8
wickedgreyzx3
Fan#: 34204
your tach needs to be set to 1 cylinder mode, or just do what everyone else does, tap into the crank sensor wiring
