#1 | ||||
ATX Shifts Hard After Fluid and filter change
I bought my 2k2 zx3 with 51k on it about two weeks ago. I decided to do some preventative maintenance and I changed the automatic transmission fluid and filter. I used valvoline Mercon V. Now my car shift hard in almost every gear. What should i do? What went wrong? Thanks for any replies.
Remove Advertisements |
Fan#: 1
#2 | ||||
Improper fluid level can cause hard shifting. Are you sure you are checking the fluid level when the fluid is completely warmed up? How many miles have you driven it since you changed the fluid?
#3 | ||||
I have checked the fluid warmed up, i will double check tonight, I have driven it maybe 500 miles. I don’t understand it, the car shifts consistently it doesn’t slip just it shift hard and jerks the car.
#4 | ||||
I believe the Focus ATX "learns" it's shifting over time, but in 500 miles that should be way over and done with (assuming the new fluid perhaps has a different "slipperyness" than the old.)
Ford Sez: "This vehicle is equipped with an adaptive Transmission Shift Strategy. Adaptive Shift Strategy offers the optimal transmission operation and shift quality. When the vehicle’s battery has been disconnected for any type of service or repair, the transmission will need to relearn the normal shift strategy parameters, much like having to reset your radio stations when your vehicle battery has been disconnected. The Adaptive Transmission Strategy allows the transmission to relearn these operating parameters. This learning process could take several transmission upshifts and downshifts; during this learning process, slightly firmer shifts may occur. After this learning process, normal shift feel and shift scheduling will resume." Perhaps disconnecting the battery for 15 minutes to "force" a relearning of the shift strategy might be worth a try? A bit of a long shot, but it's easy enough to do. But remember, if you do this, it will have to relearn the idle as well, so don't be suprised if it idles poorly at first after you do this. Your manual has a simple proceedure to speed up the learing; however, if you just drive it it will re-learn the idle as well, it just might take it a bit longer. Again, Ford Sez: "Because your vehicle’s engine is electronically controlled by a computer, some control conditions are maintained by power from the battery. When the battery is disconnected or a new battery is installed, the engine must relearn its idle and fuel trim strategy for optimum driveability and performance. To begin this process: 1. With the vehicle at a complete stop, set the parking brake. 2. Put the gearshift in P (Park) (automatic transaxle) or the neutral position (manual transaxle), turn off all accessories and start the engine. 3. Run the engine until it reaches normal operating temperature. 4. Allow the engine to idle for at least one minute. 5. Turn the A/C on and allow the engine to idle for at least one minute. 6. Drive the vehicle to complete the relearning process. • The vehicle may need to be driven 10 miles (16 km) or more to relearn the idle and fuel trim strategy. • If you do not allow the engine to relearn its idle trim, the idle quality of your vehicle may be adversely affected until the idle trim is eventually relearned. When the battery is disconnected or a new battery installed, the transmission must learn its adaptive strategy. As a result of this, the transmission may shift firmly. This operation is considered normal and will fully update transmission operation to its optimum shift feel. If the battery has been disconnected or a new battery has been installed, the clock and the preset radio stations must be reset once the battery is reconnected." |
#5 | ||||
Illegal Alien
wow, very good info to know, where did you find it?
<--Jonathan--> I've been absent from FF for too long... |
| Thread Tools | |
| Display Modes | |
