Fixed the coolant leak today, pics - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-23-2011, 02:14 AM   #61
MURDEREDOUT
MURDEREDOUT's Avatar
Fan#: 84874
What I Drive: 2003 MURDEREDOUT SVT
FF Reputation: 2 MURDEREDOUT Good Standing Member
Can't I just RTV-it and fill the system with an vacuum airlift?!
Really?! A bleeder...that's held in with a Jesus clip and sealed with an O-ring? That's what phantom I've been chasin'!
(just repl'd the T-stat per PM and R&R'd the housing gasket- figured it that anoying little weepage is gotta be one or the other-)
Pressurized the system and it held at <13psi; starts spittin' at 14-16- can't see it with soapy water... and and then holds at 17psi!!!
I put an airlift on the system figuring maybe I can see where the soapy water's gettin drawn IN!!! WTF! Put 1/2 gal of H20 ('Cause I'm not gonna WASTE coolant, right?!)..then pressure test to 15 with a mirror I'm starin' at: 'WTF is that for?!' NOTHING!
is this PART SALE legal?: http://photobucket.com/SVT-performanceParts
ASE since 1997; AAS Auto Tech. & BS Auto Eng. Mgt. FSU; MS Quality Mgt. EMU
"Got my 'low-low' slammed like pancakes, rollin' in sy-z-ryup- f#@k what ya hear-z-ryup" - Ice Cube
MURDEREDOUT is offline
Old 06-20-2011, 05:38 PM   #62
johnny206
Fan#: 65907
What I Drive: 2004 ZX3
FF Reputation: 1 johnny206 Good Standing Member
I'm out of the O-rings. Good luck to you all!
johnny206 is offline
Old 01-17-2012, 07:52 PM   #63
SWEGER
SWEGER's Avatar
Fan#: 88926
What I Drive: 2003 Infra-Red ZX5 SVT
FF Reputation: 1 SWEGER Good Standing Member
Subscribed for future reference...
2003 Infra-Red ZX5 SVT - Cheap Spectre intake (don't judge, was on there when I got it), Hawk HPS pads front/rear, Russell SS lines, Goodyear Eagle GT 215/45/17
"If guns cause violence, then all of mine are defective" - Ted Nugent
SWEGER is offline
Old 04-16-2012, 07:48 PM   #64
Biggiek
Fan#: 89305
What I Drive: 04 Infrared SVT
FF Reputation: 1 Biggiek Good Standing Member
If anyone has O-rings for the silver plug, let me know I need one!!!
Biggiek is offline
Old 04-17-2012, 09:19 PM   #65
Biggiek
Fan#: 89305
Can you do this while on the vehicle?
Biggiek is offline
Old 05-03-2012, 04:03 PM   #66
svtferrari
Fan#: 62287
What I Drive: 04 black svtf
FF Reputation: 1 svtferrari Good Standing Member
Does anyone happen to have any spare o-rings? Mine just sprung a leak :(
svtferrari is offline
Old 05-14-2012, 02:03 PM   #67
total_telecom
Fan#: 83049
What I Drive: 2004 se wagon 2.0L
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 total_telecom Good Standing Member
Originally Posted by JohnMichael View Post
It's out of the thermostat housing...let's see if I can get some better pics up.
That's a top shot of the thermo housing, it's underneath towards the front of the housing...
The above pic is of the hole where the plug goes and housing...if you need some more shots just yell!
Rockauto had the whole housing with upper hose neck and thermostat all in one unit for like $40. Just unbolt the old and bolt in the new, its all assembled in one unit!
total_telecom is offline
Old 05-24-2012, 09:17 PM   #68
coxyboi
Fan#: 95666
What I Drive: 2003,silver,ST170
FF Reputation: 1 coxyboi Good Standing Member
Am I right in thinking the thermostats housing comes in 2 part's and seals the tstat inside, what is used to seel both part's? Any one got dissected pic's? And this washer/plug that every one had prob's with is it at the front on the under side of the pipes? Schematics would help thanks
coxyboi is offline
Old 10-25-2012, 10:13 PM   #69
Incognito27
Incognito27's Avatar
Fan#: 34939
What I Drive: 2003 Ford Focus ZX5 Premium - White
FF Reputation: 3 Incognito27 Good Standing Member
SO i have a leak also.... However based on this thread i am more confused at the end than i was at the beginning
I see this question raise a few time with no affirmative answer " Does only the SVT version have the Plug with a O-ring that fails?"
May i have an answer to this please :D
I have a 2003 Focus ZX5 premium, i replaced a hose with about a 3/4 inch diameter tot he t-stat house already , but have a leak under the t-stat houseing it seems as thats the only place i see coolant leak and hit the ground.
Do i need to :
A) look for a plug with o-ring ?
B) replace the front part of the houseing with the 3 screws and gasket
c) or change the who damn thing because i can't figure out where the coolant is coming from
d) go suck a lemon and complain about it? lol :P
Incognito27 is offline
Old 10-25-2012, 11:04 PM   #70
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Forum Activity 5%
The SVT model is the only Zetec engined version that has the coolant temperature sensor in the thermostat housing that senses the fluid temperature directly. It uses an O-ring to seal the sensor in the thermostat body as shown in the pics.
The "normal" Zetec (i.e your ZX5) uses a cylinder head temperature (CHT) sensor that measures engine coolant temperature indirectly; it measures the temperature of the metal of the cylinder head near the coolant passages. The CHT sensor is located by the alternator (rear passenger side of the motor). There is no sensor fitting near the thermostat housing for your car and thus no O-ring.
Two different methods of doing the same thing - measuring engine temp.
Therefore, only the SVT has the O-ring that fails. However, the normal Zetec fails in its own way - the much larger sealing O-ring between thermostat housing and cylinder head fails or the housing cracks and leaks or a combination of both. It is theorised this is usually due to the valve cover gasket leaking and seeping oil down the side of the head by the housing. It's a common problem whatever the cause.
Do i need to :
a) No.
b) No.
c) Yes. Leak is likely between thermo housing and head.
d) Umm...No comment.
BC_ZX3 is offline
