Old 01-06-2009, 11:52 PM   #41
Zeromus
Zeromus's Avatar
Fan#: 61367
What I Drive: 03' Torreador ZX5
FF Reputation: 4 Zeromus Good Standing Member
Originally Posted by mderemer View Post
I just did this fix today. Remember that there is no such thing as too much o-ring lube.
So for under $20 and an hour of time I saved $550, which is what Bonnell Ford wanted to replace the thermostat housing. This of course wouldn't have fixed the problem.
FYI, I have a 2003 with 80k miles on it.
thats what she said.
yeah i went to ford and the "prescribed" a ~$400 for a ~$35(housing) and a~$25 VC gasket fix. i told them ,"give me back my keys dammit!"
...made by those, weakest of beings...made with wisdom acquired because of that weakness.
Zeromus is offline
Old 01-17-2009, 04:20 PM   #42
Joshuasvt
Joshuasvt's Avatar
Fan#: 27135
What I Drive: '03 Black/Red Flake SVT #1218
FF Reputation: 3 Joshuasvt Good Standing Member
Well The O-ring wasn't as bad as I thought it would be. I just pryed it on using a flat tip screw-unwinder. Took all of 30 sconds. I also added the 180 deg CFM thermostat while I was at it...;)
-JT
Joshuasvt is offline
Old 01-28-2009, 04:17 PM   #43
SVTQC
Fan#: 60781
What I Drive: svt 3dr
FF Reputation: 1 SVTQC Good Standing Member
mine is leakin now
looking for the 2 o-ring metric since my bottom leak as well
send quote please shipped to H7G 1C5 in canada
SVTQC is offline
Old 01-30-2009, 10:52 AM   #44
jdetrana
Fan#: 11655
What I Drive: 2002 Infra Red SVT
FF Reputation: 1 jdetrana Good Standing Member
Do you still have any of those o rings left? If so, how much do you want for 2? John, Alexandria, VA
jdetrana is offline
Old 02-21-2009, 01:14 PM   #45
ike34
ike34's Avatar
Fan#: 61769
What I Drive: 2004 Comp Orange SVT ZX5
FF Reputation: 1 ike34 Good Standing Member
I just replaced mine o-ring today, it was pretty simple, and didnt take long.
I bought a 10 pack of Viton O-rings from Mc Master, they are metric, they are 7mm I.D. 13mm O.D. and 3mm width, Ill part with 8 of them, Im going to keep one for a backup.
If anybody would like one let me know.
ike34 is offline
Old 02-23-2009, 02:37 PM   #46
focusben
focusben's Avatar
Fan#: 2831
What I Drive: 2002 SVT Focus
FF Reputation: 1 focusben Good Standing Member
I too had mine o-rings replaced a month ago. I had HTPerformance mail them to me, and I had the dealership do it for me. The plug was *way* seized so it's a good thing I didn't do it myself. About an hour's work but it's better than spending more for a new thermostat housing.
2002 SVT Focus (#1679 delivered June 4th, 2002)
Sonic Blue, Audiophile, Sunroof, Winter Package, Premium tinted glass, CM Stage 1, Fidanza FW.
223,000 kms and climbing...
focusben is offline
Old 06-07-2009, 12:51 PM   #47
Nate12
Fan#: 65801
What I Drive: 2002 Focus SVT
FF Reputation: 1 Nate12 Good Standing Member
Viton - O' Ring
IKE34 - Do you still have the 7mm Viton O'Rings? I've got a 2002 SVT w/ the coolant leakage issue. I'd be interested in taking a couple off your hands.
Thanks
Nate12 is offline
Old 10-21-2009, 12:43 PM   #48
sorty
Fan#: 69323
What I Drive: 2004 Comp Orange SVT Euro
FF Reputation: 1 sorty Good Standing Member
My 2002 SVT is leaking from the plug. Anyone with 7mm O rings willing to part with a couple???
John
sorty is offline
Old 11-30-2009, 10:16 PM   #49
muthagoose00
muthagoose00's Avatar
Fan#: 53800
What I Drive: 2003 CD Silver SVT hatch
FF Reputation: 3 muthagoose00 Good Standing Member
is this the proper o ring replacement?
http://www.mcmaster.com/#9263k718/=4qir5x
if not where can i order the rings i need to fix the leak plus pick up a new thermostat....
Also should i get a 195 or 180 thermostat for my 03 SVT?
Thanks
muthagoose00 is offline
Old 12-12-2009, 10:30 AM   #50
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 racer1735 Good Standing Member
Either my plug is leaking, or brake fluid is dripping from above it, running down onto it and onto the floor? My plug appears to be flush with the bottom of the housing, could this be the case? If so, how the heck do you get it out?
Reason for thinking this is, I DO have a leaking clutch master cylinder and am finding fluid on the ground under the center of my car ('04 SVT, 107,000 miles). It feels and smells more like brake fluid than coolant. Looking up under the car, the fluid is running down the passenger side of the bellhousing, starting at a point directly below that darned plug. And the plug appears to be moist, as well. But wouldn't know what would be above the housing that would drip/leak??
Also, regarding the clip that holds the plug in, do you access it from below the car? And which way does it pull (to the front? towards drivers side, etc.?)
Suggestions? Slave cylinder is on the driver side of the housing, correct? And it wouldn't necessarily leak out the front by the plug, would it? I do have a master cylinder on order.
When you've run out of mods, it's time to get something new.
racer1735 is offline
