Fixed the coolant leak today, pics - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-09-2008, 08:26 PM   #31
FordloverSVT
Fan#: 55092
What I Drive: 2003 SVT ZX5
FF Reputation: 1 FordloverSVT Good Standing Member
Originally Posted by brawls43 View Post
If you can see what color yours has, add the same type, green or possibly yellow. Do not use the orange DexCool for GMs.
Sidenote: The proper size O-ring to use is actually a METRIC o-ring. Remember that Ford converted all its cars to Metric, not to mention the Focus was originally designed in Europe, where metric is the standard. After reading some people used #203 and some used #202, I checked into the metric's and there happens to be a standard metric size right between a #202 and #203. Its a 7mm ID, 13mm OD, 3mm cross-section. I got mine in Viton and of course have some left over. It went back in easily and haven't had a leak since. If you need one, PM me and I'll drop one in the snail mail for you.
Sorry, I'm now out of the o-rings I bought, they can be ordered from places like McMasterCarr.
I just did this, and ordered the metric oring from mcmastercarr. I looked around at all the local automotive parts shops, even a few 'specialty' shops that I was told might have metric o-rings, with no luck.
After getting the o-rings, I switched mine out in about 10 minutes. The metric o-ring fits really well without having to force it. about 1/2 gallon of coolant comes out, but it's a fairly quick switch.
FordloverSVT is offline
Old 06-15-2008, 01:10 PM   #32
windaddiction
Fan#: 48960
What I Drive: 2003, Black, ZTW
FF Reputation: 1 windaddiction Good Standing Member
I just replaced the whole housing..... the large or ring where it seals to teh head was blow, the plasctic had cracked. 102$ from ford for a new new one, while i was in there I also repalced my leaky valve cover gasket... this was an easy job though only took an houe to do both, thanks FF
windaddiction is offline
Old 10-15-2008, 03:37 PM   #33
johnnySV
Fan#: 34836
What I Drive: 2000 ZX3, Silver
FF Reputation: 1 johnnySV Good Standing Member
my 2000 ZX3 is bleeding coolant and the thermostat housing is drenched. how can I determine what the cause of the leak is?
does the 2000 ZX3 have this plug?
what replacement parts should i have on-hand if i am going to attempt a fix?
thank you,
jSV
johnnySV is offline
Old 10-15-2008, 03:48 PM   #34
SVT_ME
SVT_ME's Avatar
Fan#: 53618
What I Drive: '02 Ranger XLT- '08.5 MS3 GT
FF Reputation: 7 SVT_ME Good Standing Member
If it's coming from the housing, it is probably a cracked housing or bad gasket.
[/QUOTE]
[/QUOTE]
I don't think it has the plug. but i could be mistaken.
New housing, gasket and thermostat (Hoses to, depending on how bad yours are degraded). Take the housing off and verify it is not cracked. Take care to check the gasket for any abnormalities.
That's how I would start.
SVT_ME is offline
Old 10-15-2008, 05:36 PM   #35
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
> What color/type coolant should be used for the 2000 Foci? I read Green. Is this correct?
Try this Motorcraft antifreeze/coolant reference chart:
http://www.fcsdchemicalsandlubricant...ckref/scuc.pdf
penguin is offline
Old 10-18-2008, 04:04 PM   #36
poisonivory
poisonivory's Avatar
Fan#: 898
What I Drive: 2003 Black Focus SE
FF Reputation: 1 poisonivory Good Standing Member
i'm now getting a coolant leak on my 2003 Zetec. I changed my battery last week and noticed the coolant was low, so i topped it off. Today I pulled out of the driveway and noticed what looked like a like spot. When I got back home, I popped the hood and sure enough the coolant reservoir was damn near empty after only a week or so.
I got a little confused reading this thread. So only the SVT's have the plug with the O-ring?? What do I need to do to fix the leak on a Zetec? And i'm a total newb to DIY'ing, so saying thermostat housing means nothing to me. lol Any pics of this process on Zetec like JohnMichael provided for the SVT?
Thanks in advance.
2003 Black Focus SE
Debadged-20% tint-Shorty antenna- SVT Dampers- KW Springs-MBRP catcback- Euro Upper & Lower grilles- Red billet emblems.
poisonivory is offline
Old 11-01-2008, 05:36 PM   #37
mderemer
Fan#: 54127
What I Drive: 2003 Red SVT
FF Reputation: 1 mderemer Good Standing Member
I just did this fix today. Remember that there is no such thing as too much o-ring lube.
So for under $20 and an hour of time I saved $550, which is what Bonnell Ford wanted to replace the thermostat housing. This of course wouldn't have fixed the problem.
FYI, I have a 2003 with 80k miles on it.
mderemer is offline
Old 11-02-2008, 10:01 PM   #38
LongDucDong
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
FF Reputation: 10 LongDucDong Great Standing Member
I had to order the whole plug from Ford as the o-ring wasnt sold seperately. It will be here on Tuesday and I get to have "fun" tackling it.
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
Old 11-04-2008, 12:31 AM   #39
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
I still have the #109/#203 Viton o-ring replacement kits available. If anyone needs them please contact me!
HTPerformance is offline
Old 01-07-2009, 12:00 AM   #40
brawls43
brawls43's Avatar
Fan#: 11151
What I Drive: An Orange EAP
FF Reputation: 3 brawls43 Good Standing Member
Just a reminder that the metric o-ring fits better. 7mm ID, 13mm OD.
SVT Squad #225
brawls43 is offline
