Fixed the coolant leak today, pics - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2006, 04:03 PM   #11
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'How To' Archive......
Chad (S2)
S2 is offline
Old 11-23-2006, 10:25 PM   #12
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,656, Level 78
Points: 14,656, Level: 78 Points: 14,656, Level: 78 Points: 14,656, Level: 78
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 90 goinloco1 Excellent Standing Member
if i recall correctly only the svtf has the plug.
of course my plug leaked, fixed that, then the housing cracked awhile later. ordered a new housing, the wrong one was sent. the plug hole was molded shut and so was the top sensor hole. i modified it and drilled the top sensor hole and used a coping saw to cut the grooves for the sensors keeper. no more worrying about the plug leaking! altho the sensor was a pita, the old oring fit loose, but a new one went in snug. i can get the housings part number if anyone wants and do a writup on how to mod it.
goinloco1 is online now
Old 12-12-2006, 12:44 PM   #13
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
Points 1,311, Level 20
Points: 1,311, Level: 20 Points: 1,311, Level: 20 Points: 1,311, Level: 20
Level Up 11% Completed
FF Reputation: 5 finalley Good Standing Member
add everything but the part about "having to smackit with a hammer" and "pry it with a handle". IMHO that is not an o-ring to begin with. But if you're gonna use one grind or shave a flat edge so you don't split the housing.
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
Old 12-21-2006, 05:38 PM   #14
spoil9
spoil9's Avatar
Fan#: 11696
What I Drive: 02 ZTS
FF Reputation: 1 spoil9 Good Standing Member
I just went to Ford today and bought a new Thermostat housing for my 02 ZTS. It only cost me like $58 I believe, and it no longer had that plug. Where the plug should be is now a solid piece of plastic I guess.
I'll do the exchange either tomorrow or over the weekend and I'll write a little about what I found.
spoil9 is offline
Old 01-12-2007, 12:58 PM   #15
ebayfocus2
Fan#: 40624
What I Drive: 2003 Comp Orange SVT
FF Reputation: 11 ebayfocus2 Great Standing Member
I need one of these o-rings any one know where to get one, and/or the part # ?
ebayfocus2 is offline
Old 01-12-2007, 01:22 PM   #16
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
That plug is in the svt's, i believe the regular zetec have a sensor in that hole. I can get you a new plug with the o-ring for $8.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 01-12-2007, 01:34 PM   #17
pspringe
pspringe's Avatar
Fan#: 17992
What I Drive: 95 Metro, 03 Sonic Blue SVT
FF Reputation: 5 pspringe Good Standing Member
The Ford O-ring will just go bad again.
I found it easier to take the housing off the car. I put it in a vice, to squeeze the plug back in. No cracks, no leaks.
Hofstadter's Law
"It always takes longer than you expect, even when you take into account Hofstadter's Law."
Kariertes Hemd und Samenstau, ich studier' Maschienenbau.
pspringe is offline
Old 03-01-2007, 12:30 AM   #18
HTPerformance
HTPerformance's Avatar
Fan#: 41307
What I Drive: 2002 SVT Focus
FF Reputation: 10 HTPerformance Great Standing Member
Buy-Sell-Trade Rating: (7)
I made up a webpage for the info regarding getting the o-ring replacements. Quite a few people have asked for Priority Service and that is now available.
http://htperformance.net/thermorings.html
email me @ brian@htperformance.net if you have any questions!
HTPerformance is offline
Old 04-09-2007, 02:51 PM   #19
GreenkingSVT
GreenkingSVT's Avatar
Fan#: 43469
FF Reputation: 1 GreenkingSVT Good Standing Member
I have this problem now and am wondering if this would cause problems such as oil gettin into the top of the motor and fouling out the plugs? That is what is also happening in my motor, along with the coolant issue. thanks in advance
GK
GreenkingSVT is offline
Old 04-11-2007, 11:44 AM   #20
DerekNJND
Fan#: 42892
FF Reputation: 7 DerekNJND Good Standing Member
GK
yea, oil could foul out your plugs in theory, but I doubt its related to the thermostat housing gasket/O-ring. Not sure how you've come to that conclusion or even speculation...
Oil leaking into your engine could foul up alot of things...but when this O-ring leaks, the coolant is leaking down onto your engine, transmission and a couple other places, but eventually the ground. Its not getting into your engine unless you have a coolant leak somewhere else.
DerekNJND is offline
