| Ford Focus Technical Chat This section is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls. |
Thread Tools | Search this Thread | Display Modes |
#1 |
Fixed the coolant leak today, pics
Fixed my leak with new o-ring from Mc Master
begining the fix ![]() coolant that was dripping onto the ground before fix ![]() picture of tranny soaked with coolant because of leak ![]() ![]() old o-ring that came out with the plug, see how its all worn out and has a square shape to it? ![]() This is the new Mc Master Viton o-ring i ordered #203 installed on the plug ![]() After installing the plug back with the new o-ring, the leak was over! This o-ring will take alot of persausion to get in but it will withstand the temperatures that the oem wouldn't. I have like 24 more of them, from a pack of 25. Ill part 15 or so of them if anyone needs this o-ring for a leak problem. Just let me know
Performance Mods: FC short shifter, Magnaflow exhaust, HEI wrapped svt header, BBK TB, orp, MSD coil & wires, Diablo Tuner, VF engineering rear engine mount, EBC slotted and dimpled rotors f&r, EBC green stuff pads, PowerWorks Supercharged |
#2 |
Captain TMI
I think the O ring was originally round shaped.. but over time heating and cooling made it mold to the shape of the space it was filling.
GOOD deal... I hope Duratecs don't have problems like this!!
---The Complete How-To Archive-- Moderating Tech Chat and Duratec Chat, let me know if I can help. |
#3 |
I will def. need one pretty soon..I've been really careful of watching my coolant levels..Will I need any other Items , other then what you have..I need to stop being lazy , hehe..How much you asking for?
#4 |
Michael J. Caboose
lol, judy did the same thing a few weeks ago...here's a few pics from mine:
Here was the leak spot... ![]() Here was the new o-ring attached...took a bit of fab work getting it back in, I actually had to shave a bit off to get it to fit.
Cap America and Deadpool walk into a bar, Cap orders a glass of milk, because he's Cap. DP orders a glass of Human Crap, because he's Deadpool. O'er Pirates from the Black of Pitch |
#5 |
Supercharged
i had to shave quite a bit off my Viton o-ring too..it was bending the housing.
#3788 InfraRed SVT Hill <>< |
#6 |
i didn't shave any of it off, i greased it up with gunk, and smacked it in with a hammer. I had to use a long bold to hold against the plug to reach it because there isnt' much space under there and then i smacked the back side of the bolt a few times and it was in.
#7 |
Mine has been leaking for a while but I have ben lazy about it. I have topped off the coolant a few times and that is about it. does it just pop out? It doesn't seem to have any threads...And also do you lose much coolant when you take it out??
thanks Also for the reinstall I am going to use silicone compound (dieltric grease; not RTV) because it won't deteriorate the rubber. |
#8 |
Moderator
Mine hasn't leaked yet( hope it doesn't ), .. What is that plug out of, I can't quite see the picture well enough.
Speed is only a matter of money; how fast do you want to go? Ninja Mod |
#9 |
Michael J. Caboose
It's out of the thermostat housing...let's see if I can get some better pics up.
![]() That's a top shot of the thermo housing, it's underneath towards the front of the housing... ![]() The above pic is of the hole where the plug goes and housing...if you need some more shots just yell!
Cap America and Deadpool walk into a bar, Cap orders a glass of milk, because he's Cap. DP orders a glass of Human Crap, because he's Deadpool. O'er Pirates from the Black of Pitch Last edited by JohnMichael; 02-09-2006 at 08:42 PM. |
#10 |
Michael J. Caboose
The last pic I posted shows the exact location of the aluminum plug, you can see the coilpack directly above the plug in the pic as well as the hole where the plug fits...here's a pic of the little bitty clip that holds the plug in, and it SUCKS trying to get that little bastage back in. I had to use the opposite end of a hammer to ram the plug back in, and then hold it there with all my might as I tried to fit the little clip back in...
#12 |
if i recall correctly only the svtf has the plug.
of course my plug leaked, fixed that, then the housing cracked awhile later. ordered a new housing, the wrong one was sent. the plug hole was molded shut and so was the top sensor hole. i modified it and drilled the top sensor hole and used a coping saw to cut the grooves for the sensors keeper. no more worrying about the plug leaking! altho the sensor was a pita, the old oring fit loose, but a new one went in snug. i can get the housings part number if anyone wants and do a writup on how to mod it. |
| Bookmarks |
| Display Modes | |
