"How To" - Cutting the Stock shifter - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2004, 12:18 AM   #41
fsfocus
Fan#: 6829
What I Drive: 2003 Twilight Blue ZX3 Duratec
FF Reputation: 1 fsfocus Good Standing Member
hey microtonal,
so the 12mm x 1.25 die fits perfect?
j/w cause all i found at sears was 12 x 1.5 and 12 x 1.75
ill have to call up the hardware stores tommorrow
fsfocus is offline
Old 06-15-2004, 11:19 AM   #42
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Yup.
The stock shift knob fits/threads on perfectly using that size of cutting die.
They should have the 12mm X1.25 cutting die at Sears.
Just reading.....
microtonal is offline
Old 06-15-2004, 03:28 PM   #43
fsfocus
Fan#: 6829
they dont at mine..
but ill get one from a hardware store.. thanks.
fsfocus is offline
Old 06-15-2004, 08:32 PM   #44
fsfocus
Fan#: 6829
i just did this.. the 12mm x 1.25 worked well but it is not exactly the same as the thread on the shifter .. it doesnt thread on easily with fingers
but anyways i threaded a bunch of it, and used a socket to turn the die .. not a die tool and it worked fine.
i took about 1 1/2" off the shifter, the throws are shorter and overall it feels much better.
the only drawback is the boot looks horrible cinched around the shaft.. but mine was already like this because i had the reverse lockout off.. so i have to think of something to make the boot look better.
fsfocus is offline
Old 09-16-2004, 03:33 PM   #45
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
Buy-Sell-Trade Rating: (6)
I left the reverse lock-out on mine, i just cut the shaft that's underneath the shifterboot. I got a pic if anyone wants to see
Foci_Fosho is offline
Old 09-16-2004, 03:37 PM   #46
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
Post the pic.
Just reading.....
Old 10-07-2004, 05:27 PM   #47
jveneziano
Fan#: 13586
What I Drive: 2000 Pitch Black Sony Limited Edition
FF Reputation: 1 jveneziano Good Standing Member
I did this it was very easy. I cut mine 2 inchs. For the reverse lock out I unscrewd the fac. knob
and the boot and lock out came right off. I cut the wire tie to get the lock out, out of the boot.
After I cut the shaft I cut the lock out just below the notch where the boot was tide. I then replaced the boot to the modified lock out. Iput the boot and lock out back on the shaft, it rested on the bend it the shaft, I also put back in the origanl spring and knob. You can't tell at all. It works great and I don't have the lock out function. ass soon as i get some pics i'll post them. Thanks for all the good info!
aem cai, hyper ground kit, 65 mm throtle body, kyb dampers, vogtland springs eibach front and rear sway bars, and poly ureathane bushing. Ordering real soon mrbn exhaust.
jveneziano is offline
Old 10-22-2004, 07:44 AM   #48
johnlb
Fan#: 14013
What I Drive: 01 green ZX3 mtx
FF Reputation: 1 johnlb Good Standing Member
"get er' done" i did it, it's great
pimpin' tha lo lo
johnlb is offline
Old 11-17-2004, 01:44 AM   #49
evokona00
Fan#: 8530
What I Drive: 2000 kona zx3
FF Reputation: 1 evokona00 Good Standing Member
you should just just go on ebay and get a short shifter for around 20-30greens but its up to you cause from what i know thats ghettooo and its real bad cause it causes the force on the pinion bearing in you shifter mount to pop out due to too much force but man its up to you and it looks pretty cool too big ups on your home made shifter
evokona00 is offline
Old 12-01-2004, 05:24 PM   #50
DrRay
Fan#: 14474
What I Drive: A car
FF Reputation: 1 DrRay Good Standing Member
Originally posted by Galidah
is there any difference between cutting it and buying a short shifter (besides keeping the child-like reverse lock-out) cuz if it is more beneficial to get a short shifter, i'll get one.. but if i can just cut the stock one and get the same results.. might as well be cheap....
Short-shifters from Steeda are not just shorter stalks, they have different geometry and cable/spring locations to make the shifts easier and more positive.
This cheap mod could mean harder engagement due to less leverage than the stalk was designed for.
Anyone know why the shifter mechanism was changed by Ford mid-way through 2002 production?
DrRay is offline
Similar Threads
For Sale: Stock SVT shifter W/O Shift knob Trav-E2.0 Archive 8 02-06-2007 05:16 PM
For Sale: stock parts (suspension parts, shifter, headlamps) SD_Focus Archive 1 10-24-2006 01:29 PM
WTB: stock SVT shifter 02SVTscreamin Archive 4 05-26-2006 01:22 AM
Where should I cut my stock shifter? silverfoci ZETEC Performance (2000-2004) 3 11-21-2003 11:49 AM
Cutting stock shifter Solaris Ford Focus & General Car Chat 19 10-20-2003 02:06 PM
