"How To" - Cutting the Stock shifter - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2004, 07:30 PM   #1
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Cutting the Stock Shifter
I done this mod a while ago and just wanted to pass it on for those on a budget.
About $20-30 and some labor.
Makes your stock shifter shorter and makes the throw somewhat shorter but not much.
WARNING
**You will loose your Reverse lockout mechanism if you do this mod.**
Time to complete task:
1 hour
Required tools:
12mm X 1.25 Cutting die - you can get this at Sears for $5. This will re-thread your shifter.
1-inch die Tool - the Cutting die fits inside and is used to get even leveage on the cutting die. So when you start threading the shifter, you can easily thread it. $5-10 at HW store.
Hacksaw - $5-10 at any HW store. Or try Walmart, Target, etc.
Ruler - $1
Phillips head Screwdriver
Black marker pen(sharpie)
8 inch zip tie
3 - Plastic bags
Wire cutter/dykes
10mm socket and rachet-(My 2003 ZX3 had a 10mm bolt for the rear mount of the console)
1.
Twist off stock shifter knob.
2.
Remove the console. There should be two screws under the cup holders and one under the rear cup holder. The one in the rear was a bolt on my 2003 ZX3.
There might be a zip tie holding the top of the shift boot to the shifter.
If you can, cut it with the dykes/wire cutters to remove the shift boot from the shifter.
Remove or cut the Reverse lock-out mechanism as needed to remove it.
I have a 2003 ZX3 and had to cut it off.
*At this point, the console should be removed with the shifter assembly exposed.*
3.
Measure the total thread length. Meaning. Measure from the top of the shifter to where the threads ends on the shifter. This is your reference to how much you will need to re-thread.
Make a note of this measurement.
4.
Poke a small hole in the middle of one of the plastic bags and place it over the shifter, all the way down to the base.
This will be used to catch the metal that will be flaking off when you start threading the shifter. Use another bag if you want for extra protection.
5.
Measure from the top of the shifter down about 2 inches. Or less. Or more. It's up to you.
Use the pen to mark where you want to cut it.
6.
Screw the Cutting Die on the shifter until you can't go any further.
Put the Die Tool on the Cutting die and start threading down past about an inch below the pen marking. Make sure the cutting die is below the pen mark. Repeat Step 5 if need.
7.
Remove the Die tool but leave the cutting die in place.
8.
Take the hacksaw and cut away. Just go slow and be patient. Don't rush it.
9.
After you've cut the shifter off with the hacksaw, put the Die Tool back on the Cutting die.
10.
Now thread the die until you have the same length as measured and noted in step 3.
11.
Once you've got it threaded to the proper length, twist the die off so you can remove it.
Use the Die tool if need. It should come off pretty easy. The top will be the hardest point since that's where you cut the shifter.
12.
Remove the plastic bag carefully, not to spill any metal flakes.
13.
Put the console back on. Use the zip tie to put the shifter boot on snug but not too tight.
The zip tie should lace inside the top of the shift boot.
14.
Screw the shift knob on.
You're done.
Cutting die and tool
microtonal is offline
Old 02-24-2004, 12:27 PM   #2
focaltech
Fan#: 490
What I Drive: 2001 Pitch Black ZX3
FF Reputation: 1 focaltech Good Standing Member
Buy-Sell-Trade Rating: (-1)
Microtonal, hit up one of the mods to make this a sticky. For future reference.
focaltech is offline
Old 02-24-2004, 12:34 PM   #3
yellowzx5
Fan#: 2203
What I Drive: 03 Yellow ZX5
FF Reputation: 1 yellowzx5 Good Standing Member
so, what happens to reverse? or do you just lose the lock-out feature?
yellowzx5 is offline
Old 02-24-2004, 12:56 PM   #4
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
Reverse still works fine.
You just don't have the lock out feature that's an extra safety precaution.
Reverse is below 5th and it's pretty hard to get it in to Reverse while your moving forward unless you REALLY tried.
Just reading.....
Old 02-24-2004, 08:59 PM   #5
focus mike
Fan#: 953
What I Drive: 2002 zx3 BAN MC DONALDS
FF Reputation: 1 focus mike Good Standing Member
why would you sticky this???there is already too much stickyness for me. kinda like a highskewl playboy mag. lol. anyways a short throw is like what 100-200 bux i dunno but thats way to ghetto. serously if you are on tight of a budget MAYBE just MAYBE you shouldnt be modding your car. ; )
focus mike is offline
Old 02-24-2004, 09:16 PM   #6
centennial
centennial's Avatar
Fan#: 2377
What I Drive: 2012 Focus SEL
FF Reputation: 1 centennial Good Standing Member
Aftermarket manufactureres love folks like you. Just because you can do it yourself at little to no cost does not always make it ghetto.
From your profile..." ford racing shoulder pads and steering wheel cover WoOT!"
Now that's something many might consider just a little bit ghetto. Right up there with yellow stickers.
If you've got 100 to 200 bux to throw wildly around you are probably still living with Mom & Dad. Once you get real bills you find the best way to get things done without needless expense.
centennial is offline
Old 02-24-2004, 09:28 PM   #7
focus mike
Fan#: 953
d00d that was a joke... with the shoulder pads and steering wheel cover im not bragin look i have shoulder pads im just saying it as a joke. mmmkay.....oh and they where outta my old ass pickup truck before i had my focus. and my steering wheel cover was givin to me by my sister as a gift now flame me see whats up! ; )
Old 02-24-2004, 09:34 PM   #8
centennial
centennial's Avatar
Fan#: 2377
Who flamed first? D00d. Seems like you wanted to take off on microtonal for something that some people may want to do.
Old 02-24-2004, 09:47 PM   #9
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
Come on you guys, cut it out...LOL
I'm the one who's ghetto that did the mod.
The main reason I did it was because the stock shifter kind of sits too high for me and I really liked my old 1979 Rabbit 4-speed that came with a short shifter. So, I cut it. It was easy for me to do and after you re-thread the shifter with the cutting die, it looks professionally done.
Just reading.....
Old 02-24-2004, 09:58 PM   #10
focus mike
Fan#: 953
i like the focus central shifter my factory one the gray paint is coming off...i bang on my shifter way to much. the focus central one just looks nice i guess ill pay for something that looks pretty : ) lol
like those girls on north ave. LMFAO j/k i get the honey for free its called :drumroll: my girlfriend hehehehehee and the honey is sweet.
Similar Threads
For Sale: Stock SVT shifter W/O Shift knob Trav-E2.0 Archive 8 02-06-2007 05:16 PM
For Sale: stock parts (suspension parts, shifter, headlamps) SD_Focus Archive 1 10-24-2006 01:29 PM
WTB: stock SVT shifter 02SVTscreamin Archive 4 05-26-2006 01:22 AM
Where should I cut my stock shifter? silverfoci ZETEC Performance (2000-2004) 3 11-21-2003 11:49 AM
Cutting stock shifter Solaris Ford Focus & General Car Chat 19 10-20-2003 02:06 PM
