Wheel Vibrations - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-29-2006, 06:22 PM   #1
guywiththeford
Fan#: 31369
What I Drive: Focus 2001 Blue 5-Speed
FF Reputation: 1 guywiththeford Good Standing Member
Wheel Vibrations
Hey guys i'm new to this forum so i don't knwo if this was ever talked about earlier. So my front drivers side wheel has some loose to it. When i lift the car up and move it up and down to check and see if the wheel bearing is worn it doesn't move one bit, also dosen't move to the side. I have gotten a wheel allignment also. WHen the car is on the ground and level if i push hard or kick on the wheel at the top it moves, very little but it dose. THe other side doesn't do this at all. I looked under the car and it seems that the shock strut connected to the knuckle and the driveshaft move with it. This is a problem at speeds above 65 mph is when i feel it or when i have the wheel turned to go with the road. There is almost a vibration that's steady in the steering wheel, as if it had a beat to it. This gets very annoying!!!! I was told it shoudl be the bearing in the hub but like i said earlier it doesn't wooble at all when it's in the air. So i don't knwo what this. If you guys could help out. Thanks. One more thing. My clutch pedal has no resistence to it. It's barly harder to push than my gas pedal, it's so weak. WHat coudl this be from, it still works great it's just so soft . ??
guywiththeford is offline
Old 01-29-2006, 06:36 PM   #2
DJYoshaBYD
DJYoshaBYD's Avatar
Fan#: 29234
What I Drive: 91 Eagle Talon TSi AWD - White
FF Reputation: 1 DJYoshaBYD Good Standing Member
You know.. that is wierd.... my car just started vibrating too... I can feel it in the steering wheel.. I am going to get new tires any way.. so I will see if that helps.... and my right strut makes a grinding sound in the morning, then in goes away after about 10 minutes of driving.... It almost sounds like it is grinding against the wheel well when I turn it, but then it will continue to do it as the up and down motion of the car starts (you know when your driving, lil bump here, lil bump there).... even when I drive straight... then it just goes away....
as for the clutch, I would check your clutch fluid.. you might have a slow leak that lead to air in the lines (similar to getting air in the brake lines.. real soft pedal feel)...... also, check to make sure there is fluid in there anyway... lol
-2003 Foucs zx3 2.3 SOLD
-88 Honda hatch with JDM B16A w/ LSD and 200 hp SOLD
-91 Eagle Talon TSi AWD
DJYoshaBYD is offline
Old 01-29-2006, 07:33 PM   #3
elliottcarlose
elliottcarlose's Avatar
Fan#: 11597
What I Drive: 2000 Green ZX3, 2003 CBR 954 and now a 06 C-dan
FF Reputation: 1 elliottcarlose Good Standing Member
when you jacked it up did you do it under the frame rail if so try it under the front control arm and try again for movement
SHOW =Clear tails, Steeda 17" ultra lite rims, color matched grill, Widow tint, Clear marker lights, Steeda fiberglass hood, Steel M3 Fenders,street glow green gold series
Sounds =2-12 Fosgate PS1, 1 Fosgate 5002 500watts RMS, 4 Fosgate door speakers, 1 Pioneer in dash dvd/monitor
GO 4-2-1 race header, complete cat back, SRI, and svt suspension
elliottcarlose is offline
Old 01-30-2006, 07:20 PM   #4
saagz87
Fan#: 11985
What I Drive: 2002 infa-red SVT
FF Reputation: 1 saagz87 Good Standing Member
i have all of these same symptoms! had ford check it all out and they can't find anything wrong with anything...
02 Yamaha R1... fun, fun, fun
saagz87 is offline
Old 01-31-2006, 12:33 PM   #5
guywiththeford
Fan#: 31369
What i belive it to be is the joint between the knluckle and the shock. I think there might be some loose there or in the upper part of the shock strut? I will try and fidn out for sure when i change my oil next time. There has been soem kidn of recall on this issue i think. i went to focusescort.com and under soem section they shoudl reports and this might be on one of them but i dont knwo for sure?
Black Diamond TB, Mangnaflow Exhaust, UDP 25%, Intake, RPM Cluster, Leather Seats, Pioneer HU, Polkaudio Speakers, Armrest, Fog Lights, Euro Grill, SVT Grill, Front Strut Bar, Alloy Wheels, Windshield Wiper Switch.
Old 02-07-2006, 02:41 AM   #6
rpnguitplayer
Fan#: 31415
What I Drive: 2001 ford focus zts
FF Reputation: 1 rpnguitplayer Good Standing Member
mine has same problem im gonna take it to the dealership soon but i did put new rubber and re align the s.o.b. and it helped a bit but you can still feel like a slight vibration correct???? did u ever have the vibration kinda pulse in and out slowly???
rpnguitplayer is offline
Old 02-26-2006, 10:33 AM   #7
greglovesbeer
Fan#: 32001
What I Drive: 2000 Gold Focus SE
FF Reputation: 1 greglovesbeer Good Standing Member
Mine does the exact same thing. I have been told by more than one person that the strut mount is binding. I was also told my right coil is sagging. So I am going to replace my coils, struts, and strut mounts, and I sure hope this solves my problem.
greglovesbeer is offline
Old 02-26-2006, 01:45 PM   #8
rpnguitplayer
Fan#: 31415
gget back to me and let me know how it goes ok???^
