Cam Gear Install and Tuning Question - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 01-24-2006, 04:14 PM   #1
bushmasterguy
bushmasterguy's Avatar
Fan#: 16812
What I Drive: 2004 Ford Focus SVT - CD Silver
FF Reputation: 1 bushmasterguy Good Standing Member
I just bought a Kent Cam Gear and I talked to a shop with a dyno today to install it and set it.
The guy at the shop told me he would have no idea what "degrees" to set the cam gear at and that I would have to tell him what degree to have it set at. I told him I thought that is what he would figure out by running a baseline dyno and then another dyno after adjusting the sprocket. He told me that is not how it works. I need to tell him what the degrees of the cam needs to be set at for my Focus SVT is so he can set it correctly.
So I guess my question is what is the correct degree to set my cam at for optimal performance?
The "Go":
Focus Central 65mm TB, Steeda SRI, FC 2 PC Pulley Kit, "Tom's Tune", Steeda Short Throw Shifter. MSD Coil and Wires, Steeda Strut Tower Brace, Clutch Masters Stage III, Kent Alloy Exhaust Cam Gear, Borla Exhaust, Quaife Diff, Fidanza Flywheel, Denso Spark Plugs.
The "Show":
TYC Altezza Tail Lights, Steeda Emblems, Euro Grill, RT Brake Caliper Lacquer Blue
bushmasterguy is offline
Old 01-24-2006, 04:36 PM   #2
Toolman00
Toolman00's Avatar
Fan#: 2744
What I Drive: 2000 Ford Expedition XLT 4x4
FF Reputation: 3 Toolman00 Good Standing Member
I imagine that all you'd have to do is get a baseline, then change the setting on the cam gear, then dyno... repeat until you are satisfied.
Give the toughest job to the laziest man and he'll find the easiest way to get it done.
Toolman00 is offline
Old 01-24-2006, 04:49 PM   #3
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
^^^ yup, you gotta make a baseline run, then run a few more at different degree settings to find the best one
crazymechanic is offline
Old 01-24-2006, 05:23 PM   #4
bushmasterguy
Fan#: 16812
I called Focus Central where I bought the Cam Gear and they told me the guy that has the Dyno does not know what he is talking about. IT is trial and error. Base Dyno, Adjust and Dyno again.
I talked to the guy again and explained this to him. I think he gets it now. Scary. I will definetly insist on looking over his shoulder If I use that place.
The "Go":
The "Show":
Old 01-24-2006, 05:30 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Run away!!!
Well, it does sound like you got them set straight.
Maybe the dyno shop just wanted to know what to set the gear at initially?
They should set it straight up (0) for the baseline run, and go from there.
IIRC, somewhere between -3 and -5 seems to be the setting where most folks end up,
but you probably need to hear that from someone that's actually had it done.
EDIT:
BTW, I thought Focus Central was out of business.
You actually talked to someone from there?
WD40 is offline
Old 01-24-2006, 05:35 PM   #6
bushmasterguy
Fan#: 16812
After I talked to the Dyno guy again he did say we should take it 2 degrees one direction and if that was working we would take it 2 degrees again in the same direction. The Opposite if we were loosing Hp/Tq.
I bet we run anywhere from 3 to 5 dynos. There cost is $85 a dyno but I am sure I can work out something if we are going to run multiple dynos.
And yes Focus Central is still in business. http://www.focus-central.com/main.asp
The "Go":
The "Show":
Old 01-24-2006, 09:10 PM   #7
myblacksvt
myblacksvt's Avatar
Fan#: 6660
Location: roasting tires all over the east coast, Afghanistan
What I Drive: 2003 Honda S2000 / 1990 honda civic
FF Reputation: 1 myblacksvt Good Standing Member
i would seriously not go to that guy. hes operation the dyno and doesnt even know the basics of tuning. scary
Life is a garden, dig it!
turbo/VTEC
myblacksvt is offline
Old 01-24-2006, 09:10 PM   #8
crazymechanic
Fan#: 12900
$85 per run?!?! that's disgusting...there's a place about 1.5 hours from me that gives you two runs for $55, 3 runs for $80, or two runs with air/fuel ratio for $80 (or something like that)
Old 01-26-2006, 06:41 PM   #9
Toolman00
Toolman00's Avatar
Fan#: 2744
That's the way I understand it too.
$85/run is VERY expensive! Ask if he has an hourly rate. It really wouldn't take much to tune a gear. Not too sure what the going rate is per hour, but IIRC, some guys in WI rented a dyno for $75/hour.
Old 01-26-2006, 08:04 PM   #10
Svtzx555
Fan#: 27739
What I Drive: '06 silver ST
FF Reputation: 11 Svtzx555 Great Standing Member
Buy-Sell-Trade Rating: (4)
I think maybe he meant $85 per hour. Our local dyno charges $100 per hour, then and additional $45 per hour for tuning stuff like that.
Gumpcrew#7
Originally Posted by the_07ninja View Post
Svtzx555-3 to Sn4ckm4st3r-1
Originally Posted by TnFocus View Post
Yea, I'll go .080 over on his face.
Svtzx555 is offline
