two codes EGR I'm guessing... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2006, 04:07 PM   #1
SpeedOften
SpeedOften's Avatar
Fan#: 2139
What I Drive: E90 335i, 2002 E53 X5 4.4i
FF Reputation: 28 SpeedOften Great Standing Member
I"m getting these two codes:
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
and
P1406 - DPF EGR Sensor Downstream Hose Off or Plugged While driving, the EGR monitor commands the EGR valve closed and checks the differential pressure across the EGR orifice. The test fails when the signal from the DPF EGR sensor continues to indicate EGR flow even after the EGR valve is commanded closed. Downstream hose is disconnected
So the EGR valve isn't working right.. Any ideas on how to fix this?
SpeedOften is offline
Old 01-24-2006, 05:40 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
"DPF EGR Sensor Downstream Hose Off or Plugged"
Have you checked to see if the DPF Sensor hose is off or damaged?
http://www.teamfocus.us/dpfeservice.htm
penguin is offline
Old 01-27-2006, 12:26 PM   #3
SpeedOften
SpeedOften's Avatar
Fan#: 2139
All the hoses are connected and the wiring conector is secure... Could the valve just be stuck?
Old 01-30-2006, 02:55 PM   #4
SpeedOften
SpeedOften's Avatar
Fan#: 2139
Cracked header...
my FC header is cracked.. I believe this is what's causing it...
Old 01-30-2006, 02:59 PM   #5
BlacKnight
BlacKnight's Avatar
Fan#: 23119
What I Drive: 2007 Black F150 STX
FF Reputation: 1 BlacKnight Good Standing Member
If you have any friends that work at a dealership or shop, have them hook up their scan tool and check the DPFE sensor. They are fairly common for failing.
Roger
I sell Ford, Lincoln, and Mercury vehicles one piece at a time.
Shadow may be gone, but I am still around from time to time!
BlacKnight is offline
Old 01-30-2006, 03:04 PM   #6
TM3
Fan#: 16784
What I Drive: 2004 EAP SVTF
FF Reputation: 3 TM3 Good Standing Member
Buy-Sell-Trade Rating: (17)
I've been pulling the same code (P1406). This has happened before too, right after I installed my SVT header, then after I installed my blower. The first time, a new DPFE sensor fixed the problem; but the second time around, I put in a new DPFE sensor and its still throwing the code. Both my upstream and downstream hoses are in good shape, and are plugged pretty tight, so I was thinking that the EGR Tube might have some build up on the inside that might be causing the sensor to get a false reading.
TM3 is offline
Old 01-30-2006, 03:06 PM   #7
TM3
Fan#: 16784
Also, after I installed my blower, it started throwing the P0171 code, but a new fuel filter solved that problem.
TM3 is offline
