2003 PZEV Stock CAI - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-16-2004, 10:04 AM   #1
kaweahnet
kaweahnet's Avatar
Fan#: 3329
What I Drive: 2003 Blue ZX3
FF Reputation: 1 kaweahnet Good Standing Member
2003 PZEV Stock CAI
2003 PZEV ZX3 comes with a CAI from the factory - just noticed it this weekend. I don't see how it can be improved from the design other than maybe chaning out the filter to a K&N. There is some type of meter that I can see, I can't tell whether it's a moisture bypass or what.
I see a lot of differences between my motor layout and most of the pics online. The most major difference is that my motor is sitting the other way; with the intake forward and the exhaust to the back. Also just installed an alarm this weekend too and the 2002 wiring diagrams don't fit the 2003 exactly, I hope to get an accurate one posted soon. Still can't find the tach sensor though - the wire they say to look for is at the coil and there is no friggin coil in this car!!! I found the color they recommended but the meter tells me it does nothing with RPM changes. Oh well, the whole reason for post is this question:
Has anybody done any improvements on the 2003 Stock CAI that I should be aware of?
David P. Killion
2003 Ford Focus PZEV ZX3 (my daily driver).
2003 BMW Z4 - 3.0i 6-speed
2003 Rocket RK-100 80cc Shifterkart (when on the track).
http://www.thekillions.com/dave/phot...0290-thumb.jpg
Performance mods: Marcy Intake.
Interior mods: Lynx 2000 Remote start alarm and aftermarket door locks. 15% Tint (50% on side roll-ups).
Exterior Mods: Motegi FF5 18" wheels & Yokahama Parada Spec 2 tires (215-40/ZR18). H&R 1.4" springs. 5" Super Shorty Billet antenna.
kaweahnet is offline
Old 02-16-2004, 11:21 AM   #2
kaminari_croc
kaminari_croc's Avatar
Fan#: 577
What I Drive: 2003 ZX3 (2.3L) Turbo
FF Reputation: 1 kaminari_croc Good Standing Member
Buy-Sell-Trade Rating: (4)
As far as I know you cannot change the filter out of the factory intake, it is completely sealed and to be replaced every 150,000 miles. There are aftermarket CAI's out there, but as for modifying the stock one, I don't think you can do much with that.
Pitch Black 2003 2.3L ZX3 - FSWerks Turbocharged (parting out, bye bye)
Superblack 2004 Nissan 350z Touring - mods in progress
kaminari_croc is offline
Old 02-16-2004, 11:35 AM   #3
P0WeRbyDuratec
P0WeRbyDuratec's Avatar
Fan#: 2109
What I Drive: 2012 WRX Limited
FF Reputation: 1 P0WeRbyDuratec Good Standing Member
why would u want to anyways? If your gunna spend any money, you should at least do it right. Get a real CAI.
P0WeRbyDuratec is offline
Old 02-16-2004, 11:45 AM   #4
kaweahnet
kaweahnet's Avatar
Fan#: 3329
Well, because I've heard some pretty big horror stories about CAI's, especially with respect to water intake. I don't want to cause problems if it's not going to give me a decent gain. I just had thought that maybe somebody might have done something to the stock, versus changing from stock CAI (which doesn't look to bad) to an aftermarket CAI.
David P. Killion
Old 02-16-2004, 01:02 PM   #5
soffiler
Registered User
soffiler's Avatar
Fan#: 372
What I Drive: '03 ZX3 PZEV 5-spd Twilight Blue; '97 F-250 4x4 w/ 351 V8 & AT
FF Reputation: 1 soffiler Good Standing Member
Re: 2003 PZEV Stock CAI
That meter you see on the factory intake measures pressure drop across the filter. It is a completely sealed system (for emissions reasons) designed for 150,000 miles of normal use (whatever that is) but if it starts to clog sooner, that meter will show red. The factory filter cannot be replaced except as an entire intake unit.
The Duratech 2.3 liter engine in the PZEV car is turned around, you are correct, vs. a 2.0 liter Zetec. Completely different animal.
I am not surprised the '02 wiring diagrams don't match the '03 PZEV very well. Completely different animal, as I said. It's not just a different engine mechanically, but the ECU is completely different as well.
You are correct, it doesn't have "a" friggin coil. It has four. One for each plug, located right in the plug cap. It is called C.O.P. for coil-on-plug ignition. I don't know how to connect a tach, but it's possible that you can't. The wire you would look for on a conventional ignition is the one being switched by the igniter module. The C.O.P. system has basically four separate igniter modules. You could easily locate one of the igniter signals to one of the four coils, but, that signal would be 1/4 as fast as you want.
I haven't heard anyone on this forum discussing mods to the factor intake - Marcy, Focus Central, and Focus Sport seem to be the popular aftermarket options.
soffiler is offline
Old 02-16-2004, 01:09 PM   #6
guerro
guerro's Avatar
Fan#: 339
What I Drive: 2013 Focus ST Oxford White
FF Reputation: 1 guerro Good Standing Member
Had you given any thought to maybe doing a search of the PZEV section of this very forum ?? May want to look into it. I hear it is all the rage these days.
guerro is offline
Old 02-16-2004, 01:56 PM   #7
turbo989
turbo989's Avatar
Fan#: 2869
What I Drive: 2003 Ford Focus 2.3L PZEV
FF Reputation: 1 turbo989 Good Standing Member
I want to first off give major props to the CAI by Marcy. I have had it for 2 months now and it is awesome. The Horsepower gains are close to 10FWHP...how much more horses do you want to get from a Intake bud? 10WHP is hella hard to get in any other car. You'd be lucky to get 10WHP from an intake in a civic.
Anyways, about the water problem...walter created his CAI so you can use your OEM splash guard with it. The slash guard will protect your CAI intake from sucking up water. Just as long you don't decide to plunge your front end into a lake anyways. Also...if you are still skeptical about it....by the AEM bypass valve and slap that on there along with your splash guard just to be safe. Anyways...those are just my suggestions.
I dunno anything about the electrical system you are trying to do...I just installed my sound system so I am sorry I Cannot help ya there!
The car will teach you how to drive.
Shifting weight, cornering control, power.
It doesn't matter the car you are driving,
But more the driver.
Control, experience, and technique
Is what will win your race.
·•¤^v¤ Turbo989 ¤^v¤•·
turbo989 is offline
Old 02-16-2004, 03:41 PM   #8
kaminari_croc
Fan#: 577
Whats a decent gain? I would say that the 8-10 whp you get from this is pretty decent.
Old 02-16-2004, 05:08 PM   #9
P0WeRbyDuratec
Fan#: 2109
a bypass valve will fit and work with the Marcy???? does anyone have that?
Old 02-16-2004, 05:59 PM   #10
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
The big gains you get from an aftermarket CAI is you are replacing the restrictuve factory parts with free-er flowing parts. If you are worried about water, keep the splash gaurd on, and don't submerge the bumper.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Similar Threads
FS CAI and Stock... magicleo2120 DURATEC Performance (2003-2007) 15 12-04-2005 01:27 PM
2003 Zx3 Pzev 2.3l 5-spd For Sale cbrowne Archive 7 04-24-2005 10:23 PM
Stock HU iPod Dock-Connector Input Adapter for 2000 to 2003 FocusInCali Car Audio, SYNC, MyFord Touch & Electronics 8 09-28-2004 05:38 AM
Best CAI for 2.3L pzev hodgenpodg DURATEC Performance (2003-2007) 5 03-07-2004 11:52 AM
pics of my stock 2003 Focus poisonivory Ford Focus Builds & General Showroom 9 02-09-2004 07:36 PM
