Go Back   Focus Fanatics > Model Specific Discussions > Focus SVT > SVT Interior Mods & Upgrades
SVT Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2002-204 SVT Focus.
Old 10-21-2007, 09:06 PM   #11
drewbird91
Fan#: 36256
What I Drive: 2000 ford focus 16v zetec
FF Reputation: 1 drewbird91 Good Standing Member
bump, anyone have an answer?
drewbird91@hotmail.com
drewbird91 is offline
Old 03-17-2008, 01:59 PM   #12
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 136 WD40 Excellent Standing MemberWD40 Excellent Standing Member
Where exactly does the "simulator" go?
Do you unbolt the large rectangular plug from under the seat, install simulator, bolt back up??
From the picture, that looks like male and female connectors to fit in between the two halves of the connector.
I found another supplier for the part here:
http://www.airbagsystems.com/order.htm
$29 for what's probably a resistor.
WD40 is offline
Old 03-28-2008, 12:45 PM   #13
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Well, I actually have the OTC 418-139 in my hands right now.
(Helps to have good friends at the Dealer. )
At any rate...I still have no idea where to plug this in??
WD40 is offline
Old 03-28-2008, 01:33 PM   #14
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
i believe it might go under the seat.... but dont quote me on that.
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 08-02-2008, 02:21 PM   #15
supersonicsvt
Fan#: 19223
FF Reputation: 1 supersonicsvt Good Standing Member
Back from the dead!
I have spent all day making 2.5 ohm jumpers across the harness. My factory manuals show a different harness and different wire colors than what my car has - UGH. I finally plugged the passenger seat in, moved to the driver side and put jumpers across the airbag module pins and the pre-tensioner pins, and still got 5-1 and 5-4 light flashes. I give up.
WD40, did you ever try the simulator? The harness on the OTC simulator doesn't look like they match the harnesses under my seat - I don't want to shell out $110 for them unless they work, activating the front airbags for my commute to the track with factory (legal!) seatbelts................
supersonicsvt is offline
Old 08-02-2008, 03:31 PM   #16
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
ok...anything on this??? WD did you find where it pluggs in??? did you verify??
HaveBlue83 is offline
Old 08-11-2008, 04:00 PM   #17
supersonicsvt
Fan#: 19223
Looks like WD40 hasn't visited the forum since May. Anybody know what's up with WD40?
Old 09-16-2008, 06:55 PM   #18
Focus Kenn
Fan#: 52973
What I Drive: 04 Liquid Grey Sedan
FF Reputation: 1 Focus Kenn Good Standing Member
i have an 04 focus that does not have side air bags however still has a sensor under the seat. I went to ford today and used the dam simulator "418-139" and my light still came on. I give up. I want a secure airbag system but nice seats at the same time....weak.... anyone get this to work correctly. the light flashed 4 times then stopped, 4 times then stopped. it did this 4 flashes 4 times then went solid.
Focus Kenn is offline
Old 09-18-2008, 09:11 AM   #19
supersonicsvt
Fan#: 19223
Here is what WD40 told me:
"The simulator will not plug into the SVT seats.
As you found out, it's a different plug, due to the extra wiring for power seats, seat heaters, and side airbags.
What I did find out is that you have to use a capacitor in series with a resistor to get the light to go out.
I took pics, but I'll be darned if I can find the time to post them up.
With any luck, I can get you the "values" within a day or two.
You also HAVE to use a good seat belt tensioner.
I swapped with one of my stock seats.
If the tensioner came off a car that blew an airbag, it won't work and will set the code again.
I cut the yellow wire coming from the airbag (airbag missing...but the wire will still be there) and spliced in the resistor and capacitor.
Haven't seen a light since.
And...I've still got to get an airbag ordered.
^^^That's the right way to fix it.
I rather like having the added saftey factor."
I gave up after he told me this. I'll just wear my six-point harness and forget the factory belts.
Old 08-20-2009, 07:22 PM   #20
scootercommuter
Fan#: 29751
What I Drive: 2001 Midnite Blue Focus Wagon
FF Reputation: 1 scootercommuter Good Standing Member
What size of Capacitor did you put in series with your resistor for this airbag modification? Much appreciated.
Original owner '01 Midnight Blue Ford Focus SE Wagon
'07 Yamaha Classic 650
'01 Bajaj Legend
scootercommuter is offline
