Help me with install on rear camber kit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2006, 02:56 PM   #1
cbrenn71
cbrenn71's Avatar
Fan#: 30613
What I Drive: 2003 Black ZX3, 2000 Dodge Durango
FF Reputation: 5 cbrenn71 Good Standing Member
Buy-Sell-Trade Rating: (21)
i posted a bit back refering to problems with my rear suspension. i was told by my alignment shop that does great work, that a rear camber kit would remedy my problem.
i got my camber kit in, but have no idea how to install it. can someone who has done this before and knows what they are doing, help me out? thanks.
i have attached a picture of what my camber kit looks like. thanks.
cbrenn71 is offline
Old 01-22-2006, 08:29 PM   #2
Focusondeez69
Focusondeez69's Avatar
Fan#: 27442
What I Drive: 05 liquid grey zx3
FF Reputation: 1 Focusondeez69 Good Standing Member
im about to do the same install with the camber bolts, and i too would like to get some input on this!
What suspension are you running?
Focusondeez69 is offline
Old 01-22-2006, 09:07 PM   #3
cbrenn71
cbrenn71's Avatar
Fan#: 30613
lol. stock. my suspension has some issues apparently due to stock springs settling and throwing off my camber. i chewed through a set of firehawks before i saw what was going on.
Unique Coatings
SPECIALIZING IN TINTED TAIL LIGHTS/HEADLIGHTS, HID UPGRADE KITS/RETROFITS, ANGEL EYE CONVERSION KITS, LED BULB UPGRADES, AND CLEAR PAINT PROTECTION, and LAMIN-X FILMS
cbrenn71 is offline
Old 01-22-2006, 09:08 PM   #4
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
got news for ya...it's probably not your springs settling. ford released new rear upper control arms that'll take about 1 degree of camber out of your rear wheels and get you back to factory settings. good luck
crazymechanic is offline
Old 01-22-2006, 10:22 PM   #5
cbrenn71
cbrenn71's Avatar
Fan#: 30613
i know of the redesigned upper control arms. the reason they developed them was due to the fact the springs settle and the fact that the upper control arms drop in causing the alignment issue. these camber kits allow for +/- 1 degree of camber adjustment. the same as the new upper control arms do. i was told by a ford master mechanic this would also remedy the problem.
thanks for the insight though.
Unique Coatings
cbrenn71 is offline
Old 01-22-2006, 10:35 PM   #6
wakeboardjl
See that video?
wakeboardjl's Avatar
Fan#: 10643
What I Drive: 2005 Mazda 3 Hatchback
FF Reputation: 1 wakeboardjl Good Standing Member
you have to grind off the tack weld on the one of the bolts and then replace it with those bolts. I believe it's the upper control arm bolt but I don't remember.
SVT Squad #162
"I'm the dude!"
wakeboardjl is offline
Old 01-22-2006, 11:01 PM   #7
cbrenn71
cbrenn71's Avatar
Fan#: 30613
yeah i was reading that on the instructions, and i saw which one i have to grind off. shouldn't be that hard, but i was confused about the position of the winged washers. do they go on the outsides of the control arm?
Unique Coatings
cbrenn71 is offline
Old 01-23-2006, 10:03 AM   #8
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The winged washer goes right under the bolt head. The inside wing fits in the hole on the control arm. This washer acts like a lock washer to keep the bolt from turning when you tighten the nut on the other end. Before you install the bolts paint the arrow on the bolt head white or yellow. This will help the alignment guy and yourself know which way the cam on the bolt is pointed. I pointed both straight up (a neutral position) and then took it in for the alignment.
Geezer is offline
Old 01-23-2006, 01:37 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
The revised upper control arms do not allow for any adjustment.
They add +1 camber to alleviate too much negative camber, and have no provision for adjustment at all.
Installation instructions for the adjustable rear camber bolts:
http://www.teamfocus.us/camberboltsinstall.htm
WD40 is offline
Old 01-23-2006, 01:52 PM   #10
cbrenn71
cbrenn71's Avatar
Fan#: 30613
sorry, yeah, i meant that t hey add one degree, not plus or minus. i got them installed today. took me about 25 minutes from start to finish to do both sides.
thanks for the help guys. i can see visually my camber has taken a turn for the better just by installing them, and not having it aligned yet. time for new tires and an alignment.
Unique Coatings
cbrenn71 is offline
